I was looking something up and saw this
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f057ab0b-fbae-4962-b6a1-c852b0ec828d rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude E6510 v: 0001
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0N5KHN v: A02 serial: <superuser required> BIOS: Dell
v: A17 date: 05/12/2017
ID-1: BAT0 charge: 52.8 Wh (100.0%) condition: 52.8/57.7 Wh (91.5%)
volts: 12.5 min: 11.1 model: Samsung SDI DELL PT43696 type: Li-ion
serial: <filter> status: full
RAM: total: 15.56 GiB used: 10.93 GiB (70.2%)
Info: model: Intel Core i7 Q 720 bits: 64 type: MT MCP arch: Nehalem
gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6
model-id: 0x1E (30) stepping: 5 microcode: 0xA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1786 high: 2688 min/max: 933/1600 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2291 2: 2113 3: 2688
4: 2168 5: 933 6: 933 7: 2229 8: 933 bogomips: 25550
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti
rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GT218M [NVS 3100M] vendor: Dell Latitude E6510
driver: nouveau v: kernel non-free: series: 340.xx status: legacy (EOL) last:
release: 340.108 kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm
built: 2006-13 pcie: gen: 2 speed: 5 GT/s lanes: 16 ports:
active: DP-1,VGA-1 off: eDP-1 empty: DP-2 bus-ID: 01:00.0
chip-ID: 10de:0a6c class-ID: 0300 temp: 72.0 C
Device-2: Ricoh HD Webcam type: USB driver: uvcvideo bus-ID: 1-1.4:5
chip-ID: 05ca:1814 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 950x285mm (37.40x11.22")
s-diag: 992mm (39.05")
Monitor-1: DP-1 pos: right model: BenQ G2200W serial: <filter> built: 2009
res: 1680x1050 dpi: 90 gamma: 1.2 size: 474x296mm (18.66x11.65")
diag: 559mm (22") ratio: 16:10 modes: max: 1680x1050 min: 720x400
Monitor-2: VGA-1 pos: primary,left model: Dell P2311H serial: <filter>
built: 2010 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-3: eDP-1 note: disabled model: LG Display built: 2009
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 800x600
API: OpenGL v: 3.3 Mesa 22.3.5 renderer: NVA8 direct-render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Dell Latitude E6510 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-2: NVIDIA High Definition Audio vendor: Dell Latitude E6510
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel 82577LM Gigabit Network vendor: Dell Latitude E6510
driver: e1000e v: kernel port: 8040 bus-ID: 00:19.0 chip-ID: 8086:10ea
class-ID: 0200
Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:422c
class-ID: 0280
Device-3: Dell F3607gw v2 Mobile Broadband Module type: USB
driver: cdc_acm,cdc_ether,cdc_wdm bus-ID: 2-1.6:3 chip-ID: 413c:8184
class-ID: 0202 serial: <filter>
IF: wwp0s29u1u6i6 state: down mac: <filter>
Device-1: Dell DW375 Bluetooth Module type: USB driver: btusb v: 0.8
bus-ID: 2-1.7:4 chip-ID: 413c:8187 class-ID: fe01 serial: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 8020 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 119.24 GiB used: 17.01 GiB (14.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD PM800 2.5 128GB
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 5D1Q scheme: MBR
Optical-1: /dev/sr0 vendor: Optiarc model: DVD+-RW AD-7930H rev: 100A
dev-links: cdrom
ID-1: / raw-size: 119.24 GiB size: 116.81 GiB (97.96%)
used: 17.01 GiB (14.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: f057ab0b-fbae-4962-b6a1-c852b0ec828d
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Hub-3: 1-1.1:3 info: Dell internal USB Hub of E-Port Replicator ports: 3
rev: 2.0 speed: 480 Mb/s power: 2mA chip-ID: 413c:2513 class-ID: 0900
Hub-4: 1-1.2:4 info: Dell internal USB Hub of E-Port Replicator ports: 3
Device-1: 1-1.2.1:6 info: Holtek Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04d9:a096 class-ID: 0300
Device-2: 1-1.2.2:7 info: Logitech Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-3: 1-1.4:5 info: Ricoh HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA chip-ID: 05ca:1814
class-ID: 0e02
Hub-5: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
Hub-6: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.6:3 info: Dell F3607gw v2 Mobile Broadband Module
type: Communication,Abstract (modem),CDC-Data,Mobile Direct Line
driver: cdc_acm,cdc_ether,cdc_wdm interfaces: 11 rev: 2.0 speed: 480 Mb/s
power: 20mA chip-ID: 413c:8184 class-ID: 0202 serial: <filter>
Device-2: 2-1.7:4 info: Dell DW375 Bluetooth Module type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 100mA
Device-3: 2-1.8:5 info: Broadcom BCM5880 Secure Applications Processor
with fingerprint swipe sensor type: Smart Card driver: N/A interfaces: 2
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0a5c:5801 class-ID: 0b00
serial: <filter>
System Temperatures: cpu: 77.0 C mobo: N/A sodimm: SODIMM C gpu: nouveau
temp: 72.0 C
Fan Speeds (RPM): cpu: 3594
Processes: 238 Uptime: 6h 10m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1203 pm: pacman pkgs: 1199 libs: 330 tools: pamac,yay pm: flatpak
pkgs: 4 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
