USB Headset microphone floating bug: sound disappears every 2sec-15min
Hi there!
I’ve been having floating bug related to microphone for something like 2 years already :slight_smile:
Main problem statement
When I use microphone from my headset for something like 5sec - 15min it can stop working with no reason.
Workaround
If I will open pavucontrol and change profile for my headset – it will start work (again for some time).
My circles of hell
  • This behavior was with me from kernel 5.10.* to 5.15.85. I haven’t noticed any improvements or regressions during this time, I was just writing pacman -Syya every ~1 month in the hope that it will go away by itself :slight_smile:
  • I tried pulseaudio and pipewire. Problem remains on both of sound servers, and hack with changing profiles (in same pavucontrol) works on both backends… Probably with pipewire this bug is even crazier, microphone “crashes” every 10sec-2min, so I came back to pulseaudio.
  • Problem reproduces in any app that uses micrphone: google-chrome-stable (google meet, mic test, …); teams-for-linux; discord; intellij-idea (yep, there is an ability to have a call); slack; you_can_put_any_other_app :).
  • Microphone doesn’t disappear from system or smth like that, it visible by pulseaudion and by applications, it just doesnt provide any sound.
  • Microphone works perfectly in Windows (10 & 11).
  • I found some better experience when I switched to another machine (with same distro of Manjaro), it still was crashing but super rare (1-2 times per month)… but I back to my machine… and I tried to reinstall Manjaro – the problem remains and crashes are not rare.
  • I listen music (using google-chrome) 24/7, sometimes (every 10-30 minutes) I can hear that sound in my headphones, “cracks” or smth like that, just for 1 second. It’s not correlating with microphone problem, but as far as it’s the same USB headset (mic+headphones) – can be related. Also when I open pavucontrol sound disappears for 1-2 seconds and then appears as nothing happened.
  • If sound from microphone disappeared – I can just open pavucontrol and change profile of my headset from Analog stereo duplex to Analog stereo Output + Digital stereo (IEC958) Input and it will work… It doesn’t really matter what profile you will choose (you just need to change profile from current to anything else), I used Digital stereo duplex (IEC958) for long time, switched to Analog because sound is louder. Btw, headphones works with:
    • Analog stereo duplex
    • Digital stereo duplex (IEC958)
    • Analog stereo input + Digital stereo output (IEC958)
    • Analog stereo output + Digital stereo input (IEC958)
    • probably other profiles, haven’t tested to be honest.
  • I tried to change USB ports… no changes.
  • I tried to install some roccat software & even rebuild it from sources – nothing.
  • I don’t want to throw away the headphones… although sometimes they seem to be a problem of my nervousness :slight_smile:
  • Nothing interesting, when bug appears, in journalctl, dmesg, …
  • I have read that someone has problems with USB mic.. and reason was in conflicting between USB devices, so I will provide everything.
I don’t know where to dig, what is the root cause… To be honest, Im not too good in linux internals and what is going on with sound sub-system in linux. I will try to provide as many information as I can, if you will need something to debug – kindly ask me, I will do anything to overcome this problem.
Hardware info
  • CPU: i7-5930k
  • GPU: gtx980ti (nvidia proprietary drivers)
  • Motherboard: Asus X99-deluxe/U3.1
  • RAM: 16GB, Gskill …
  • SSD+HDD (980pro + seagate …)
  • Headphones: Roccat khan aimo
  • Keyboard: ducky shine 7
  • Mouse: Roccat kone pure ultra
  • Webcam: razer kiyo pro
    No USB hubs or smth like that – everything plugged directly in motherboard’s ports.
Software info
Software info provided after ~3 hours of work, and this bug already appeared couple of times (6-8 times).
uname-a
[xionix@xio ~]$ uname -a
Linux xio 5.15.85-1-MANJARO #1 SMP PREEMPT Wed Dec 21 21:15:06 UTC 2022 x86_64 GNU/Linux
lsusb
[xionix@xio ~]$ lsusb
Bus 002 Device 002: ID 8087:8002 Intel Corp. 8 channel internal hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 002: ID 1e7d:2dd2 ROCCAT ROCCAT Kone Pure Ultra
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:800a Intel Corp. Hub
Bus 004 Device 009: ID 1532:0e05 Razer USA, Ltd Razer Kiyo Pro
Bus 004 Device 004: ID 174c:3074 ASMedia Technology Inc. ASM1074 SuperSpeed hub
Bus 004 Device 003: ID 174c:3074 ASMedia Technology Inc. ASM1074 SuperSpeed hub
Bus 004 Device 002: ID 13fe:5500 Kingston Technology Company Inc. Flash drive
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 008: ID 04d9:0348 Holtek Semiconductor, Inc. Keyboard
Bus 003 Device 011: ID 2109:8883 VIA Labs, Inc. USB Billboard Device
Bus 003 Device 012: ID 048d:8295 Integrated Technology Express, Inc. ITE Device(8595)
Bus 003 Device 009: ID 0d8c:01c2 C-Media Electronics, Inc. USB Advanced Audio Device
Bus 003 Device 007: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
Bus 003 Device 005: ID 174c:2074 ASMedia Technology Inc. ASM1074 High-Speed hub
Bus 003 Device 004: ID 1b1c:1c07 Corsair HX1000i Power Supply
Bus 003 Device 003: ID 1b1c:0c04 Corsair Link Cooling Node
Bus 003 Device 002: ID 0b05:180a ASUSTek Computer, Inc. Broadcom BCM20702 Single-Chip Bluetooth 4.0 + LE
Bus 003 Device 013: ID 1e7d:39d0 ROCCAT ROCCAT Khan AIMO
Bus 003 Device 006: ID 174c:2074 ASMedia Technology Inc. ASM1074 High-Speed hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
inxi -Fazy
  Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=e5af83ea-4181-4bea-906c-9dfa3682ca01 rw quiet apparmor=1
    security=apparmor resume=UUID=ef52a209-aacb-400a-a5a3-e24396a9c5a2
    udev.log_priority=3
  Desktop: i3 v: 4.21.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: ASUS product: All Series v: N/A
    serial: <superuser required>
  Mobo: ASUSTeK model: X99-DELUXE v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 3301 date: 06/28/2016
  Info: model: Intel Core i7-5930K bits: 64 type: MT MCP arch: Haswell
    gen: core 5 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3F (63) stepping: 2 microcode: 0x49
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 15 MiB desc: 1x15 MiB
  Speed (MHz): avg: 1939 high: 4105 min/max: 1200/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1779 2: 1908 3: 1500
    4: 1500 5: 1505 6: 1501 7: 4105 8: 3470 9: 1502 10: 1500 11: 1504 12: 1500
    bogomips: 99036
    vulnerable
    prctl and seccomp
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] vendor: ASUSTeK driver: nvidia
    v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2022-12) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:17c8
    class-ID: 0300
  Device-2: Razer USA Kiyo Pro type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 4-6.4:9 chip-ID: 1532:0e05 class-ID: 0102
  Display: x11 server: X.Org v: 21.1.6 compositor: Picom v: git-b700a
    driver: N/A display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 92 s-size: 1237x402mm (48.70x15.83")
    s-diag: 1301mm (51.21")
  Monitor-1: DP-0 pos: primary,top-left res: 2560x1440 dpi: 107
    size: 609x355mm (23.98x13.98") diag: 705mm (27.75") modes: N/A
  Monitor-2: DP-2 pos: bottom-r res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel C610/X99 series HD Audio vendor: ASUSTeK
    driver: snd_hda_intel bus-ID: 3-10.3:13 v: kernel bus-ID: 00:1b.0
    chip-ID: 1e7d:39d0 chip-ID: 8086:8d20 class-ID: 0300 class-ID: 0403
  Device-2: NVIDIA GM200 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb0
    class-ID: 0403
  Device-3: ROCCAT Khan AIMO type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Device-4: C-Media USB Advanced Audio Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-9.1.1:9 chip-ID: 0d8c:01c2
    class-ID: 0300
  Device-5: Razer USA Kiyo Pro type: USB driver: snd-usb-audio,uvcvideo
  Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.63 running: no
  Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel
    port: f000 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
  Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 08:00.0
  IF: enp8s0 state: down mac: <filter>
  Device-3: Broadcom BCM4360 802.11ac Wireless Network Adapter
    vendor: ASUSTeK driver: wl v: kernel modules: bcma pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 14e4:43a0 class-ID: 0280
  IF: wlp9s0 state: dormant mac: <filter>
  Device-1: ASUSTek Broadcom BCM20702 Single-Chip Bluetooth 4.0 + LE type: USB
    driver: btusb v: 0.8 bus-ID: 3-6:2 chip-ID: 0b05:180a class-ID: fe01
    serial: <filter>
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
    bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
  Supported mdraid levels: raid0
  Device-1: md126 maj-min: 9:126 type: mdraid level: raid-0 status: active
  Info: report: N/A blocks: 3907023872 chunk-size: 16k
  Components: Online:
  0: sda maj-min: 8:0 size: 1.82 TiB
  1: sdb maj-min: 8:16 size: 1.82 TiB
  Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
  Info: report: N/A blocks: 5296 chunk-size: N/A
  Components: Online: N/A Spare:
  0: sdb maj-min: 8:16 size: 1.82 TiB state: S
  1: sda maj-min: 8:0 size: 1.82 TiB state: S
  Local Storage: total: raw: 3.93 TiB usable: 296.2 GiB used: 22.12 GiB (7.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVPV256HDGL-00000
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: BXW7300Q temp: 42.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000NM0033-9ZM175
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: SN06
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000NM0033-9ZM175
  ID-4: /dev/sdc maj-min: 8:32 type: USB model: USB DISK 3.0 size: 57.73 GiB
    block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
