I have upgrade to kernel 5.7.14 the other day and ever since I am not able to build the vmware kernel modules.
I have remove vmware and reinstalled all the prerequisites as it states here: VMware - ArchWiki
Specifically the linux-headers package
This is the logs of vmware-modconfig --install-all --console
[AppLoader] GLib does not have GSettings support.
Stopping VMware services:
VMware Authentication Daemon done
VM communication interface socket family done
Virtual machine communication interface done
Virtual machine monitor done
Blocking file system done
make: Entering directory '/tmp/modconfig-jv8Y1d/vmmon-only'
Using kernel build system.
/sbin/make -C /lib/modules/5.7.14-1-MANJARO/build/include/.. M=$PWD SRCROOT=$PWD/. \
MODULEBUILDDIR= modules
make[1]: Entering directory '/usr/lib/modules/5.7.14-1-MANJARO/build'
CC [M] /tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.o
CC [M] /tmp/modconfig-jv8Y1d/vmmon-only/linux/driverLog.o
CC [M] /tmp/modconfig-jv8Y1d/vmmon-only/linux/hostif.o
CC [M] /tmp/modconfig-jv8Y1d/vmmon-only/common/apic.o
CC [M] /tmp/modconfig-jv8Y1d/vmmon-only/common/comport.o
CC [M] /tmp/modconfig-jv8Y1d/vmmon-only/common/cpuid.o
CC [M] /tmp/modconfig-jv8Y1d/vmmon-only/common/memtrack.o
CC [M] /tmp/modconfig-jv8Y1d/vmmon-only/common/phystrack.o
/tmp/modconfig-jv8Y1d/vmmon-only/common/memtrack.o: warning: objtool: .text.__x86_indirect_thunk_rbx+0x0: unsupported intra-function call
CC [M] /tmp/modconfig-jv8Y1d/vmmon-only/common/sharedAreaVmmon.o
/tmp/modconfig-jv8Y1d/vmmon-only/common/memtrack.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
make[2]: *** [scripts/Makefile.build:267: /tmp/modconfig-jv8Y1d/vmmon-only/common/memtrack.o] Error 255
make[2]: *** Deleting file '/tmp/modconfig-jv8Y1d/vmmon-only/common/memtrack.o'
make[2]: *** Waiting for unfinished jobs....
/tmp/modconfig-jv8Y1d/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Free() falls through to next function PhysTrack_Add()
/tmp/modconfig-jv8Y1d/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Add() falls through to next function PhysTrack_Remove()
/tmp/modconfig-jv8Y1d/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Remove() falls through to next function PhysTrack_Test()
In file included from /tmp/modconfig-jv8Y1d/vmmon-only/./include/vm_asm.h:43,
from /tmp/modconfig-jv8Y1d/vmmon-only/linux/hostif.c:60:
/tmp/modconfig-jv8Y1d/vmmon-only/./include/x86msr.h:140: warning: "MSR_MISC_FEATURES_ENABLES" redefined
140 | #define MSR_MISC_FEATURES_ENABLES 0x140
In file included from ./arch/x86/include/asm/nospec-branch.h:11,
from ./arch/x86/include/asm/irqflags.h:9,
from ./include/linux/irqflags.h:16,
from ./include/linux/rcupdate.h:26,
from ./include/linux/rculist.h:11,
from ./include/linux/pid.h:5,
from ./include/linux/sched.h:14,
from ./include/linux/binfmts.h:5,
from /tmp/modconfig-jv8Y1d/vmmon-only/linux/hostif.c:32:
./arch/x86/include/asm/msr-index.h:719: note: this is the location of the previous definition
719 | #define MSR_MISC_FEATURES_ENABLES 0x00000140
/tmp/modconfig-jv8Y1d/vmmon-only/./include/x86msr.h:475: warning: "MSR_K7_HWCR_SMMLOCK" redefined
475 | #define MSR_K7_HWCR_SMMLOCK 0x00000001ULL // Lock SMM environment
./arch/x86/include/asm/msr-index.h:527: note: this is the location of the previous definition
527 | #define MSR_K7_HWCR_SMMLOCK BIT_ULL(MSR_K7_HWCR_SMMLOCK_BIT)
/tmp/modconfig-jv8Y1d/vmmon-only/./include/x86msr.h:636: warning: "MSR_TSX_FORCE_ABORT" redefined
636 | #define MSR_TSX_FORCE_ABORT 0x0000010f
./arch/x86/include/asm/msr-index.h:728: note: this is the location of the previous definition
728 | #define MSR_TSX_FORCE_ABORT 0x0000010F
In file included from /tmp/modconfig-jv8Y1d/vmmon-only/./include/vm_asm_x86.h:41,
from /tmp/modconfig-jv8Y1d/vmmon-only/./include/vm_asm.h:44,
/tmp/modconfig-jv8Y1d/vmmon-only/./include/x86_basic_defs.h:78: warning: "CR3_PCID_MASK" redefined
78 | #define CR3_PCID_MASK 0xFFF
