[HowTo] VirtualBox - Installation - USB - Shared Folder
Difficulty: ★★☆☆☆
VirtualBox - Installation, USB, Shared folders
It is recommended to read the VirtualBox article on the Wiki or the VirtualBox End-user documentation.
Topics Covered
  1. Host Packages and Installation
  2. Basic Host Configuration
  3. Basic VM Configuration
  4. Oracle VirtualBox Extensions
  5. Advanced VM Configuration
  6. Manjaro Guest Installation
  7. Other Linux Guest Installation
  8. Manjaro Guest Configuration
  9. Linux Shared Folders
  10. Troubleshooting Screen Issues
  11. Windows Guest Configuration
  12. Display issues
Packages to be installed
  • VirtualBox
  • VirtualBox Host Modules
  • VirtualBox Guest Additions ISO
  • Oracle VirtualBox Extension Pack
System Firmware
Before you install - reboot to your system and ensure you have enabled virtual extensions in your systems firmware.
systemctl reboot --firmware-setup
Installation
Your current active kernel is found using the mhwd-kernel command (@sueridgepipe note)
$ mhwd-kernel -li
linux57
Install virtualbox with the required kernel modules matching the output from your system.
$ pamac install virtualbox linux57-virtualbox-host-modules virtualbox-guest-iso
You need remember to install kernel modules for every kernel installed on which you intend to use VirtualBox.
Load kernel modules
Prior to using VirtualBox kernel modules must be loaded. Either restart your system or load it manually.
VirtualBox might come with a window prompting you to run either
  • /sbin/rcvbox
  • /sbin/vboxconfig
These commands are for other operating systems and does not exist on Manjaro.
The command to (re)load VirtualBox kernel modules on Manjaro is
$ sudo vboxreload
2. Basic Host configuration
Your host user must be member of the group vboxusers. The variable $USER below translates to your current logged in username.
$ sudo gpasswd -a $USER vboxusers
Log off to register the change.
3. Basic VM configuration
General
Advanced
  • Shared Clipboard (handy)
  • Drag’n’Drop (don’t work)
System
Motherboard
  • Base Memory 2 to 4 GB
  • Untick Floppy
  • Tick Enable EFI
  • Hardware Clock UTC
    • Linux guest - ticked
    • Windows guest - unticked
Processor
  • 2 processors
Display
The chosen default display type for any Linux is VMSVGA and this will be good for most distributions.
Use either
  • VMSVGA
    • optional select 3D
  • 128MB
Or
  • VBoxSVGA
  • 128MB
Using VBoxSVGA or VMSVGA is a choice. VBoxSVGA will make VirtualBox complain on invalid settings but using VMSVGA your VM will not resize to adapt to changes in window size.
If you want to be sure Manjaro guest will resize correct you must choose the VBoxSVGA display type and ignore the warning.
Selecting VBoxSVGA and 3D will reset your graphics to VMSVGA and 3D.
:manjaro: You can cheat VBox to use VboxSVGA and 3D
  • Initially create the VM using VMSVGA and 3D
  • Select the VM in VBoxManager
  • In the Display section click VMSVGA and change it to VBoxSVGA
  • Start the VM
4. VirtualBox extensions
The extension pack is a proprietary set of extensions providing extra functionality to VirtualBox like USB2 and USB3 passthrough.
Functionality provided is
  • Oracle Cloud Infrastructure integration
  • USB 2.0 and USB 3.0 Host Controller
  • Host Webcam
  • VirtualBox RDP
  • PXE ROM
  • Disk Encryption
  • NVMe
You only need this if you are going to use the above functionality provided and it is not required for VirtualBox to function.
As noted by VirtualBox it important you are using the extension pack matching your installed version of VirtualBox
Please install the same version extension pack as your installed version of VirtualBox.
Downloads – Oracle VM VirtualBox
As suggested in a comment below (thank you @j77h) - check your version.
$ vboxmanage --version
6.1.14r140239
Install using AUR
The extension pack’s PKGBUILD is provided from AUR so we use Pamac to build and install it. Remember to match your VirtualBox version
$ pamac search virtualbox-ext-oracle
virtualbox-ext-oracle-manjaro         6.1.12-2         AUR
    Oracle VM VirtualBox Extension
    Pack
virtualbox-ext-oracle-beta            6.1.0_RC1-1      AUR
    Pack (Beta)
virtualbox-ext-oracle-5-test-build    5.2.35_135314-1  AUR
    Pack Test Build 5.2.35_135314
virtualbox-ext-oracle-5.0             5.0.40-1         AUR
    Pack
virtualbox-ext-oracle-5               5.2.x-1          AUR
    Pack 5.2.x (stable)
virtualbox-ext-oracle                 6.1.14-1         AUR
    Pack
When you decided which version to install
$ pamac build virtualbox-ext-<your-decision>
Download from VirtualBox
Download the extensions package from below link - remember to match your VirtualBox version.
Sometimes the stable branch of Manjaro is not in line with AUR - in this case you need locate the matching extension pack manually.
The extension .vbox-extpack is a registered mime extension so just open the file and VirtualBox will install the extension pack. Provide your password when asked.
5. Advanced Guest Configuration
Advanced configuration requires the extension pack to be installed. You can configure USB passthrough for USB-2 and USB-3. You need to configure your guest system to use USB-3 if you have such controller. This is done in the USB Settings menu item. Do not attach any devices on this tab unless you are doing something advanced.
Attach a device
Access the DevicesUSB menu in VirtualBox Machine Window or USB menu item in the status bar. Select the USB device to mount in the virtual machine.
:warning: USB devices
  • To prevent data corruption on USB devices always sync and unmount USB devices safely.
  • Do not transfer your mouse or keyboard.