    rev: DL07 scheme: MBR
  ID-1: / raw-size: 114.97 GiB size: 112.61 GiB (97.94%) used: 13.9 GiB (12.3%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-3: /home raw-size: 1024 GiB size: 1006.86 GiB (98.33%)
    used: 8.22 GiB (0.8%) fs: ext4 dev: /dev/md126p1 maj-min: 259:7
  ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p5 maj-min: 259:5
  System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 61 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
  Processes: 297 Uptime: 4h 51m wakeups: 0 Memory: 15.54 GiB
  used: 3.42 GiB (22.0%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1153
  pm: pacman pkgs: 1142 libs: 295 tools: pamac,yay pm: snap pkgs: 11
  Shell: Bash v: 5.1.16 running-in: urxvtd inxi: 3.3.24
lspci -k
[xionix@xio manjaro-roccat-suicide]$ lspci -k
00:00.0 Host bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DMI2 (rev 02)
	Subsystem: Intel Corporation Device 0000
00:01.0 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 (rev 02)
	Kernel driver in use: pcieport
00:01.1 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 1 (rev 02)
00:02.0 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 2 (rev 02)
	DeviceName:  Onboard IGD
00:03.0 PCI bridge: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCI Express Root Port 3 (rev 02)
00:05.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Address Map, VTd_Misc, System Management (rev 02)
00:05.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Hot Plug (rev 02)
00:05.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 RAS, Control Status and Global Errors (rev 02)
00:05.4 PIC: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 I/O APIC (rev 02)
00:11.0 Unassigned class [ff00]: Intel Corporation C610/X99 series chipset SPSR (rev 05)
	Subsystem: ASUSTeK Computer Inc. Device 8600
00:14.0 USB controller: Intel Corporation C610/X99 series chipset USB xHCI Host Controller (rev 05)
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation C610/X99 series chipset MEI Controller #1 (rev 05)
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection (2) I218-V (rev 05)
	DeviceName:  Onboard LAN
	Subsystem: ASUSTeK Computer Inc. Device 85c4
	Kernel driver in use: e1000e
	Kernel modules: e1000e
00:1a.0 USB controller: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #2 (rev 05)
	Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation C610/X99 series chipset HD Audio Controller (rev 05)
	Subsystem: ASUSTeK Computer Inc. Device 8637
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port #1 (rev d5)
00:1c.3 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port #4 (rev d5)
00:1c.4 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port #5 (rev d5)
00:1c.6 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port #7 (rev d5)
00:1d.0 USB controller: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation C610/X99 series chipset LPC Controller (rev 05)
	Kernel driver in use: lpc_ich
	Kernel modules: lpc_ich
00:1f.2 RAID bus controller: Intel Corporation SATA Controller [RAID mode] (rev 05)
	Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation C610/X99 series chipset SMBus Controller (rev 05)
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation GM200 [GeForce GTX 980 Ti] (rev a1)
	Subsystem: ASUSTeK Computer Inc. Device 855c
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GM200 High Definition Audio (rev a1)
02:00.0 USB controller: ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller
	Subsystem: ASUSTeK Computer Inc. Device 8696
03:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM951/PM951 (rev 01)
	Subsystem: Samsung Electronics Co Ltd PM963 2.5" NVMe PCIe SSD
	Kernel driver in use: nvme
06:00.0 PCI bridge: ASMedia Technology Inc. Device 118f
	Subsystem: ASMedia Technology Inc. Device 118f
07:01.0 PCI bridge: ASMedia Technology Inc. Device 118f
07:02.0 PCI bridge: ASMedia Technology Inc. Device 118f
07:03.0 PCI bridge: ASMedia Technology Inc. Device 118f
07:04.0 PCI bridge: ASMedia Technology Inc. Device 118f
08:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
	Subsystem: ASUSTeK Computer Inc. Device 85f0
	Kernel driver in use: igb
	Kernel modules: igb
09:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter (rev 03)
	Subsystem: ASUSTeK Computer Inc. Device 8659
	Kernel driver in use: wl
	Kernel modules: bcma, wl
0c:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
	Subsystem: ASUSTeK Computer Inc. Device 85e2
0d:00.0 USB controller: ASMedia Technology Inc. ASM1042A USB 3.0 Host Controller
	Subsystem: ASUSTeK Computer Inc. Device 85fd
ff:0b.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring
ff:0b.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 02)
	Kernel driver in use: hswep_uncore
ff:0b.2 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 R3 QPI Link 0 & 1 Monitoring (rev 02)
ff:0c.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers
ff:0c.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
ff:0c.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
ff:0c.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
ff:0c.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
ff:0c.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Unicast Registers (rev 02)
ff:0f.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Buffered Ring Agent (rev 02)
ff:0f.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Buffered Ring Agent (rev 02)
ff:0f.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers (rev 02)
	Subsystem: Intel Corporation Device 2fe0
ff:0f.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers (rev 02)
ff:0f.6 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 System Address Decoder & Broadcast Registers (rev 02)
ff:10.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface
ff:10.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 PCIe Ring Interface (rev 02)
ff:10.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers
ff:10.6 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers (rev 02)
ff:10.7 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Scratchpad & Semaphore Registers (rev 02)
ff:12.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0
ff:12.1 Performance counters: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Home Agent 0 (rev 02)
ff:13.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers
ff:13.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Target Address, Thermal & RAS Registers (rev 02)
ff:13.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder
ff:13.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder (rev 02)
ff:13.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder (rev 02)
ff:13.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder (rev 02)
ff:13.6 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Channel 0/1 Broadcast (rev 02)
ff:13.7 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Global Broadcast (rev 02)
ff:14.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 Thermal Control (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 Thermal Control
ff:14.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 Thermal Control (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 Thermal Control
ff:14.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 ERROR Registers (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 0 ERROR Registers
ff:14.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 ERROR Registers (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 1 ERROR Registers
ff:14.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 (rev 02)
ff:14.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 (rev 02)
ff:14.6 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 (rev 02)
ff:14.7 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 0 & 1 (rev 02)
ff:15.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 Thermal Control (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 Thermal Control
ff:15.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 Thermal Control (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 Thermal Control
ff:15.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 ERROR Registers (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 2 ERROR Registers
ff:15.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 ERROR Registers (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 0 Channel 3 ERROR Registers
ff:16.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 1 Target Address, Thermal & RAS Registers (rev 02)
ff:16.6 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Channel 2/3 Broadcast (rev 02)
ff:16.7 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO Global Broadcast (rev 02)
ff:17.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Integrated Memory Controller 1 Channel 0 Thermal Control (rev 02)
ff:17.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 (rev 02)
ff:17.5 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 (rev 02)
ff:17.6 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 (rev 02)
ff:17.7 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 DDRIO (VMSE) 2 & 3 (rev 02)
ff:1e.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit (rev 02)
	Subsystem: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit
ff:1e.1 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit (rev 02)
ff:1e.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit (rev 02)
ff:1e.3 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit (rev 02)
ff:1e.4 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 Power Control Unit (rev 02)
ff:1f.0 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 VCU (rev 02)
ff:1f.2 System peripheral: Intel Corporation Xeon E7 v3/Xeon E5 v3/Core i7 VCU (rev 02)
pacmd list-sources
[xionix@xio manjaro-roccat-suicide]$ pacmd list-sources
7 source(s) available.
