Hi guys good night! In Manjaro 22, with the xfce graphical environment, the panel, when it is at the bottom of the screen (default), the plugin notifications (I don’t know if this is the correct term) appear almost completely covered behind the same panel, according to the photo shows, where the mouse cursor points to the battery indicator, when the status notification appears in a hidden way as explained. Any correction suggestions?!
Try Settings > Panel > Panel 0 > Display, “Reserve space on screen edges for the panel”.
Maybe this:
Solved! Thank you!