In file included from ./arch/x86/include/asm/irqflags.h:5,
./arch/x86/include/asm/processor-flags.h:39: note: this is the location of the previous definition
39 | #define CR3_PCID_MASK 0xFFFull
In file included from /tmp/modconfig-jv8Y1d/vmmon-only/./common/vmx86.h:32,
from /tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.h:33,
from /tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.c:47:
from ./arch/x86/include/asm/paravirt_types.h:46,
from ./arch/x86/include/asm/ptrace.h:94,
from ./arch/x86/include/asm/math_emu.h:5,
from ./arch/x86/include/asm/processor.h:13,
from ./arch/x86/include/asm/cpufeature.h:5,
from ./arch/x86/include/asm/thread_info.h:53,
from ./include/linux/thread_info.h:38,
from ./arch/x86/include/asm/preempt.h:7,
from ./include/linux/preempt.h:78,
from ./include/linux/spinlock.h:51,
from ./include/linux/wait.h:9,
from ./include/linux/wait_bit.h:8,
from ./include/linux/fs.h:6,
from ./include/linux/highmem.h:5,
from /tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.c:25:
from /tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.c:49:
In file included from ./arch/x86/include/asm/processor.h:5,
/tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.c: In function ‘LinuxDriver_Ioctl’:
/tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.c:1230:5: warning: "VMX86_DEVEL" is not defined, evaluates to 0 [-Wundef]
1230 | #if VMX86_DEVEL
At top level:
/tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.c:668:1: warning: ‘always_inline’ function might not be inlinable [-Wattributes]
668 | LinuxDriverSyncReadTSCs(uint64 *delta) // OUT: TSC max - TSC min
/tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.o: warning: objtool: .text.__x86_indirect_thunk_rax+0x0: unsupported intra-function call
/tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
make[2]: *** [scripts/Makefile.build:267: /tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.o] Error 255
make[2]: *** Deleting file '/tmp/modconfig-jv8Y1d/vmmon-only/linux/driver.o'
/tmp/modconfig-jv8Y1d/vmmon-only/linux/hostif.o: warning: objtool: .text.__x86_indirect_thunk_rax+0x0: unsupported intra-function call
/tmp/modconfig-jv8Y1d/vmmon-only/linux/hostif.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
make[2]: *** [scripts/Makefile.build:267: /tmp/modconfig-jv8Y1d/vmmon-only/linux/hostif.o] Error 255
make[2]: *** Deleting file '/tmp/modconfig-jv8Y1d/vmmon-only/linux/hostif.o'
make[1]: *** [Makefile:1732: /tmp/modconfig-jv8Y1d/vmmon-only] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.7.14-1-MANJARO/build'
make: *** [Makefile:117: vmmon.ko] Error 2
make: Leaving directory '/tmp/modconfig-jv8Y1d/vmmon-only'
make: Entering directory '/tmp/modconfig-jv8Y1d/vmnet-only'
CC [M] /tmp/modconfig-jv8Y1d/vmnet-only/driver.o
CC [M] /tmp/modconfig-jv8Y1d/vmnet-only/hub.o
CC [M] /tmp/modconfig-jv8Y1d/vmnet-only/userif.o
CC [M] /tmp/modconfig-jv8Y1d/vmnet-only/netif.o
CC [M] /tmp/modconfig-jv8Y1d/vmnet-only/bridge.o
CC [M] /tmp/modconfig-jv8Y1d/vmnet-only/procfs.o
CC [M] /tmp/modconfig-jv8Y1d/vmnet-only/smac_compat.o
CC [M] /tmp/modconfig-jv8Y1d/vmnet-only/smac.o
CC [M] /tmp/modconfig-jv8Y1d/vmnet-only/vnetEvent.o
CC [M] /tmp/modconfig-jv8Y1d/vmnet-only/vnetUserListener.o
In file included from ./include/linux/pci.h:43,
from /tmp/modconfig-jv8Y1d/vmnet-only/compat_netdevice.h:27,
from /tmp/modconfig-jv8Y1d/vmnet-only/netif.c:44:
./include/linux/pci_ids.h:2294: warning: "PCI_VENDOR_ID_VMWARE" redefined
2294 | #define PCI_VENDOR_ID_VMWARE 0x15ad
In file included from /tmp/modconfig-jv8Y1d/vmnet-only/net.h:38,
from /tmp/modconfig-jv8Y1d/vmnet-only/vnetInt.h:26,
from /tmp/modconfig-jv8Y1d/vmnet-only/netif.c:43:
/tmp/modconfig-jv8Y1d/vmnet-only/vm_device_version.h:56: note: this is the location of the previous definition
56 | #define PCI_VENDOR_ID_VMWARE 0x15AD
./include/linux/pci_ids.h:2295: warning: "PCI_DEVICE_ID_VMWARE_VMXNET3" redefined
2295 | #define PCI_DEVICE_ID_VMWARE_VMXNET3 0x07b0