    index: 0
	driver: <module-alsa-card.c>
	flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 1030
	volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	base volume: 65536 / 100% / 0.00 dB
	volume steps: 65537
	muted: no
	current latency: 0.00 ms
	max rewind: 0 KiB
	sample spec: s16le 2ch 44100Hz
	channel map: front-left,front-right
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 0.00 ms; range is 0.50 .. 1999.82 ms
	monitor_of: 0
	card: 0 <alsa_card.pci-0000_01_00.1>
	module: 6
	properties:
		device.description = "Monitor of GM200 High Definition Audio Digital Stereo (HDMI)"
		device.class = "monitor"
		alsa.card = "1"
		alsa.card_name = "HDA NVidia"
		alsa.long_card_name = "HDA NVidia at 0xfb080000 irq 75"
		device.bus_path = "pci-0000:01:00.1"
		sysfs.path = "/devices/pci0000:00/0000:00:03.0/0000:01:00.1/sound/card1"
		device.bus = "pci"
		device.vendor.id = "10de"
		device.vendor.name = "NVIDIA Corporation"
		device.product.id = "0fb0"
		device.product.name = "GM200 High Definition Audio"
		device.string = "1"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
    index: 1
	name: <alsa_output.usb-C-Media_Electronics_Inc._USB_Advanced_Audio_Device-00.analog-stereo.monitor>
	state: SUSPENDED
	suspend cause: IDLE
	priority: 1040
	        balance 0.00
	volume steps: 65537
	muted: no
	max rewind: 0 KiB
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
	monitor_of: 1
	card: 1 <alsa_card.usb-C-Media_Electronics_Inc._USB_Advanced_Audio_Device-00>
	module: 7
	properties:
		device.description = "Monitor of USB Advanced Audio Device Analog Stereo"
		alsa.card = "2"
		alsa.card_name = "USB Advanced Audio Device"
		alsa.long_card_name = "C-Media Electronics Inc. USB Advanced Audio Device at usb-0000:00:14.0-9.1.1, f"
		alsa.driver_name = "snd_usb_audio"
		device.bus_path = "pci-0000:00:14.0-usb-0:9.1.1:1.0"
		sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9.1/3-9.1.1/3-9.1.1:1.0/sound/card2"
		udev.id = "usb-C-Media_Electronics_Inc._USB_Advanced_Audio_Device-00"
		device.bus = "usb"
		device.vendor.id = "0d8c"
		device.vendor.name = "C-Media Electronics, Inc."
		device.product.id = "01c2"
		device.product.name = "USB Advanced Audio Device"
		device.serial = "C-Media_Electronics_Inc._USB_Advanced_Audio_Device"
		device.string = "2"
		device.icon_name = "audio-card-usb"
    index: 5
	state: SUSPENDED
	suspend cause: IDLE
	priority: 1030
	        balance 0.00
	volume steps: 65537
	muted: no
	max rewind: 0 KiB
	             Stereo
	used by: 0
	linked by: 0
	monitor_of: 3
	card: 3 <alsa_card.pci-0000_00_1b.0>
	module: 9
	properties:
		device.description = "Monitor of Built-in Audio Digital Stereo (IEC958)"
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xfbb30000 irq 74"
		device.bus_path = "pci-0000:00:1b.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "8d20"
		device.product.name = "C610/X99 series chipset HD Audio Controller"
		device.string = "0"
  * index: 14
	flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9049
	        balance 0.00
	base volume: 20724 /  32% / -30.00 dB
	volume steps: 65537
	muted: no
	max rewind: 0 KiB
	sample spec: s16le 2ch 48000Hz
	             Stereo
	used by: 0
	linked by: 0
	card: 4 <alsa_card.usb-Razer_Inc_Razer_Kiyo_Pro-02>
	module: 26
	properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "USB Audio"
		alsa.id = "USB Audio"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "4"
		alsa.card_name = "Razer Kiyo Pro"
		alsa.long_card_name = "Razer Inc Razer Kiyo Pro at usb-0000:00:14.0-6.4, super speed"
		device.bus_path = "pci-0000:00:14.0-usb-0:6.4:1.2"
		sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb4/4-6/4-6.4/4-6.4:1.2/sound/card4"
		udev.id = "usb-Razer_Inc_Razer_Kiyo_Pro-02"
		device.bus = "usb"
		device.vendor.id = "1532"
		device.vendor.name = "Razer USA, Ltd"
		device.product.id = "0e05"
		device.product.name = "Razer Kiyo Pro"
		device.serial = "Razer_Inc_Razer_Kiyo_Pro"
		device.form_factor = "webcam"
		device.string = "front:4"
		device.buffering.buffer_size = "384000"
		device.buffering.fragment_size = "192000"
		device.access_mode = "mmap+timer"
		device.profile.name = "analog-stereo"
		device.profile.description = "Analog Stereo"
		device.description = "Razer Kiyo Pro Analog Stereo"
		device.icon_name = "camera-web-usb"
	ports:
		analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: unknown)
			properties:
	active port: <analog-input-mic>
    index: 20
	state: IDLE
	suspend cause: (none)
	priority: 1040
	        balance 0.00
	volume steps: 65537
	muted: no
	max rewind: 4 KiB
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 2000.00 ms; range is 26.00 .. 2000.00 ms
	monitor_of: 7
	card: 5 <alsa_card.usb-ROCCAT_ROCCAT_Khan_AIMO-00>
	module: 27
	properties:
		device.description = "Monitor of ROCCAT Khan AIMO Analog Stereo"
		alsa.card = "3"
		alsa.card_name = "ROCCAT Khan AIMO"
		alsa.long_card_name = "ROCCAT ROCCAT Khan AIMO at usb-0000:00:14.0-10.3, full speed"
		device.bus_path = "pci-0000:00:14.0-usb-0:10.3:1.0"
		sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10.3/3-10.3:1.0/sound/card3"
		udev.id = "usb-ROCCAT_ROCCAT_Khan_AIMO-00"
		device.bus = "usb"
		device.vendor.id = "1e7d"
		device.vendor.name = "ROCCAT"
		device.product.id = "39d0"
		device.product.name = "ROCCAT Khan AIMO"
		device.serial = "ROCCAT_ROCCAT_Khan_AIMO"
		device.string = "3"
    index: 23
	name: <alsa_input.usb-C-Media_Electronics_Inc._USB_Advanced_Audio_Device-00.analog-stereo>
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9049
	        balance 0.00
	base volume: 30419 /  46% / -20.00 dB
	volume steps: 65537
	muted: no
	max rewind: 0 KiB
	sample spec: s16le 2ch 16000Hz
	             Stereo
	used by: 0
	linked by: 0
	module: 7
	properties:
		device.api = "alsa"
		alsa.device = "0"
		alsa.card = "2"
		device.bus = "usb"
		device.string = "front:2"
		device.buffering.buffer_size = "128000"
		device.buffering.fragment_size = "64000"
		device.description = "USB Advanced Audio Device Analog Stereo"
	ports:
			properties:
    index: 31
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9049
	volume: front-left: 49858 /  76% / -7.12 dB,   front-right: 49858 /  76% / -7.12 dB
	        balance 0.00
	volume steps: 65537
	muted: no
	max rewind: 0 KiB
	             Stereo
	used by: 0
	linked by: 0
	module: 27
	properties:
		device.api = "alsa"
		alsa.device = "0"
		alsa.card = "3"
		device.bus = "usb"
		device.string = "front:3"
		device.buffering.buffer_size = "352800"
		device.buffering.fragment_size = "176400"
		device.description = "ROCCAT Khan AIMO Analog Stereo"
	ports:
			properties:
pacmd list-sinks
xionix@xio manjaro-roccat-suicide]$ pacmd list-sinks
4 sink(s) available.
    index: 0
	flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9030
	        balance 0.00
	volume steps: 65537
	muted: no
	max request: 0 KiB
	max rewind: 0 KiB
	monitor source: 0
	             Stereo
	used by: 0
	linked by: 0
	module: 6
	properties:
		device.api = "alsa"
		alsa.name = "AORUS AD27QD"
		alsa.id = "HDMI 0"
		alsa.device = "3"
		alsa.card = "1"
		device.bus = "pci"
		device.string = "hdmi:1"
		device.buffering.buffer_size = "352768"
		device.buffering.fragment_size = "176384"
		device.profile.name = "hdmi-stereo"
		device.profile.description = "Digital Stereo (HDMI)"
		device.description = "GM200 High Definition Audio Digital Stereo (HDMI)"
	ports:
		hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
			properties:
				device.product.name = "AORUS AD27QD
	active port: <hdmi-output-0>
    index: 1
	name: <alsa_output.usb-C-Media_Electronics_Inc._USB_Advanced_Audio_Device-00.analog-stereo>
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9049
	volume: front-left: 43519 /  66% / -10.67 dB,   front-right: 43519 /  66% / -10.67 dB
	        balance 0.00
	volume steps: 65537
	muted: no
	max request: 0 KiB
	max rewind: 0 KiB
	monitor source: 1
	             Stereo
	used by: 0
	linked by: 0
	module: 7
	properties:
		device.api = "alsa"
		alsa.device = "0"
		alsa.card = "2"
		device.bus = "usb"
	ports:
		analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
			properties:
	active port: <analog-output>
    index: 3
	flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9037
	        balance 0.00
	volume steps: 65537
	muted: no
	max request: 0 KiB
	max rewind: 0 KiB
	monitor source: 5
	             Stereo
	used by: 0
	linked by: 0
	module: 9
	properties:
		device.api = "alsa"
		alsa.name = "ALC1150 Digital"
		alsa.id = "ALC1150 Digital"
		alsa.device = "1"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "iec958:0"
		device.profile.name = "iec958-stereo"
		device.profile.description = "Digital Stereo (IEC958)"
		device.description = "Built-in Audio Digital Stereo (IEC958)"
	ports:
		iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
			properties:
	active port: <iec958-stereo-output>
  * index: 7
	flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL LATENCY DYNAMIC_LATENCY
	state: RUNNING
	priority: 9049
	volume: front-left: 29387 /  45%,   front-right: 29387 /  45%
	        balance 0.00
	volume steps: 39
	muted: no
	current latency: 41.48 ms
	max request: 4 KiB
	max rewind: 4 KiB
	monitor source: 20
	             Stereo
	used by: 1
	linked by: 1
	configured latency: 26.00 ms; range is 26.00 .. 2000.00 ms
	module: 27
	properties:
		device.api = "alsa"
		alsa.device = "0"
		alsa.card = "3"
		device.bus = "usb"
	ports:
		analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
			properties:
	active port: <analog-output-speaker>
journalctl & dmesg
Here is everything from system startup :slight_smile:
https://github.com/dmkulazhenko/manjaro-roccat-suicide
Looking forward for ur help guys! <3
can you report
pacman -Ss manjaro-alsa
pacman -Ss manjaro-pipewire
pacman -Ss manjaro-pulseaudio
see also
pacman -Si manjaro-alsa
pacman -Si manjaro-pipewire
pacman -Si manjaro-pulseaudio
Here it is…
[xionix@xio manjaro-roccat-suicide]$ pacman -Ss manjaro-alsa
extra/manjaro-alsa 20221002-1 [installed]
    Manjaro meta package for complete ALSA support
[xionix@xio manjaro-roccat-suicide]$ pacman -Ss manjaro-pipewire
extra/manjaro-pipewire 20221015-2
    Manjaro meta package for complete PipeWire support.
[xionix@xio manjaro-roccat-suicide]$ pacman -Ss manjaro-pulseaudio
extra/manjaro-pulse 20221015-2 [installed]
    Manjaro meta package for complete PulseAudio support
[xionix@xio manjaro-roccat-suicide]$ pacman -Si manjaro-alsa
Repository      : extra
Version         : 20221002-1
Description     : Manjaro meta package for complete ALSA support
Architecture    : any
URL             : https://wiki.archlinux.org/index.php/Advanced_Linux_Sound_Architecture
Licenses        : GPL
Groups          : None
Provides        : None
Depends On      : alsa-firmware  alsa-lib  alsa-oss  alsa-plugins  alsa-utils
Optional Deps   : alsa-tools: Advanced tools for certain sound cards
                  pipewire-alsa: PipeWire support
                  pulseaudio-alsa: PulseAudio support
Conflicts With  : None
Replaces        : None
Download Size   : 17.79 KiB
Installed Size  : 0.00 KiB
Packager        : Mark Wagie <mark@manjaro.org>
Build Date      : Sun 02 Oct 2022 10:17:20 PM +03
Validated By    : MD5 Sum  SHA-256 Sum  Signature
[xionix@xio manjaro-roccat-suicide]$ pacman -Si manjaro-pipewire
Repository      : extra
Version         : 20221015-2
Description     : Manjaro meta package for complete PipeWire support.
Architecture    : any
URL             : https://wiki.archlinux.org/title/PipeWire
Licenses        : GPL
Groups          : None
Provides        : None
Depends On      : gst-plugin-pipewire  pipewire  pipewire-alsa  pipewire-pulse  pipewire-session-manager
Optional Deps   : easyeffects: advanced equalizer and effects
                  pipewire-jack: Jack support
                  pipewire-v4l2: V4L2 interceptor
                  pipewire-x11-bell: X11 bell
                  pipewire-zeroconf: Zeroconf support
                  realtime-privileges: Realtime privileges for users
Conflicts With  : manjaro-pulse  pulseaudio-equalizer  pulseaudio-jack  pulseaudio-lirc  pulseaudio-rtp  pulseaudio-zeroconf
Replaces        : None
Download Size   : 21.44 KiB
Installed Size  : 1.52 KiB
Build Date      : Sat 15 Oct 2022 07:50:15 PM +03
[xionix@xio manjaro-roccat-suicide]$ pacman -Si manjaro-pulseaudio
error: package 'manjaro-pulseaudio' was not found
Repository      : extra
Description     : Manjaro meta package for complete PulseAudio support
Architecture    : any
URL             : https://wiki.archlinux.org/title/PulseAudio
Licenses        : GPL
Groups          : None
Provides        : None
Depends On      : pulseaudio  pulseaudio-alsa  pulseaudio-bluetooth
Optional Deps   : paprefs: Configuration dialog
                  pasystray: system tray application
                  pavucontrol: A GTK volume control tool
                  pavucontrol-qt: A Qt volume control tool
                  pulseaudio-ctl: Control volume from the shell or mapped to keyboard shortcuts
                  pulseaudio-equalizer: Graphical equalizer
                  pulseaudio-equalizer-ladspa: A 15-band equalizer
                  pulseaudio-jack: Jack support
                  pulseaudio-lirc: IR (lirc) support
                  pulseaudio-rtp: RTP and RAOP support
                  pulseaudio-zeroconf: Zeroconf support
Conflicts With  : manjaro-pipewire  pipewire-jack  pipewire-pulse  pipewire-v4l2  pipewire-x11-bell  pipewire-zeroconf
Replaces        : None
Download Size   : 20.14 KiB
also here it is my i3 config file, I changed it a little bit in audio section too.
