Jana
August 27, 2022, 5:06pm
1
Use: Manjaro-ARM-kde-plasma-rpi4-22.08
Hi,
I need to use MobaXterm to connect to my Manjaro via VNC and SSH.
SSH connection it works for me but without support X11 forwarding.
1, how can i enable/install X11 forwardingsupport on my manjaro?
2, how can I install a VNC server that will be accessible to various programs that support VNC connections (example: MobaXterm )?
Thanks.
Hi Jana,
For X11 forwarding change this in /etc/ssh/sshd_config
X11Forwarding yes
X11DisplayOffset 10
X11UseLocalhost yes
Maybe Remmina
Remmina — X2Go, RDP, SSH, SPICE, VNC, and X2Go protocol remote desktop client.
Jana
August 27, 2022, 6:31pm
3
Remmina also occurred to me, but it seems that remmina is only a client without a server or no ?
I use RealVNC for everything, I found this: https://forum.manjaro.org/t/trouble-with-vnc-server-generic/104690
(pamac build realvnc-vnc-server
But I don’t know how to continue proceed and start RealVNC server.
Jana
August 27, 2022, 6:42pm
5
I have Manjaro ARM, deb package won’t work for me or will it?
Ah, I thought you already installed this as described here:
But the setup process should be the same.
Nope, you can’t install deb packages on Manjaro.
Jana
August 27, 2022, 6:49pm
7
) Does this mean that it will be compiled and automatically installed at the same time?
Yes, you can also use: pamac install realvnc-vnc-server
Jana
August 27, 2022, 7:08pm
9
it seems that the assembly went well, but no command will start the VNC Server
What are you trying to achieve?
If you want to control your remote using VNC over SSH
If you want to be able to run a single program on the remote machine and display the gui on your local you use X11 forwarding - xdmcp over ssh
Heard about it today. maybe also an alternative to VNC
https://aur.archlinux.org/packages/rustdesk
Discover RustDesk, open source remote desktop software, open source TeamViewer alternative, control your desktop remotely. You have full control of your data, no concerns about security.
Do you need the full desktop or just an application? If it’s just an application you can call it through ssh once it’s set up properly.
$ssh -X user@server
Once logged in you can call the application.
$application
You could also just use x11vnc and set it up as a service so it starts at boot. Any simple client will connect to it. I use gvncviewer when I actually use it…not often.
