This problem occurs randomly on startups.
I am using two monitors with my Manjaro KDE setup. The left monitor is a horizontal one, and the right monitor is a vertical one.
The monitor is properly set up as a vertical monitor in the settings. (Seen in picture #1 )
Occasionally, when Manjaro boots up, the right monitor will display horizontally, with the wallpaper cut off and artifacts (Seen in picture #2 ). Weirdly enough though, if I use the system screenshot tool, it displays properly. (Seen in picture #3 )
If I move my mouse on to the second monitor, I can see that the mouse works vertically, unlike what happens when a vertical monitor is set to horizontal in the settings.
If I right click and open the desktop menu, the menu is rotated, however it only reacts to hover events when my mouse moves to the corresponding vertical location of the screen (Seen in picture #4 ).
Thank you very much for your help.
Picture #1: https://i.imgur.com/58uinKP.png
Picture #2 (Notice how the wallpaper is rotated and cut off, while the bottom part of the screen contain artifacts): https://i.imgur.com/RUW5ubt.jpg
Picture #3 (Notice the right part of the screen - the second monitor displays properly in the screenshot app): https://i.imgur.com/Nkg8gSy.png
Picture #4 (Notice that the location of the cursor doesn’t match up with the displayed menu, instead it matches up with a “ghost” menu that will be displayed if the screen was functioning properly): https://i.imgur.com/j4SYR10.jpg
This issue can be temporarily fixed by rebooting for several times and restarting the monitor for several times.
The horizontal monitor is Dell P2419HC, and the vertical monitor is Dell U2414H.
The system information can be found below:
System: Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2
info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: Dell product: G3 3590 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 061RYD v: A00 serial: <filter> UEFI: Dell v: 1.10.0 date: 02/03/2020
Battery: ID-1: BAT0 charge: 51.0 Wh (100.0%) condition: 51.0/51.0 Wh (100.0%) volts: 12.3 min: 11.4 model: BYD DELL M4GWP9A
type: Li-poly serial: <filter> status: Full
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake note: check rev: A cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
9: 800 10: 800 11: 800 12: 800
Graphics: Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Dell driver: nvidia v: 465.31 bus-ID: 01:00.0
chip-ID: 10de:2191 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:3 chip-ID: 0c45:671f class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel,nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa resolution: 1: 1920x1080~60Hz 2: 1080x1920 s-dpi: 97
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3
chip-ID: 8086:a348 class-ID: 0401
Device-2: Elite Silicon USB Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4.4:6
chip-ID: 18c3:6255 class-ID: 0300
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000 bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: outline-tun0 state: up speed: 10 Mbps duplex: full mac: N/A
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus-ID: 1-14:8
Drives: Local Storage: total: 942.7 GiB used: 102.19 GiB (10.8%)
ID-1: /dev/nvme0n1 vendor: LITE-ON model: CAZ-82512-Q11 NVMe 512GB size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: 23201111 scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD5000LPLX-08ZNTT0 size: 465.76 GiB speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A04 scheme: GPT
Partition: ID-1: / size: 459.43 GiB used: 76.26 GiB (16.6%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 59.0 C mobo: N/A
Repos: Packages: 1495 pacman: 1480 flatpak: 7 snap: 8
Active pacman repo servers in: /etc/pacman.conf
1: https://download.opensuse.org/repositories/home:/ungoogled_chromium/Arch/$arch
1: https://manjaro.lucassymons.net/stable/$repo/$arch
2: https://mirror.init7.net/manjaro/stable/$repo/$arch
3: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
4: https://mirror.koddos.net/manjaro/stable/$repo/$arch
5: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
6: http://ftp.linux.org.tr/manjaro/stable/$repo/$arch
7: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
8: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
Info: Processes: 324 Uptime: 32m wakeups: 3 Memory: 19.35 GiB used: 4.22 GiB (21.8%) Init: systemd v: 248 Compilers:
gcc: 11.1.0 clang: 12.0.0 Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
Since posting this, I have upgraded to the 5.13 kernel, and this never happened again. These are the related information for anyone interested:
5.10 LTS: Still happens
5.13: Never happened yet
xrandr:
Screen 0: minimum 320 x 200, current 3000 x 1920, maximum 16384 x 16384
eDP-1 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.97 59.96 59.93 48.00
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-1-8 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00*+
1600x900 60.00
1280x1024 75.02 60.02
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
640x480 75.00 59.94
720x400 70.08