[xionix@xio manjaro-roccat-suicide]$ cat ~/.i3/config
# i3 config file (v4)
# Please see http://i3wm.org/docs/userguide.html for a complete reference!
# Set mod key (Mod1=<Alt>, Mod4=<Super>)
set $mod Mod4
# set default desktop layout (default is tiling)
# workspace_layout tabbed <stacking|tabbed>
# Configure border style <normal|1pixel|pixel xx|none|pixel>
default_border pixel 1
default_floating_border pixel 1
# Hide borders
hide_edge_borders none
# change borders
bindsym $mod+u border none
bindsym $mod+y border pixel 1
bindsym $mod+n border normal
# Font for window titles. Will also be used by the bar unless a different font
# is used in the bar {} block below.
font xft:URWGothic-Book 11
# Use Mouse+$mod to drag floating windows
floating_modifier $mod
# start a terminal
bindsym $mod+Return exec terminal
# kill focused window
bindsym $mod+w kill
# start program launcher
bindsym $mod+d exec --no-startup-id dmenu_recency
# launch categorized menu
bindsym $mod+z exec --no-startup-id morc_menu
## sound-section - DO NOT EDIT if you wish to automatically upgrade Alsa -> Pulseaudio later! ##
exec --no-startup-id pasystray
# exec --no-startup-id "sh -c 'sleep 5; exec pulseaudio --start'"
bindsym XF86AudioRaiseVolume exec --no-startup-id pactl set-sink-volume @DEFAULT_SINK@ +4% #increase sound volume
bindsym XF86AudioLowerVolume exec --no-startup-id pactl set-sink-volume @DEFAULT_SINK@ -4% #decrease sound volume
bindsym XF86AudioMute exec --no-startup-id pactl set-sink-mute @DEFAULT_SINK@ toggle # mute sound
#exec --no-startup-id volumeicon
#bindsym $mod+Ctrl+m exec terminal -e 'alsamixer'
#exec --no-startup-id pulseaudio
#exec --no-startup-id pa-applet
#bindsym $mod+Ctrl+m exec pavucontrol
# Screen brightness controls
# bindsym XF86MonBrightnessUp exec "xbacklight -inc 10; notify-send 'brightness up'"
# bindsym XF86MonBrightnessDown exec "xbacklight -dec 10; notify-send 'brightness down'"
# Start Applications
bindsym $mod+Ctrl+b exec terminal -e 'bmenu'
bindsym $mod+F2 exec google-chrome-stable
bindsym $mod+F3 exec pcmanfm
# bindsym $mod+F3 exec ranger
bindsym $mod+Shift+F3 exec pcmanfm_pkexec
bindsym $mod+F5 exec terminal -e 'mocp'
bindsym $mod+t exec --no-startup-id pkill picom
bindsym $mod+Ctrl+t exec --no-startup-id picom -b
bindsym $mod+Shift+d --release exec "killall dunst; exec notify-send 'restart dunst'"
bindsym Print exec --no-startup-id flameshot gui
bindsym $mod+Print --release exec --no-startup-id i3-scrot -w
bindsym $mod+Shift+Print --release exec --no-startup-id i3-scrot -s
bindsym $mod+Shift+h exec xdg-open /usr/share/doc/manjaro/i3_help.pdf
bindsym $mod+Ctrl+x --release exec --no-startup-id xkill
# focus_follows_mouse no
# change focus
bindsym $mod+j focus left
bindsym $mod+k focus down
bindsym $mod+l focus up
bindsym $mod+semicolon focus right
# alternatively, you can use the cursor keys:
bindsym $mod+Left focus left
bindsym $mod+Down focus down
bindsym $mod+Up focus up
bindsym $mod+Right focus right
# move focused window
bindsym $mod+Shift+j move left
bindsym $mod+Shift+k move down
bindsym $mod+Shift+l move up
bindsym $mod+Shift+semicolon move right
bindsym $mod+Shift+Left move left
bindsym $mod+Shift+Down move down
bindsym $mod+Shift+Up move up
bindsym $mod+Shift+Right move right
# workspace back and forth (with/without active container)
workspace_auto_back_and_forth yes
bindsym $mod+b workspace back_and_forth
bindsym $mod+Shift+b move container to workspace back_and_forth; workspace back_and_forth
# split orientation
bindsym $mod+h split h;exec notify-send 'tile horizontally'
bindsym $mod+v split v;exec notify-send 'tile vertically'
bindsym $mod+q split toggle
# toggle fullscreen mode for the focused container
bindsym $mod+f fullscreen toggle
# change container layout (stacked, tabbed, toggle split)
bindsym $mod+s layout stacking
bindsym $mod+Shift+w layout tabbed
bindsym $mod+e layout toggle split
# toggle tiling / floating
bindsym $mod+Shift+space floating toggle
# change focus between tiling / floating windows
bindsym $mod+space focus mode_toggle
# toggle sticky
bindsym $mod+Shift+s sticky toggle
# focus the parent container
bindsym $mod+a focus parent
# move the currently focused window to the scratchpad
bindsym $mod+Shift+minus move scratchpad
# Show the next scratchpad window or hide the focused scratchpad window.
# If there are multiple scratchpad windows, this command cycles through them.
bindsym $mod+minus scratchpad show
#navigate workspaces next / previous
bindsym $mod+Ctrl+Right workspace next
bindsym $mod+Ctrl+Left workspace prev
# Workspace names
# to display names or symbols instead of plain workspace numbers you can use
# something like: set $ws1 1:mail
#                 set $ws2 2:
set $ws1 1
set $ws2 2
set $ws3 3
set $ws4 4
set $ws5 5
set $ws6 6
set $ws7 7
set $ws8 8
set $wse1 e1
set $wse2 e2
set $wse3 e3
set $wse4 e4
set $wse5 e5
set $wse6 e6
set $wse7 e7
set $wse8 e8
# switch to workspace
bindsym $mod+1 workspace $ws1
bindsym $mod+2 workspace $ws2
bindsym $mod+3 workspace $ws3
bindsym $mod+4 workspace $ws4
bindsym $mod+5 workspace $ws5
bindsym $mod+6 workspace $ws6
bindsym $mod+7 workspace $ws7
bindsym $mod+8 workspace $ws8
bindsym Ctrl+Mod1+1 workspace $wse1
bindsym Ctrl+Mod1+2 workspace $wse2
bindsym Ctrl+Mod1+3 workspace $wse3
bindsym Ctrl+Mod1+4 workspace $wse4
bindsym Ctrl+Mod1+5 workspace $wse5
bindsym Ctrl+Mod1+6 workspace $wse6
bindsym Ctrl+Mod1+7 workspace $wse7
bindsym Ctrl+Mod1+8 workspace $wse8
# Move focused container to workspace
bindsym $mod+Ctrl+1 move container to workspace $ws1
bindsym $mod+Ctrl+2 move container to workspace $ws2
bindsym $mod+Ctrl+3 move container to workspace $ws3
bindsym $mod+Ctrl+4 move container to workspace $ws4
bindsym $mod+Ctrl+5 move container to workspace $ws5
bindsym $mod+Ctrl+6 move container to workspace $ws6
bindsym $mod+Ctrl+7 move container to workspace $ws7
bindsym $mod+Ctrl+8 move container to workspace $ws8
# Move to workspace with focused container
bindsym $mod+Shift+1 move container to workspace $ws1; workspace $ws1
bindsym $mod+Shift+2 move container to workspace $ws2; workspace $ws2
bindsym $mod+Shift+3 move container to workspace $ws3; workspace $ws3
bindsym $mod+Shift+4 move container to workspace $ws4; workspace $ws4
bindsym $mod+Shift+5 move container to workspace $ws5; workspace $ws5
bindsym $mod+Shift+6 move container to workspace $ws6; workspace $ws6
bindsym $mod+Shift+7 move container to workspace $ws7; workspace $ws7
bindsym $mod+Shift+8 move container to workspace $ws8; workspace $ws8
bindsym Ctrl+Shift+1 move container to workspace $wse1; workspace $wse1
bindsym Ctrl+Shift+2 move container to workspace $wse2; workspace $wse2
bindsym Ctrl+Shift+3 move container to workspace $wse3; workspace $wse3
bindsym Ctrl+Shift+4 move container to workspace $wse4; workspace $wse4
bindsym Ctrl+Shift+5 move container to workspace $wse5; workspace $wse5
bindsym Ctrl+Shift+6 move container to workspace $wse6; workspace $wse6
bindsym Ctrl+Shift+7 move container to workspace $wse7; workspace $wse7
bindsym Ctrl+Shift+8 move container to workspace $wse8; workspace $wse8
# Open applications on specific workspaces
# assign [class="Thunderbird"] $ws1
# assign [class="Pale moon"] $ws2
# assign [class="Pcmanfm"] $ws3
# assign [class="Skype"] $ws5
# Open specific applications in floating mode
for_window [title="alsamixer"] floating enable border pixel 1
for_window [class="calamares"] floating enable border normal
for_window [class="Clipgrab"] floating enable
for_window [title="File Transfer*"] floating enable
for_window [class="fpakman"] floating enable
for_window [class="Galculator"] floating enable border pixel 1
