@ Forum Members,
How to install and use Ventoy on a USB stick in Manjaro Xfce ?
- Does Ventoy need to be installed first using the software package manager ?
– would like a step by step explanation on how to make a multiboot usb then because I do not know the use of Manjaro and entering the correct commands in the terminal yet.
Thank you in advance for your understanding and patience.
Kind regards,
Klakke.
My system:
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Xfce 4.16.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: MEDION product: P6624 v: N/A serial: <filter>
Mobo: MEDION model: P6624 serial: <filter> BIOS: American Megatrends
v: 0.07 date: 08/20/2010
ID-1: BAT0 charge: 100.7 Wh (100.0%) condition: 100.7/63.4 Wh (159.0%)
volts: 16.7 min: 14.4 model: SANYO M10B1 status: Full
Info: Dual Core model: Intel Core i3 M 370 bits: 64 type: MT MCP
arch: Nehalem rev: 5 cache: L2: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19157
Speed: 1463 MHz min/max: 931/2394 MHz Core speeds (MHz): 1: 1463 2: 1331
3: 991 4: 1463
Device-1: Intel Core Processor Integrated Graphics vendor: Wistron
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GF108M [GeForce GT 425M] vendor: Wistron driver: nouveau
v: kernel bus-ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 21.2.1
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Wistron
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Device-1: Qualcomm Atheros AR8131 Gigabit Ethernet
vendor: Wistron Medion Akoya E7214 Notebook PC driver: atl1c v: kernel
port: d000 bus-ID: 03:00.0
Device-2: Realtek RTL8191SEvB Wireless LAN driver: rtl8192se v: kernel
port: c000 bus-ID: 05:00.0
IF: wlp5s0 state: up mac: <filter>
Local Storage: total: 232.89 GiB used: 18.54 GiB (8.0%)
ID-1: /dev/sda vendor: Fujitsu model: MHZ2250BH G2 size: 232.89 GiB
ID-1: / size: 228.17 GiB used: 18.54 GiB (8.1%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 52.0 C mobo: 41.0 C gpu: nouveau temp: 52.0 C
Processes: 187 Uptime: 15m Memory: 3.64 GiB used: 1.33 GiB (36.4%)
Init: systemd Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1325
Shell: Bash v: 5.1.8 inxi: 3.3.06]