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 connected 1080x1920+1920+0 left (normal left inverted right x axis y axis) 530mm x 300mm
1920x1080 60.00 + 59.94 50.00*
1600x1200 60.00
1600x900 60.00
1280x720 60.00 59.94 50.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
1920x1080 (0x9a) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1600x900 (0x9b) 108.000MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
1280x1024 (0x9c) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x54) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1152x864 (0x9d) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1024x768 (0x9e) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x65) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x9f) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x74) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
640x480 (0xa0) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x81) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
inxi:
Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=222f70c6-6db3-4021-9feb-b40895ef9ea9 rw quiet apparmor=1
security=apparmor resume=UUID=9b20272f-a867-487e-ba02-6de6d30adaf0
udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 7
date: 02/03/2020
volts: 12.7 min: 11.4 model: BYD DELL M4GWP9A type: Li-poly serial: <filter>
status: Full
RAM: total: 19.34 GiB used: 4.96 GiB (25.7%)
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 12 MiB bogomips: 62431
Speed: 896 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 896 2: 899 3: 898
4: 900 5: 900 6: 900 7: 900 8: 900 9: 899 10: 896 11: 899 12: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
loaded: modesetting,nvidia unloaded: intel alternate: fbdev,nouveau,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3000x1920 s-dpi: 97 s-size: 788x504mm (31.0x19.8")
s-diag: 935mm (36.8")
Monitor-1: DP-1-8 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: HDMI-1-0 res: 1080x1920
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4.4:6 chip-ID: 18c3:6255
class-ID: 0300
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
IF-ID-1: mpqemubr0 state: down mac: <filter>
IF-ID-2: outline-tun0 state: up speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IF-ID-3: tap-4023f41d9e3 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:8 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 942.7 GiB used: 155.74 GiB (16.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: LITE-ON
model: CAZ-82512-Q11 NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 23201111 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPLX-08ZNTT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
used: 121.76 GiB (26.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 222f70c6-6db3-4021-9feb-b40895ef9ea9
used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: D7CE-1A39
ID-3: /run/media/dreta/Data raw-size: 465.49 GiB size: 457.19 GiB (98.22%)
used: 33.97 GiB (7.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Data
uuid: a2fd607c-346c-4bb0-a63f-d25419ed0c94
ID-1: swap-1 type: partition size: 8.8 GiB used: 3.2 MiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 9b20272f-a867-487e-ba02-6de6d30adaf0
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Hub-2: 1-4:2 info: Texas Instruments ports: 6 rev: 2.1 speed: 480 Mb/s
chip-ID: 0451:8442 class-ID: 0900
Hub-3: 1-4.3:15 info: Texas Instruments ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0451:8044 class-ID: 0900
Device-1: 1-4.3.2:16 info: MosArt Wireless Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:4102 class-ID: 0301
Device-2: 1-4.3.4:17 info: Holtek Noppoo Choc Mid type: Keyboard,HID
power: 100mA chip-ID: 04d9:1829 class-ID: 0300
Device-3: 1-4.4:6 info: Elite Silicon USB Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 500mA chip-ID: 18c3:6255 class-ID: 0300
Device-4: 1-4.5:9 info: Texas Instruments type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip-ID: 0451:82ff class-ID: 0300 serial: <filter>
Device-5: 1-5:3 info: Microdia Integrated_Webcam_HD type: Video
Device-6: 1-11:5 info: Alienware LED controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.1 speed: 12 Mb/s
chip-ID: 187c:0550 class-ID: 0300 serial: <filter>
Device-7: 1-14:8 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-4:2 info: Texas Instruments ports: 2 rev: 3.1 speed: 5 Gb/s
chip-ID: 0451:8440 class-ID: 0900
System Temperatures: cpu: 55.0 C mobo: N/A
Processes: 349 Uptime: 6h 54m wakeups: 17 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1569 apt: 0
pacman: 1556 lib: 429 flatpak: 0 snap: 13 Shell: fish v: 3.3.1
running-in: konsole inxi: 3.3.06
Monitor and graphic cards: I am not actually sure about this
Still, the problem is already fixed. Thank you very much for your help though!
Fabby
August 28, 2021, 9:28am
5
Fabby
August 28, 2021, 9:31am
6
One last piece of advice: You’re not on a Long Term Support kernel any more, as I’ve moved you to the fast track and you must keep installing newer Stable kernels as Stable kernels go EOL much faster than LTS ones.
Please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
Especially the section on kernels.
system
Closed
August 30, 2021, 11:32pm
7