for_window [class="GParted"] floating enable border normal
for_window [title="i3_help"] floating enable sticky enable border normal
for_window [class="Lightdm-settings"] floating enable
for_window [class="Lxappearance"] floating enable sticky enable border normal
for_window [class="Manjaro-hello"] floating enable
for_window [class="Manjaro Settings Manager"] floating enable border normal
for_window [title="MuseScore: Play Panel"] floating enable
for_window [class="Nitrogen"] floating enable sticky enable border normal
for_window [class="Oblogout"] fullscreen enable
for_window [class="octopi"] floating enable
for_window [title="About Pale Moon"] floating enable
for_window [class="Pamac-manager"] floating enable
for_window [class="Pavucontrol"] floating enable
for_window [class="qt5ct"] floating enable sticky enable border normal
for_window [class="Qtconfig-qt4"] floating enable sticky enable border normal
for_window [class="Simple-scan"] floating enable border normal
for_window [class="(?i)System-config-printer.py"] floating enable border normal
for_window [class="Skype"] floating enable border normal
for_window [class="Timeset-gui"] floating enable border normal
for_window [class="(?i)virtualbox"] floating enable border normal
for_window [class="Xfburn"] floating enable
# Disable titles for other apps
for_window [class="^.*"] border pixel 1
# switch to workspace with urgent window automatically
for_window [urgent=latest] focus
# reload the configuration file
bindsym $mod+Shift+c reload
# restart i3 inplace (preserves your layout/session, can be used to upgrade i3)
bindsym $mod+Shift+r restart
# exit i3 (logs you out of your X session)
bindsym $mod+Shift+e exec "i3-nagbar -t warning -m 'You pressed the exit shortcut. Do you really want to exit i3? This will end your X session.' -b 'Yes, exit i3' 'i3-msg exit'"
# Set shut down, restart and locking features
bindsym $mod+0 mode "$mode_system"
set $mode_system (l)ock, (e)xit, switch_(u)ser, (s)uspend, (h)ibernate, (r)eboot, (Shift+s)hutdown
mode "$mode_system" {
    bindsym l exec --no-startup-id i3exit lock, mode "default"
    bindsym s exec --no-startup-id i3exit suspend, mode "default"
    bindsym u exec --no-startup-id i3exit switch_user, mode "default"
    bindsym e exec --no-startup-id i3exit logout, mode "default"
    bindsym h exec --no-startup-id i3exit hibernate, mode "default"
    bindsym r exec --no-startup-id i3exit reboot, mode "default"
    bindsym Shift+s exec --no-startup-id i3exit shutdown, mode "default"
    # exit system mode: "Enter" or "Escape"
    bindsym Return mode "default"
    bindsym Escape mode "default"
# Resize window (you can also use the mouse for that)
bindsym $mod+r mode "resize"
mode "resize" {
        # These bindings trigger as soon as you enter the resize mode
        # Pressing left will shrink the window’s width.
        # Pressing right will grow the window’s width.
        # Pressing up will shrink the window’s height.
        # Pressing down will grow the window’s height.
        bindsym j resize shrink width 5 px or 5 ppt
        bindsym k resize grow height 5 px or 5 ppt
        bindsym l resize shrink height 5 px or 5 ppt
        bindsym semicolon resize grow width 5 px or 5 ppt
        # same bindings, but for the arrow keys
        bindsym Left resize shrink width 10 px or 10 ppt
        bindsym Down resize grow height 10 px or 10 ppt
        bindsym Up resize shrink height 10 px or 10 ppt
        bindsym Right resize grow width 10 px or 10 ppt
        # exit resize mode: Enter or Escape
# Lock screen
bindsym $mod+9 exec --no-startup-id blurlock
# Autostart applications
exec --no-startup-id /usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
exec --no-startup-id nitrogen --restore; sleep 1; picom -b
#exec --no-startup-id manjaro-hello
exec --no-startup-id nm-applet
exec --no-startup-id xfce4-power-manager
exec --no-startup-id pamac-tray
exec --no-startup-id clipit
exec --no-startup-id caffeine
# exec --no-startup-id blueman-applet
# exec_always --no-startup-id sbxkb
# exec --no-startup-id start_conky_maia
# exec --no-startup-id start_conky_green
exec --no-startup-id xautolock -time 10 -locker blurlock
exec_always --no-startup-id ff-theme-util
exec_always --no-startup-id fix_xcursor
# Color palette used for the terminal ( ~/.Xresources file )
# Colors are gathered based on the documentation:
# https://i3wm.org/docs/userguide.html#xresources
# Change the variable name at the place you want to match the color
# of your terminal like this:
# [example]
# If you want your bar to have the same background color as your
# terminal background change the line 362 from:
# background #14191D
# to:
# background $term_background
# Same logic applied to everything else.
set_from_resource $term_background background
set_from_resource $term_foreground foreground
set_from_resource $term_color0     color0
set_from_resource $term_color1     color1
set_from_resource $term_color2     color2
set_from_resource $term_color3     color3
set_from_resource $term_color4     color4
set_from_resource $term_color5     color5
set_from_resource $term_color6     color6
set_from_resource $term_color7     color7
set_from_resource $term_color8     color8
set_from_resource $term_color9     color9
set_from_resource $term_color10    color10
set_from_resource $term_color11    color11
set_from_resource $term_color12    color12
set_from_resource $term_color13    color13
set_from_resource $term_color14    color14
set_from_resource $term_color15    color15
# Start i3bar to display a workspace bar (plus the system information i3status if available)
bar {
	i3bar_command i3bar
	status_command i3status
	position bottom
## please set your primary output first. Example: 'xrandr --output eDP1 --primary'
#	tray_output primary
#	tray_output eDP1
	bindsym button4 nop
	bindsym button5 nop
#   font xft:URWGothic-Book 11
	strip_workspace_numbers yes
    colors {
        background #222D31
        statusline #F9FAF9
        separator  #454947
#                      border  backgr. text
        focused_workspace  #F9FAF9 #16a085 #292F34
        active_workspace   #595B5B #353836 #FDF6E3
        inactive_workspace #595B5B #222D31 #EEE8D5
        binding_mode       #16a085 #2C2C2C #F9FAF9
        urgent_workspace   #16a085 #FDF6E3 #E5201D
# hide/unhide i3status bar
bindsym $mod+m bar mode toggle
# Theme colors
# class                   border  backgr. text    indic.   child_border
  client.focused          #556064 #556064 #80FFF9 #FDF6E3
  client.focused_inactive #2F3D44 #2F3D44 #1ABC9C #454948
  client.unfocused        #2F3D44 #2F3D44 #1ABC9C #454948
  client.urgent           #CB4B16 #FDF6E3 #1ABC9C #268BD2
  client.placeholder      #000000 #0c0c0c #ffffff #000000
  client.background       #2B2C2B
### settings for i3-gaps: ###
# Set inner/outer gaps
gaps inner 14
gaps outer -2
# Additionally, you can issue commands with the following syntax. This is useful to bind keys to changing the gap size.
# gaps inner|outer current|all set|plus|minus <px>
# gaps inner all set 10
# gaps outer all plus 5
# Smart gaps (gaps used if only more than one container on the workspace)
smart_gaps on
# Smart borders (draw borders around container only if it is not the only container on this workspace)
# on|no_gaps (on=always activate and no_gaps=only activate if the gap size to the edge of the screen is 0)
smart_borders on
# Press $mod+Shift+g to enter the gap mode. Choose o or i for modifying outer/inner gaps. Press one of + / - (in-/decrement for current workspace) or 0 (remove gaps for current workspace). If you also press Shift with these keys, the change will be global for all workspaces.
