Hi, i have just installed qemu but i crash when the windows setup starts. I’m following this guide by some ordinary gamers. I’ve given the VM 6/8GB and 8 of my 12 threads. Any help would be appreciated.
Thanks.
Thanks.
Hello @pro0110
You can not expect that someone would watch a 45min video just for explanation. Summarize step by step what you have done.
Thanks.
this is what ive done from my basic understanding
enabled iommu
installed qemu libvirt edk2-ovmf virt-manager ebtables dnsmasq packages
enabled and started libvirtd.service and virtlogd.socket
started default network
vm settings:
chipset q35
firmware UEFI x86_64: /usr/share/edk2-ovmf/x64/OVMF_CODE.fd
cpu 1 socket, 4 cores, 2 threads
ram 6gb
enabled cd rom boot
no other settings were changed
after booting the vm, whole pc crashes
Have a look at this guide:
And then please post your system information. Thanks.
~ sudo inxi --admin --verbosity=7 --filter --no-host --width ✔
[sudo] password for billly:
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=08285496-6e64-4925-bc1c-fc6dab36d749 rw quiet
cryptdevice=UUID=2f4041b2-f195-4632-b980-5dcd032197df:luks-2f4041b2-f195-4632-b980-5dcd032197df
root=/dev/mapper/luks-2f4041b2-f195-4632-b980-5dcd032197df apparmor=1
security=apparmor amd_iommu=on udev.log_priority=3
Console: tty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 4007 date: 12/08/2020
RAM: total: 7.69 GiB used: 1.86 GiB (24.1%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM_A1 size: 8 GiB speed: 2133 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Crucial Technology
part-no: CT8G4DFD8213.C16FBR2 serial: <filter>
Device-2: DIMM_A2 size: No Module Installed
Device-3: DIMM_B1 size: No Module Installed
Device-4: DIMM_B2 size: No Module Installed
Info: 6-Core model: AMD Ryzen 5 2600X socket: AM4 bits: 64 type: MT MCP
arch: Zen+ family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache:
L1: 576 KiB L2: 3 MiB L3: 16 MiB bogomips: 93460
Speed: 3868 MHz min/max: 2200/3900 MHz base/boost: 3900/4250 boost: disabled
volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz): 1: 3868 2: 1947 3: 2195
4: 2194 5: 1954 6: 2194 7: 2196 8: 2195 9: 3874 10: 1947 11: 1947 12: 2195
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: ASUSTeK driver: nouveau
v: kernel bus-ID: 08:00.0 chip-ID: 10de:1c81 class-ID: 0300
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 38
size: 1280x720mm (50.4x28.3") diag: 1469mm (57.8")
OpenGL: renderer: NV137 v: 4.3 Mesa 21.2.1 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-2: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel port: c000 bus-ID: 07:00.0 chip-ID: 10ec:818b class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: luks-2f4041b2-f195-4632-b980-5dcd032197df maj-min: 254:0
type: LUKS dm: dm-0 size: 232.59 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 232.59 GiB
Local Storage: total: 232.89 GiB used: 55.61 GiB (23.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD2500BVVT-28A26Y1 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 1A01 temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 249d 5h cycles: 2634
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 55.61 GiB (24.4%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-2f4041b2-f195-4632-b980-5dcd032197df label: N/A
uuid: 08285496-6e64-4925-bc1c-fc6dab36d749
used: 440 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: NO_LABEL uuid: D942-C738
Device-1: 1-1:2 info: Microdia USB DEVICE type: Keyboard,Mouse
power: 400mA chip-ID: 0c45:6656 class-ID: 0301
Device-2: 1-5:3 info: Winbond ADXMK0419 type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 400mA chip-ID: 0416:a0f8 class-ID: 0301 serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 36.5 C mobo: N/A gpu: nouveau temp: 34.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 973
Processes: 316 Uptime: 6m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1262 lib: 340 flatpak: 0
Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
You cannot passthrough a GPU which is in use. You need one GPU for Xorg and a second GPU for the VM. Only GPUs which can be used for xorg and multiple VMs are modern Intel GPUs.
im not even on the gpu pass through part, i havent even installed my os yet
Ah ok sorry…
So you gave it 6Gigs of your 8Gig memory and did not even consider to have swapfile/partition:
I guess it did not crash, but rather freeze because the host have less memory available and cannot swap.
alright, ill try with maybe 3gb instead and let u know
also i have no clue how to make swap
Also Luks encryption needs memory for decryption and will slow down the whole process.
seems to be working now, thanks!
