Sarah
1
I have an issue with VLC, especially at high speeds (4x / 3x) where the audio clips heavily when I seek around.
Since I have an NVME SSD, I wouldn’t think that this would happen, but it does. I’ve tried all the usual settings changes.
I should note that it only appears to be the audio, and not the video; the video is just fine.
Here are the file cache settings:
Disabling hardware decoding and manually setting the number of ffmpeg threads didn’t help
How can I stop the audio from stuttering?
Hi, Sarah
Are you open the tab of the Play ? You find the menu with the selector of speed. Maybe use the normal mode, this solve the problem
Sarah
3
I have no idea what this means
What normal mode? I need to watch things at > 2x speed. It’s a requirement since I don’t have much time in my life for watching things I want to watch
We need the result of this command line: inxi --full --verbosity=7 --filter, please and post your demand of help in sounds category
Sarah
6
System: Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1407 date: 04/02/2020
Memory: RAM: total: 31.33 GiB used: 8.15 GiB (26.0%)
CPU: Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 L2 cache: 3072 KiB
bogomips: 94843
Speed: 3950 MHz min/max: 2200/3950 MHz boost: enabled Core speeds (MHz): 1: 3950 2: 3950 3: 3950
4: 3949 5: 3950 6: 3950 7: 3950 8: 3950 9: 3950 10: 3950 11: 3950 12: 3949
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3
cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc
cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt
nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc
perfctr_nb pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good
sep sev sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Graphics: Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: ASRock driver: amdgpu
v: kernel bus ID: 0a:00.0 chip ID: 1002:731f
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu FAILED: ati
unloaded: modesetting,radeon alternate: fbdev,vesa resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz 3: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.38.0 5.8.3-2-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.6 direct render: Yes
Audio: Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 0a:00.1
chip ID: 1002:ab38
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 0c:00.4 chip ID: 1022:1487
Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo bus ID: 5-2:3
chip ID: 0c45:6367 serial: <filter>
Sound Server: ALSA v: k5.8.3-2-MANJARO
Network: Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: 5.6.0-k port: f000
bus ID: 04:00.0 chip ID: 8086:1539
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 4.64 TiB used: 1.66 TiB (35.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T2B0C-00PXH0 size: 931.51 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 211070WD scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST2000LM015-2E8174 size: 1.82 TiB speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-3: /dev/sdb vendor: Seagate model: ST380815AS size: 74.51 GiB speed: 3.0 Gb/s
serial: <filter> rev: A scheme: GPT
ID-4: /dev/sdc vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1C scheme: GPT
ID-5: /dev/sdd vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: RSM4 scheme: GPT
ID-6: /dev/sde type: USB vendor: Toshiba model: TransMemory size: 14.92 GiB serial: <filter>
rev: 1.00 scheme: MBR
ID-7: /dev/sdf type: USB vendor: SanDisk model: Gaming Xbox 360 size: 7.48 GiB serial: <filter>
rev: 8.02 scheme: MBR
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 767.00 GiB used: 499.68 GiB (65.1%) fs: btrfs dev: /dev/dm-0 label: N/A
uuid: 6ce26050-4dcc-47b7-a937-45467d8b8d61
ID-2: /boot/efi size: 511.0 MiB used: 716 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 label: N/A
uuid: 4B3B-683F