set $mode_gaps Gaps: (o) outer, (i) inner
set $mode_gaps_outer Outer Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_inner Inner Gaps: +|-|0 (local), Shift + +|-|0 (global)
bindsym $mod+Shift+g mode "$mode_gaps"
mode "$mode_gaps" {
        bindsym o      mode "$mode_gaps_outer"
        bindsym i      mode "$mode_gaps_inner"
mode "$mode_gaps_inner" {
        bindsym plus  gaps inner current plus 5
        bindsym minus gaps inner current minus 5
        bindsym 0     gaps inner current set 0
        bindsym Shift+plus  gaps inner all plus 5
        bindsym Shift+minus gaps inner all minus 5
        bindsym Shift+0     gaps inner all set 0
mode "$mode_gaps_outer" {
        bindsym plus  gaps outer current plus 5
        bindsym minus gaps outer current minus 5
        bindsym 0     gaps outer current set 0
        bindsym Shift+plus  gaps outer all plus 5
        bindsym Shift+minus gaps outer all minus 5
        bindsym Shift+0     gaps outer all set 0
# xinput cfg
exec --no-startup-id "xinput set-prop 'ROCCAT ROCCAT Kone Pure Ultra' 'libinput Accel Speed' -0.5"
# arandr cfg
exec --no-startup-id /home/xionix/.screenlayout/mid_right.sh
# My settings start here :)
exec --no-startup-id "setxkbmap -model pc105 -layout us,ru -option grp:alt_shift_toggle"
bindsym XF86Calculator exec --no-startup-id urxvt -e python
bindsym Ctrl+XF86Calculator exec --no-startup-id generate-gmeet-room
have you tried pipewire + alsa ?
sorry, Im not sure what does it mean pipewire + alsa…
I thought alsa is something low level & manjaro in any case use alsa (out of the box)…
I tried to switch to pipewire today. I dont remember exactly what commands I executed, but it was something like:
  1. I removed everything connected to pulseaudio (e.g. pacman -R manjaro-pulse);
  2. I installed pipewire (e.g. pacman -S manjaro-pipewire) + wireplumber I assume;
  3. reboot
  4. Installed pipewire-pulse;
  5. reboot
  6. Checked inxi, it said that pipewire currently running and pulseaudio with jack is not. Checked pactl info and it said that it’s running “fake” pulseaudio with real pipewire backend.
Can u please provide me a link or smth to read about alsa setup… because from my side I thought that I already using it.
Also, in original topic I mentioned that I tried pipewire and the problem still was here.
btw, right now I tried inxi and it says to me that:
[xionix@xio manjaro-roccat-suicide]$ inxi -Fazy
    udev.log_priority=3
  Speed (MHz): avg: 1733 high: 3187 min/max: 1200/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1720 2: 2368 3: 1500
    4: 1502 5: 1500 6: 1500 7: 1524 8: 3187 9: 1500 10: 1500 11: 1500 12: 1500
    bogomips: 99036
    vulnerable
    prctl and seccomp
    process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:17c8 class-ID: 0300
    driver: snd_hda_intel bus-ID: 3-10.3:13 v: kernel chip-ID: 1e7d:39d0
    bus-ID: 00:1b.0 class-ID: 0300 chip-ID: 8086:8d20 class-ID: 0403
    bus-ID: 01:00.1 chip-ID: 10de:0fb0 class-ID: 0403
    class-ID: 0300
  Sound Server-3: PipeWire v: 0.3.63 running: yes
    serial: <filter>
  Components: Online:
  Local Storage: total: raw: 3.93 TiB usable: 296.2 GiB used: 23.12 GiB (7.8%)
    lanes: 4 type: SSD serial: <filter> rev: BXW7300Q temp: 41.9 C scheme: GPT
    used: 14.14 GiB (12.6%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    used: 8.98 GiB (0.9%) fs: ext4 dev: /dev/md126p1 maj-min: 259:7
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 60 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
  Processes: 303 Uptime: 6h 20m wakeups: 0 Memory: 15.54 GiB
  used: 4.77 GiB (30.7%) Init: systemd v: 252 default: graphical
So, I have pipewire & pulseaudio running in one time…
Maybe I messed up it’s service during today experiments (because before there was no such behavior).
[xionix@xio manjaro-roccat-suicide]$ systemctl --user status pipewire.socket pipewire.service
● pipewire.socket - PipeWire Multimedia System Socket
     Loaded: loaded (/usr/lib/systemd/user/pipewire.socket; enabled; preset: enabled)
     Active: active (running) since Tue 2023-01-10 16:36:55 +03; 6h ago
      Until: Tue 2023-01-10 16:36:55 +03; 6h ago
   Triggers: ● pipewire.service
     Listen: /run/user/1000/pipewire-0 (Stream)
     CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.socket
Jan 10 16:36:55 xio systemd[1004]: Listening on PipeWire Multimedia System Socket.
● pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
     Active: active (running) since Tue 2023-01-10 21:40:17 +03; 1h 17min ago
TriggeredBy: ● pipewire.socket
   Main PID: 23711 (pipewire)
      Tasks: 3 (limit: 19064)
     Memory: 6.3M
        CPU: 68ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─23711 /usr/bin/pipewire
Jan 10 21:40:17 xio systemd[1004]: Started PipeWire Multimedia Service.
Jan 10 21:40:17 xio pipewire[23711]: mod.rt: Can't find xdg-portal: (null)
Jan 10 21:40:17 xio pipewire[23711]: mod.rt: found session bus but no portal
Jan 10 21:40:20 xio pipewire[23711]: [5:03:47.003313343] [23711]  INFO Camera camera_manager.cpp:299 libcamera v0.0.2
Jan 10 21:40:20 xio pipewire[23711]: [5:03:47.006738326] [23779]  WARN V4L2 v4l2_pixelformat.cpp:312 Unsupported V4L2 pixel format H264
so I will experiment with micro right now and then will disable pipewire using:
systemctl --user disable --now pipewire.socket pipewire.service
and re-experiment one more time :slight_smile:
check status with alsactl alsamixer ( no Mute ‘M’ )
not forget to do alsactl store after
https://wiki.archlinux.org/title/Advanced_Linux_Sound_Architecture#Tips_and_tricks
after in pavucontrol and apps
you should use -Rs option to remove scripts / configs ,
and adding
manjaro-pipewire , manjaro-wireplumber - manjaro-alsa remove manjaro-pulseausio
not forget
so, regarding experiments:
pipewire & pulseaudio running both in same time
State: machine up for something like 5h, I havent used mic for 2-3h, pulseaudio & pipewire running both (logs upper).
  1. Tried to use mic – no sound;
  2. Changed profile in pavucontrol from analog duplex, to analog out digital in, and then back – microphone started his work;
  3. Microphone working already something like 2 minutes;
  4. I closed google meet tab where I checked is microphone alive;
  5. I opened new google meet tab, and microphone is dead; (u can assume that there was no breaks between each steps, except specified);
Note: I was listening music whole time, and there was no music interaptions or smth like that, except times when I opened&closed pavucontrol .
preparation for the second part of experiment
[xionix@xio manjaro-roccat-suicide]$ systemctl --user disable --now pipewire.socket pipewire.service
○ pipewire.socket - PipeWire Multimedia System Socket
     Active: inactive (dead) since Tue 2023-01-10 23:08:02 +03; 2s ago
   Duration: 6h 31min 7.369s
Jan 10 23:08:02 xio systemd[1004]: Closed PipeWire Multimedia System Socket.
