USB mouse does not work
Hello i use manjaro kde 515 lte on Lenovo yoga 910-13 x64.
When i plug mouse in it lights up but lsusb dont see it at all.
i already 2 month trying to do something with it but cant find anything what can help.
First i used 4.19 kernel also same
Hi @Merk, and welcome!
In order for us, or anyone really, to be of assistance, more information is required:
As much info as you can, really.
USB A devices has 4 connectors - two for power - two for the bus signal.
If the device is powered but the system doesn’t recognize the device - in your case a mouse - is defective. Perhaps only the cable where one of the signal wires is broken.
Or the system’s usb port is defective - have you tried a second port?
Two months without a mouse! Have you tried another mouse?
hello sure mouse and usb works. already tested it
mouse model destiny gm-918
Kernel: 5.15.71-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=9872a53c-50d5-404d-b545-3e530cbfc9ca rw quiet
cryptdevice=UUID=7325c159-f4fe-495e-ae2d-2bf9a9a10913:luks-7325c159-f4fe-495e-ae2d-2bf9a9a10913
root=/dev/mapper/luks-7325c159-f4fe-495e-ae2d-2bf9a9a10913 apparmor=1
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: LENOVO product: INVALID v: INVALID
serial: Chassis: type: 31 v: INVALID
serial:
Mobo: LENOVO model: VIUU4 v: SDK0K17763 WIN serial:
UEFI-[Legacy]: LENOVO v: 2JCN37WW date: 04/13/2017
ID-1: BAT1 charge: 34.5 Wh (58.2%) condition: 59.3/78.0 Wh (76.0%)
volts: 7.4 min: 7.7 model: Simplo BASE-BAT type: Li-poly serial:
status: discharging
RAM: total: 15.37 GiB used: 4.72 GiB (30.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 9 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 900 min/max: 400/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 23209
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-1:2
chip-ID: 5986:2104 class-ID: 0e02
Display: x11 server: X. Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: eDP-1 model: LG Display 0x051e built: 2016 res: 3840x2160
hz: 60 dpi: 316 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 3840x2160
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.71-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.58 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp1s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-8:4 chip-ID: 0cf3:e300 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Device-1: luks-7325c159-f4fe-495e-ae2d-2bf9a9a10913 maj-min: 254:0
type: LUKS dm: dm-0 size: 237.68 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 237.69 GiB
Local Storage: total: 238.47 GiB used: 127.57 GiB (53.5%)
ID-1: / dev /nvme0n1 maj-min: 259:0 vendor: Samsung
model: MZVLV256HCHP-000L2 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: 5L0QBXV7 temp: 39.9 C scheme: MBR
ID-1: / raw-size: 237.68 GiB size: 232.89 GiB (97.98%) used: 127.57 GiB
(54.8%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-7325c159-f4fe-495e-ae2d-2bf9a9a10913 label: N/A
uuid: 9872a53c-50d5-404d-b545-3e530cbfc9ca
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 800 MiB fs: ext4 label: N/A
uuid: ce2ee13c-fd45-474f-8055-5c998c696a21
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Acer EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:2104
class-ID: 0e02
Device-2: 1-5:3 info: Validity Sensors type: driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 138a:0094
class-ID: ff00 serial:
Device-3: 1-8:4 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0cf3:e300 class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 50.0 C pch: 45.0 C mobo: N/A
Processes: 189 Uptime: 15m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1518 libs: 445 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
sure bro
[ 0.335842] usbcore: registered new interface driver usbfs
[ 0.335842] usbcore: registered new interface driver hub
[ 0.335842] usbcore: registered new device driver usb
[ 0.443222] usbcore: registered new interface driver usbserial_generic
[ 0.443228] usbserial: USB Serial support registered for generic
[ 0.837582] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.837586] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.837589] usb usb1: Product: xHCI Host Controller
[ 0.837593] usb usb1: Manufacturer: Linux 5.15.71-1-MANJARO xhci-hcd
[ 0.837594] usb usb1: SerialNumber: 0000:00:14.0
[ 0.839784] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 0.839787] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.839789] usb usb2: Product: xHCI Host Controller
[ 0.839790] usb usb2: Manufacturer: Linux 5.15.71-1-MANJARO xhci-hcd
[ 0.839792] usb usb2: SerialNumber: 0000:00:14.0
[ 0.840542] usb: port power management may be unreliable
[ 1.088564] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.238485] usb 1-1: New USB device found, idVendor=5986, idProduct=2104, bcdDevice=53.08
[ 1.238488] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.238489] usb 1-1: Product: EasyCamera
[ 1.238490] usb 1-1: Manufacturer: SunplusIT Inc
[ 1.361892] usb 1-5: new full-speed USB device number 3 using xhci_hcd
[ 1.503404] usb 1-5: New USB device found, idVendor=138a, idProduct=0094, bcdDevice= 1.64
[ 1.503408] usb 1-5: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 1.503410] usb 1-5: SerialNumber: a4ab84ed5474
[ 1.625224] usb 1-8: new full-speed USB device number 4 using xhci_hcd
[ 1.766477] usb 1-8: New USB device found, idVendor=0cf3, idProduct=e300, bcdDevice= 0.01
[ 1.766480] usb 1-8: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.642315] usbcore: registered new interface driver btusb
[ 8.644580] usb 1-1: Found UVC 1.00 device EasyCamera (5986:2104)
[ 8.647237] Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
[ 8.665977] input: EasyCamera: EasyCamera as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/input/input17
[ 8.666436] usbcore: registered new interface driver uvcvideo
[ 9.007578] Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
[ 1480.886452] usb 1-7: new low-speed USB device number 5 using xhci_hcd
[ 1481.012942] usb 1-7: device descriptor read/64, error -71
[ 1481.246570] usb 1-7: device descriptor read/64, error -71
[ 1481.476557] usb 1-7: new low-speed USB device number 6 using xhci_hcd
[ 1481.603275] usb 1-7: device descriptor read/64, error -71
[ 1481.836644] usb 1-7: device descriptor read/64, error -71
[ 1481.943301] usb usb1-port7: attempt power cycle
[ 1482.346525] usb 1-7: new low-speed USB device number 7 using xhci_hcd
[ 1482.348100] usb 1-7: Device not responding to setup address.
[ 1482.553765] usb 1-7: Device not responding to setup address.
[ 1482.759849] usb 1-7: device not accepting address 7, error -71
[ 1482.883054] usb 1-7: new low-speed USB device number 8 using xhci_hcd
[ 1482.883761] usb 1-7: Device not responding to setup address.
[ 1483.090931] usb 1-7: Device not responding to setup address.
[ 1483.296493] usb 1-7: device not accepting address 8, error -71
[ 1483.296720] usb usb1-port7: unable to enumerate USB device
Providing terminal output
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
Please edit your posts accordingly.
Edit:
Welp…
I’ve gone through all these:
…and I couldn’t find the mouse. So, maybe I’m wrong, but it looks to me like a defective device. Otherwise a defective USB port.
and it worked? seems like this is just a defective mouse.
BOTH usb and mouse working as i said 3 times already guys
How many times you’ve said it doesn’t change this fact:
