Hi, not sure if that’s the right place to post, but since a few days, my volume +/-/mute keys (on f3, f2 and f1 respectively) don’t work, while all the others (change brightness, …) work no problem, and i know it does not come from my hardware since they still work as fn keys. I’ve tried rebooting my pc and restarting Pulseaudio, no success.
Here is the output of inxi --admin --verbosity=7 --filter --width :
Kernel: 5.16.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=ae898843-225c-4739-954d-1d43b362939c rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82LN v: IdeaPad 5 15ALC05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 15ALC05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709WIN
serial: <superuser required> UEFI: LENOVO v: H2CN23WW date: 12/13/2021
ID-1: BAT0 charge: 44.2 Wh (70.5%) condition: 62.7/70.0 Wh (89.5%)
volts: 15.7 min: 15.2 model: Celxpert L19C4PF1 type: Li-poly
serial: <filter> status: discharging cycles: 72
RAM: total: 5.72 GiB used: 3.85 GiB (67.3%)
RAM Report:
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1666 high: 2139 min/max: 1400/4370 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1638 2: 1929
3: 1537 4: 1415 5: 1660 6: 1635 7: 1783 8: 1600 9: 1556 10: 1863 11: 1577
12: 1397 13: 1893 14: 1631 15: 2139 16: 1408 bogomips: 57504
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x15f5 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.14-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.14-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:c822
class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 6 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 207.16 GiB (43.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: UMIS RPJTJ512MEE1OWX size: 476.94 GiB block-size: physical: 512 B
rev: 2.1C0628 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 237.85 GiB size: 233.05 GiB (97.99%)
used: 63.18 GiB (27.1%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: ae898843-225c-4739-954d-1d43b362939c
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 28.6 MiB (11.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: 4ED7-C9AA
ID-3: /run/media/nora/Windows-SSD raw-size: 237.85 GiB
size: 237.85 GiB (100.00%) used: 143.96 GiB (60.5%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows-SSD
uuid: 466CDAAD6CDA9751
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: WINRE_DRV uuid: 5802DBE802DBC960
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Syntek Integrated Camera type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 58.0 C
Processes: 343 Uptime: 21h 45m wakeups: 28 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1430
lib: 395 flatpak: 0 Shell: Zsh v: 5.8.1 running-in: konsole inxi: 3.3.15
Does anyone have an idea about what causes this issue ?
Thanks !!!
