Version mismatch between pixman and lib32-pixman
Hi!
This thread is relevant to System freezing while playing Guild Wars 2 but I can’t reply there.
I have noticed that while pixman has been updated to version 0.43.0, its dependency lib32-pixman is still at 0.42.2-1.
In the Arch repos, both pixman and lib32-pixman are at version 0.43.0-1.
Since downgrading pixman to the version that matches the lib32-pixman version fixes the issue, I assume there might be a connection here.
Welcome to the forum! :wave:
Lib32 versions aren’t always updated at the same time. Since the lib64 and lib32 versions are unrelated, it makes no difference.
❯ pacman -Si pixman lib32-pixman | grep 'Build Date'
Build Date      : Thu 04 Jan 2024 05:38:10 AM MST
Build Date      : Sun 14 Jan 2024 01:04:07 PM MST
EDIT: Also, apparently it doesn’t make any difference using lib32-pixman 0.43.0-1:
Thank you for the quick reply!
Good to know that this isn’t the cause.
I guess I’ll just downgrade pixman for now and keep an eye on the issue tracker.
