My VLC stutters (even for this humble 480p reading of Arthur C Clarke’s A Walk in the Dark.
This is surprising to me given my system specs (the file is local, not network) and is on my NVME hard drive.
I would not expect such seeking issues, which are only compounded when I view my 1080p school material.
Here is a video of it in action at various speeds: https://youtu.be/Gf0ixc14Ulw
How can I resolve this?
VLC Options:
System Specs:
Host: MidnightStarSign Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.2.0 Desktop: KDE Plasma 5.20.4 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser/root required> UEFI: American Megatrends v: 1407
date: 04/02/2020
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
L2 cache: 3072 KiB
bogomips: 94842
Speed: 3950 MHz min/max: 2200/3950 MHz boost: enabled Core speeds (MHz):
1: 3950 2: 3950 3: 3950 4: 3950 5: 3950 6: 3950 7: 3950 8: 3950 9: 3950
10: 3950 11: 3950 12: 3950
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASRock driver: amdgpu v: kernel bus ID: 0b:00.0
Display: x11 server: X.Org 1.20.10 driver: amdgpu,ati
unloaded: modesetting,radeon resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
3: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.39.0 5.9.11-3-MANJARO
LLVM 11.0.0)
v: 4.6 Mesa 20.2.3 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 0b:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0d:00.4
Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus ID: 7-2:3
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: f000 bus ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 24:4b:fe:5b:08:2a
Local Storage: total: 4.62 TiB used: 1.82 TiB (39.3%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T2B0C-00PXH0
ID-2: /dev/sda vendor: Seagate model: ST2000LM015-2E8174 size: 1.82 TiB
ID-3: /dev/sdb vendor: Seagate model: ST380815AS size: 74.51 GiB
ID-4: /dev/sdc vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
ID-5: /dev/sdd vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
ID-1: / size: 767.00 GiB used: 312.69 GiB (40.8%) fs: btrfs dev: /dev/dm-0
ID-2: /home size: 767.00 GiB used: 312.69 GiB (40.8%) fs: btrfs dev: /dev/dm-0
ID-1: swap-1 type: partition size: 64.00 GiB used: 0 KiB (0.0%) dev: /dev/dm-1
System Temperatures: cpu: 45.8 C mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 524 Uptime: 5h 27m Memory: 31.33 GiB used: 9.47 GiB (30.2%)
Init: systemd Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1813 Shell: Bash
v: 5.0.18 inxi: 3.1.08
