Of course, it may help if you supply your System Information:
inxi -zv8
Note that the output produced by this command is privacy-filtered.
Please also remember to use proper code formatting as this makes it much easier to read on the Forum:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks ```
or three tildes ~~~
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
Thanks, I saw similar info elsewhere. The trick is knowing if the kvm is needed or not. It seems that, for me, irqbypass and ccp use it.
Note that I’ve never seen this problem before, so I presume it was introduced by a recent update. I was hoping to get the answer without having to go through a reboot.
I added the boot parameter kvm.enable_virt_at_load=0, ran update-grub, and re-booted. No joy.