  • Do not add filters for your USB devices.
6. MANJARO GUEST installation
Before installation ensure you are using VBoxSVGA graphics.
Graphic drivers are included are included in the kernel and Manjaro installer will use mhwd to install the kernel modules.
Install the guest utilities
$ sudo pacman -Syu virtualbox-guest-utils
7. OTHER LINUX GUEST installation
For best results, Linux as well as Windows guests needs the guest utilities installed. Prefer to use the ISO image provided as other Linux distributions might not have the most recent version of the utilities.
When you have installed the packages continue with Linux Guest Configuration or Windows Guest Configuration.
From the Devices menu of the VirtualBox Guest Window choose Insert Guest Additions CD Image…
:information_source: On some Linux systems it is required to open a terminal and execute the installer from CLI. Open a file manager, browse to the mounted ISO, use the file manager to launch a terminal then start the installer.
$ ./runasroot.sh
8. MANJARO GUEST Configuration
In the running guest - add the user to vboxsf group. The environment variable $USER translates to the current logged in user.
$ sudo gpasswd -a $USER vboxsf
Enable the vboxservice. The service loads the required modules when run.
$ sudo systemctl enable --now vboxservice
9. LINUX Shared folders
Shared folders requires extra configuration of host and guest. What needs to be done in the guest is a little different depending on the guest operation system. The following works for Manjaro.
Host Configuration
  • On the host locate the Settings section in VirtualBox GUI
  • Shared Folders tab
  • Add a shared folder
  • Select the Automount option
:information_source: Set the folders to Read-only if you plan to use Windows and want to browse insecure websites and other insecure activities. Doing so will prevent an eventual malware/ransomware from spreading to your host.
Guest mounting
Ensure your guest system user is member of vboxsf group.
$ groups
sys network power lp wheel $USER
After reboot you will need to mount the folders - please verify the folder /media exist - otherwise create it - but usually VirtualBox creates the folder.
$ sudo mkdir /media
Then use VBoxControl to mount the folders
$ sudo VBoxControl sharedfolder list --automount
The folders can be accessed using /media/sf_sharename
10. Troubleshooting screen issues
If you get issues setting the guest screen resolution, pay attention to the graphics driver selected for the virtual machine as noted by @Teek here and @sueridgepipe here.
Opaque windows
Open Kvantum Manager, select Configure Active Theme and navigate to Compositing & General Look.
Either activate the Disable composite effects or activate Translucent windows. Chosing the latter option please ensure VirtualBox and VirtualBoxVM is included in the list of Opaque apps.
Fullscreen
Changing to fullscreen using the hotkeys - default Right Ctrlf depends on
  • graphics driver - VBoxSVGA
  • Manjaro guest needs vboxservice enabled and running
    The resize of the screen sometimes takes 5-10 seconds to adapt but if it don’t adapt - use the hotkey to switch back and forth one (1) time.
Blurred - Distorted - Unreadable dialogs on Windows
If you use Windows and you have unreadable/blank dialogs - disable 3D/2D in the virtual machine graphics section.
If your virtual machine display does not resize correct
  1. Your guest is Manjaro
    • Ensure your graphics driver is VBoxSVGA before installing Manjaro
    • Ensure you have enabled the vboxservice
  2. Your guest is Ubuntu
    • Ensure you have the latest available drivers installed in the guest.
  3. Your guest is Windows
    • Try reinstalling the guest utils using the ISO image provided.
The following is not consistent but may depend on your graphics driver.
  • If you click on the vm window’s maximize button or drag using the lower right corner, the vm may not recieve notification on the change in window size. You can expand the window by dragging a border in either direction to have the vm resize correct. Your window size will remembered so you don’t have to do it every time.
11. WINDOWS GUEST Configuration
Insert the guest additions and run the installer in your Windows system.
Restart the guest to make the shared folders available using the Windows Explorer.
12. VirtualBox display issues
Should it be mhwd-kernel -li in the Installation part?
May I suggest another point to add to this section?
The version of the extension pack in the AUR is sometimes ahead of the version of virtualbox in Manjaro, so it’s best to check before installing.
I do it with these commands:
pikaur -S virtualbox-ext-oracle
Example:
[xxx]$ vboxmanage --version
6.1.14r140239
[xxx]$ pikaur -S virtualbox-ext-oracle
 virtualbox-ext-oracle                6.1.8-1       -> 6.1.14-1
EDIT: since I first wrote this post, linux-aarhus added this to his post:
virtualbox-ext-oracle-manjaro ...
Notice “virtualbox-ext-oracle-manjaro”.
Then I discovered that pikaur and yay can search too, eg :
$ pikaur -Ss virtualbox-ext-oracle
also brings up “virtualbox-ext-oracle-manjaro
If ‘virtualbox-ext-oracle-manjaro’ always has the right version,
then if you use it, the rest of this post is redundant.
While Manjaro was on 6.12, Arch and AUR were on 6.14,
so I did not install virtualbox-ext-oracle from AUR.
I did install it, this way:
Got the 6.12 ext pack from
https://www.virtualbox.org/wiki/Download_Old_Builds
then install it via
sudo vboxmanage extpack install --replace <name>.vbox-extpack
Actually, I did not myself use that command either, so i can’t guarantee that it works.
I found it only today, in https://forum.manjaro.org/t/unable-to-install-module-vboxhost-6-1-14-ose-for-kernel-5-4-64-1-manjaro-missing-kernel-headers/24504/4]
What I did use was the GUI, like this:
Open the GUI with sudo:
sudo /usr/lib/virtualbox/VirtualBox
then go into file > preferences > extensions, and it’s obvious what to do there.
Close that GUI, then open it the usual way (without sudo) before you try to use it.