ID-3: /home size: 767.00 GiB used: 499.68 GiB (65.1%) fs: btrfs dev: /dev/dm-0 label: N/A
ID-4: /mnt/System_Root size: 767.00 GiB used: 499.68 GiB (65.1%) fs: btrfs dev: /dev/dm-0
label: N/A uuid: 6ce26050-4dcc-47b7-a937-45467d8b8d61
ID-5: /run/media/sarah/Convergent Refuge size: 1.82 TiB used: 1.17 TiB (64.4%) fs: btrfs
dev: /dev/dm-2 label: Convergent Refuge uuid: a1dfce78-131b-4b86-9914-801098c8b8f9
Swap: ID-1: swap-1 type: partition size: 64.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
label: N/A uuid: c5112526-26fb-473c-b7ab-bb9ef049aa38
Unmounted: ID-1: /dev/nvme0n1p2 size: 767.00 GiB fs: crypto_luks label: N/A
uuid: 466d5812-64c7-4a28-bcc4-a1a5adfa9450
ID-2: /dev/nvme0n1p3 size: 64.00 GiB fs: crypto_luks label: N/A
uuid: 81b2dc57-06f5-4471-b484-77c3a516f307
ID-3: /dev/nvme0n1p4 size: 450.0 MiB fs: ntfs label: Recovery uuid: 32ECB8E3ECB8A291
ID-4: /dev/nvme0n1p5 size: 100.0 MiB fs: vfat label: N/A uuid: 98BB-C59C
ID-5: /dev/nvme0n1p6 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-6: /dev/nvme0n1p7 size: 99.46 GiB fs: ntfs label: N/A uuid: D01A88621A884804
ID-7: /dev/sda1 size: 1.82 TiB fs: crypto_luks label: N/A
uuid: 3993eeb9-a4f3-42e1-a34c-10e52fa83113
ID-8: /dev/sdb1 size: 74.50 GiB fs: btrfs label: Satellite Galaxy
uuid: 24d99e13-090e-4513-a7e2-06f8c89907d7
ID-9: /dev/sdc1 size: 931.51 GiB fs: ntfs label: Nihilistic Automaton uuid: 6FD2B3C077FEE0EB
ID-10: /dev/sdd1 size: 931.51 GiB fs: ntfs label: N/A uuid: 02F9C8074F371C3F
ID-11: /dev/sde1 size: 2.91 GiB fs: iso9660 label: MANJARO_KDE_2003 uuid: 2020-06-06-08-14-33-00
ID-12: /dev/sde2 size: 4.0 MiB fs: vfat label: MISO_EFI uuid: F327-8F27
ID-13: /dev/sdf1 size: 2.91 GiB fs: iso9660 label: MANJARO_KDE_2003 uuid: 2020-06-06-08-14-33-00
ID-14: /dev/sdf2 size: 4.0 MiB fs: vfat label: MISO_EFI uuid: F327-8F27
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: <vendor specific>
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 0b05:18f3
serial: <filter>
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 5-1:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0 speed: 480 Mb/s chip ID: 1a40:0201
Device-1: 5-1.1:4 info: Sunplus Innovation Gaming mouse [Philips SPK9304] type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s chip ID: 1bcf:08a0
Device-2: 5-1.3:5 info: Future Devices FT232 Serial (UART) IC type: <vendor specific>
driver: ftdi_sio interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 0403:6001 serial: <filter>
Device-3: 5-1.4:6 info: Toshiba TransMemory-Mini / Kingston DataTraveler 2.0 Stick
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0930:6544
serial: <filter>
Device-4: 5-1.5:7 info: Elan Micro type: Keyboard driver: hid-generic,usbhid interfaces: 2
rev: 1.1 speed: 1.5 Mb/s chip ID: 04f3:152e
Device-5: 5-1.6:8 info: N/A type: Mouse,HID driver: uclogic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s chip ID: 256c:006e
Hub: 5-1.7:9 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1a40:0101
Device-1: 5-1.7.3:10 info: Texas Instruments TI-Nspire Calculator type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 0451:e012
Device-2: 5-1.7.4:11 info: SanDisk Cruzer Micro Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0781:5151 serial: <filter>
Device-3: 5-2:3 info: Microdia USB 2.0 Camera type: Video,Audio driver: snd-usb-audio,uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s chip ID: 0c45:6367 serial: <filter>
Hub: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 46 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 497 Uptime: 2h 36m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1577
pacman: 1565 flatpak: 3 snap: 9 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Thanks, I think to go back on old version of kernel. Try the kernel 5.04.60-2 and reboot for see the result
