Hello i try run other linux on virtualbox and i got error message ‘’ Kernel driver not installed (rc=-1908)
If you are running Manjaro as a guest in Virtualbox, you probably need to install virtualbox-guest-dkms package
pacman -Syu virtualbox-guest-dkms
Edit. When you say “other linux on virtualbox” did you mean you run Manjaro as host, installed virtualbox, and then are trying to run some other Linux distribution there? If so, you will need to look at that distribution’s package repository for the similar package as above.
They should already be installed. See @linux-aarhus’s awesome tutorial on the archived forum:
EDIT: Updated link
Thx for this link now work fine
@Yochanan
Thank you.
I have transferred the guide the new forum.