○ pipewire.service - PipeWire Multimedia Service
   Duration: 1h 27min 44.877s
TriggeredBy: ○ pipewire.socket
    Process: 23711 ExecStart=/usr/bin/pipewire (code=exited, status=0/SUCCESS)
   Main PID: 23711 (code=exited, status=0/SUCCESS)
        CPU: 72ms
Jan 10 23:08:02 xio systemd[1004]: Stopping PipeWire Multimedia Service...
Jan 10 23:08:02 xio systemd[1004]: Stopped PipeWire Multimedia Service.
    udev.log_priority=3
  Speed (MHz): avg: 1765 high: 3065 min/max: 1200/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2519 2: 1973 3: 1500
    4: 1500 5: 1500 6: 1500 7: 1500 8: 3065 9: 1502 10: 1624 11: 1500 12: 1500
    bogomips: 99036
    vulnerable
    prctl and seccomp
    class-ID: 0300
    driver: snd_hda_intel v: kernel bus-ID: 3-10.3:13 bus-ID: 00:1b.0
    class-ID: 0403
    class-ID: 0300
    serial: <filter>
  Components: Online:
  Local Storage: total: raw: 3.93 TiB usable: 296.2 GiB used: 23.13 GiB (7.8%)
    used: 8.99 GiB (0.9%) fs: ext4 dev: /dev/md126p1 maj-min: 259:7
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 57 C
  Processes: 310 Uptime: 6h 32m wakeups: 0 Memory: 15.54 GiB
  used: 5.12 GiB (33.0%) Init: systemd v: 252 default: graphical
only pulseaudio running
  3. Microphone working for something like 10-15 seconds;
Outcome
Nothing changed when I killed pipewire.
What is more interesting – when I re-open google meet: microphone brakes, it’s kinda fast way to reproduce floating bug… probably it’s not floating any more :slight_smile:
@stephane, regarding ur request with alsa - don’t worry, that what I will try to do right now.
btw, thanks for help, we already found fast way to reproduce an issue :slight_smile:
be careful kernel 6.0 or 6.1 can change on audio system
So, currently microphone is broken.
arecord -l
[xionix@xio manjaro-roccat-suicide]$ arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1150 Analog [ALC1150 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 2: ALC1150 Alt Analog [ALC1150 Alt Analog]
  Subdevices: 1/1
card 2: Device [USB Advanced Audio Device], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
card 3: AIMO [ROCCAT Khan AIMO], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
card 4: Pro [Razer Kiyo Pro], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
So, card 3 is my headset.
amixer -c3
[xionix@xio manjaro-roccat-suicide]$ amixer -c3
Simple mixer control 'Speaker',0
  Capabilities: pvolume pswitch pswitch-joined
  Limits: Playback 0 - 38
  Mono:
  Front Left: Playback 11 [29%] [-34.00dB] [on]
  Front Right: Playback 11 [29%] [-34.00dB] [on]
Simple mixer control 'Mic',0
  Capabilities: pvolume cvolume pswitch pswitch-joined cswitch cswitch-joined
  Limits: Playback 0 - 37 Capture 0 - 30
  Front Left: Playback 18 [49%] [3.00dB] [off] Capture 27 [90%] [27.00dB] [on]
  Front Right: Playback 18 [49%] [3.00dB] [off] Capture 27 [90%] [27.00dB] [on]
Im not sure what is going here, but seems to be it’s not muted… lets try disabling automute.
[xionix@xio manjaro-roccat-suicide]$ amixer -c 3 sset "Auto-Mute Mode" Disabled
amixer: Unable to find simple control 'Auto-Mute Mode',0
[xionix@xio manjaro-roccat-suicide]$ echo $?
1
also I tried to play in GUI (alsamixer)… and from it side I can see that mic is not muted, I tried to mute&unmute it – it doesn’t help. I tried to control volume of music – it works properly.
Should I install pipewire and try to play with alsa one more time?
what if I will try to update to 6.1.1-1… probably it will be resolved somehow? :slight_smile:
or will it gain only more pain?
you can have more than one kernel ,
sudo pacman -S linux515-headers
sudo mhwd-kernel -i linux60
sudo mhwd-kernel -i linux61
go in grub > advanced options > select kernel
Seems the typical problem about intel audio and 5.15.8x kernel
If so, just install any 6.x kernel, and it will work fine again.
@stephane @Nachordez
Hi guys,
So I update to 6.1.1-1.
For me it looks like no changes at all.
Linux xio 6.1.1-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Dec 21 23:21:50 UTC 2022 x86_64 GNU/Linux
[xionix@xio ~]$ inxi -Fazy
  Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    udev.log_priority=3
  Speed (MHz): avg: 1344 high: 1700 min/max: 1200/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1200 3: 1200
    4: 1500 5: 1700 6: 1200 7: 1200 8: 1200 9: 1532 10: 1200 11: 1501 12: 1500
    bogomips: 99044
    vulnerable
    class-ID: 0300
    bus-ID: 4-6.4:5 chip-ID: 1532:0e05 class-ID: 0102
    driver: snd_hda_intel v: kernel bus-ID: 3-10.3:8 bus-ID: 00:1b.0
    class-ID: 0403
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-9.1.1:10
    chip-ID: 0d8c:01c2 class-ID: 0300
  Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
    serial: <filter>
  Components: Online:
  Local Storage: total: raw: 3.93 TiB usable: 296.2 GiB used: 24.22 GiB (8.2%)
    used: 15.05 GiB (13.4%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    used: 9.17 GiB (0.9%) fs: ext4 dev: /dev/md126p1 maj-min: 259:7
  System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 55 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
  Processes: 272 Uptime: 10m wakeups: 0 Memory: 15.54 GiB
  used: 2.03 GiB (13.1%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1159
  pm: pacman pkgs: 1148 libs: 295 tools: pamac,yay pm: snap pkgs: 11
Sound/mic habits remains totally same as on 5.15.x kernel.
Also, I tried to play with mute in aslamixer one one more time - it doesn’t help at all.
Also, I noticed that when micro works in pavucontrol I have a bar showing that Im something talking in mic:
But, when microphone dies, this bar just disappears :confused:
I tried right now to play with loopback (to hear micro sound in headphones).
So, micro works properly without any cracks or smth, and sound from micro just disappears when I close any app that using mic (e.g. I close google meet tab).
Sorry to hear that… Your intel CPU is older than ones known to be affected by the kernel question, but I really was hoping to be related. It seems to be a different question, and I don’t have ane clue now, I can’t help…
no problems, I understand that my problem is kinda… special… Im dealing with it 2 years for now… and I think that the only thing that I haven’t found anywhere on net :slight_smile:
btw, updating to new kernel leaded to more problems. Now, with 6.1.1-1 I have the same behavior not only with microphone, but with headphones too :smiling_face_with_tear:
So, when I try to listen music in some service (e.g. Spotify) or watch some video on Youtube – nothing works until I change profile for headset in pavucontrol.
To be specific:
  • Video on Youtube just trying to load (loading wheel is spinning) and if I will wait around 10 seconds – some error raised saying that I need to try to restart PC, and if errror will not go away – contact support.
  • Music in web service is not playing – playing cursor just freezes on 0:01 second of track and if I will change profile – it will imminently start playing music.
One idea: so that it’s not recent hardware, and seems to work even worse in new kernel… Have you tried to downgrade to older kernel than 5.15? There are some older LTS kernels offered by Manjaro, an new kernel is basically needed for new hardware, so could be a solution, or at least something worth to try!
as I said in original message I was living with this behavior from 5.10.x to latest. (already around 2 years)