/tmp/modconfig-jv8Y1d/vmnet-only/vm_device_version.h:74: note: this is the location of the previous definition
74 | #define PCI_DEVICE_ID_VMWARE_VMXNET3 0x07B0
from /tmp/modconfig-jv8Y1d/vmnet-only/bridge.c:53:
/tmp/modconfig-jv8Y1d/vmnet-only/vm_device_version.h:56: warning: "PCI_VENDOR_ID_VMWARE" redefined
from /tmp/modconfig-jv8Y1d/vmnet-only/bridge.c:52:
./include/linux/pci_ids.h:2294: note: this is the location of the previous definition
/tmp/modconfig-jv8Y1d/vmnet-only/vm_device_version.h:74: warning: "PCI_DEVICE_ID_VMWARE_VMXNET3" redefined
./include/linux/pci_ids.h:2295: note: this is the location of the previous definition
/tmp/modconfig-jv8Y1d/vmnet-only/vnetEvent.o: warning: objtool: .text.__x86_indirect_thunk_r12+0x0: unsupported intra-function call
/tmp/modconfig-jv8Y1d/vmnet-only/vnetEvent.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
make[2]: *** [scripts/Makefile.build:267: /tmp/modconfig-jv8Y1d/vmnet-only/vnetEvent.o] Error 255
make[2]: *** Deleting file '/tmp/modconfig-jv8Y1d/vmnet-only/vnetEvent.o'
/tmp/modconfig-jv8Y1d/vmnet-only/procfs.o: warning: objtool: .text.__x86_indirect_thunk_r10+0x0: unsupported intra-function call
/tmp/modconfig-jv8Y1d/vmnet-only/procfs.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
make[2]: *** [scripts/Makefile.build:267: /tmp/modconfig-jv8Y1d/vmnet-only/procfs.o] Error 255
make[2]: *** Deleting file '/tmp/modconfig-jv8Y1d/vmnet-only/procfs.o'
/tmp/modconfig-jv8Y1d/vmnet-only/hub.o: warning: objtool: .text.__x86_indirect_thunk_rax+0x0: unsupported intra-function call
/tmp/modconfig-jv8Y1d/vmnet-only/hub.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
make[2]: *** [scripts/Makefile.build:266: /tmp/modconfig-jv8Y1d/vmnet-only/hub.o] Error 255
make[2]: *** Deleting file '/tmp/modconfig-jv8Y1d/vmnet-only/hub.o'
/tmp/modconfig-jv8Y1d/vmnet-only/userif.o: warning: objtool: .text.__x86_indirect_thunk_rax+0x0: unsupported intra-function call
/tmp/modconfig-jv8Y1d/vmnet-only/userif.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
make[2]: *** [scripts/Makefile.build:267: /tmp/modconfig-jv8Y1d/vmnet-only/userif.o] Error 255
make[2]: *** Deleting file '/tmp/modconfig-jv8Y1d/vmnet-only/userif.o'
/tmp/modconfig-jv8Y1d/vmnet-only/driver.o: warning: objtool: .text.__x86_indirect_thunk_rax+0x0: unsupported intra-function call
/tmp/modconfig-jv8Y1d/vmnet-only/driver.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
make[2]: *** [scripts/Makefile.build:267: /tmp/modconfig-jv8Y1d/vmnet-only/driver.o] Error 255
make[2]: *** Deleting file '/tmp/modconfig-jv8Y1d/vmnet-only/driver.o'
/tmp/modconfig-jv8Y1d/vmnet-only/bridge.o: warning: objtool: .text.__x86_indirect_thunk_rcx+0x0: unsupported intra-function call
/tmp/modconfig-jv8Y1d/vmnet-only/bridge.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
make[2]: *** [scripts/Makefile.build:267: /tmp/modconfig-jv8Y1d/vmnet-only/bridge.o] Error 255
make[2]: *** Deleting file '/tmp/modconfig-jv8Y1d/vmnet-only/bridge.o'
/tmp/modconfig-jv8Y1d/vmnet-only/vnetUserListener.o: warning: objtool: .text.__x86_indirect_thunk_rax+0x0: unsupported intra-function call
/tmp/modconfig-jv8Y1d/vmnet-only/vnetUserListener.o: warning: objtool: If this is a retpoline, please patch it in with alternatives and annotate it with ANNOTATE_NOSPEC_ALTERNATIVE.
make[2]: *** [scripts/Makefile.build:267: /tmp/modconfig-jv8Y1d/vmnet-only/vnetUserListener.o] Error 255
make[2]: *** Deleting file '/tmp/modconfig-jv8Y1d/vmnet-only/vnetUserListener.o'
make[1]: *** [Makefile:1732: /tmp/modconfig-jv8Y1d/vmnet-only] Error 2
make: *** [Makefile:117: vmnet.ko] Error 2
make: Leaving directory '/tmp/modconfig-jv8Y1d/vmnet-only'
Unable to install all modules. See log for details.
I am all new to this and results in google from this forum lead to me a page saying the post does exist.
I have tried reading the log but could not understand.
Does anyone what to do?
