USB Floppy Drive sometimes mounted as root
When I mount a floppy drive in nautilus it gets mounted owned by root so I cant write to it. If I unmount it and then mount it again its owned by me and everything is fine. What’s going on here and how can I fix it so that it mounts properly first time?
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=64dbb951-063f-43f5-bb22-3358237997b5 rw quiet splash apparmor=1
  Desktop: GNOME v: 48.5 tk: GTK v: 3.24.50 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: PC Specialist product: NH5x_NH7x_HHx_HJx_HKx v: N/A
    serial: <superuser required> Chassis: No Enclosure type: 10
  Mobo: CLEVO model: NHxxHJHK serial: <superuser required>
    uuid: <superuser required> UEFI: INSYDE v: 1.07.03TPCS1 date: 05/13/2021
  ID-1: BAT0 charge: 42.7 Wh (100%) condition: 42.7/47.2 Wh (90.6%)
    volts: 16.03 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
    charging: status: full cycles: N/A
  System RAM: total: 32 GiB available: 31.13 GiB used: 6.42 GiB (20.6%)
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 16 GiB speed: 2667 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: Corsair part-no: CM4X16GE2666C18S4 serial: N/A
  Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
    microcode: 0x56
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB
    desc: 8x1.2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 985 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 985 2: 985 3: 985 4: 985 5: 985 6: 985 7: 985
    8: 985 9: 985 10: 985 11: 985 12: 985 13: 985 14: 985 15: 985 16: 985
    bogomips: 73744
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: CLEVO/KAPOK
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: CLEVO/KAPOK
    driver: N/A alternate: nouveau non-free: 550-580.xx+ status: current (as of
    2025-08; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0300
  Device-3: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 5986:9102
    class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: modesetting gpu: i915
    display-ID: 0
  Monitor-1: eDP-1 model: LG Display 0x065b built: 2019 res: 1920x1080
    dpi: 128 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.306 y: 0.608
    blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9
    modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.2.3-arch1.2
    note: incomplete (EGL sourced) renderer: Mesa Intel UHD Graphics (TGL GT1),
    llvmpipe (LLVM 20.1.8 256 bits)
  API: Vulkan v: 1.4.321 layers: 7 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (TGL GT1) driver: mesa intel v: 25.2.3-arch1.2
    device-ID: 8086:9a60 surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo
    gpu: nvidia-settings,nvidia-smi x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
  Device-2: NVIDIA GA107 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: off 3: wireplumber
    status: active 4: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
  Server-4: PulseAudio v: 17.0-43-g3e2bb status: off (using pipewire-pulse)
    with: 1: pulseaudio-alsa type: plugin 2: pulseaudio-jack type: module
    tools: pacat,pactl
    vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Info: services: httpd, NetworkManager, smbd, sshd, systemd-timesyncd,
    wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 2.75 TiB used: 390.15 GiB (13.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU010TZ
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 27.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: TEAC model: V0.0 size: 720 KiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 1.1 spd: 12 Mb/s
    lanes: 1 mode: 1.1 tech: N/A serial: <filter> fw-rev: 0.00
  ID-1: / raw-size: 195.31 GiB size: 191.19 GiB (97.89%)
    used: 99.58 GiB (52.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 64dbb951-063f-43f5-bb22-3358237997b5
  ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
    used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 2648-2A15
  ID-3: /home raw-size: 488.28 GiB size: 479.55 GiB (98.21%)
    used: 290.57 GiB (60.6%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: N/A uuid: f859277a-0dfa-427e-a5e8-d35d70c10e61
  ID-4: /run/media/rod/MSDOS5 raw-size: 720 KiB size: 713 KiB (99.03%)
    used: 433 KiB (60.7%) fs: vfat dev: /dev/sdb maj-min: 8:16 label: MSDOS5
    uuid: 203F-07C7
  ID-1: swap-1 type: partition size: 39.06 GiB used: 12 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 9c1c4b00-ef12-4226-83ab-8aeeb1e74571
  ID-1: /dev/sda1 maj-min: 8:1 size: 488.28 GiB fs: ext4 label: OldDisc
    uuid: 3d22ee2f-0ab6-4ce6-9a33-33d89a9a0e14
  ID-2: /dev/sda2 maj-min: 8:2 size: 488.28 GiB fs: ext4 label: Archive
    uuid: 3e1f4036-a8b7-48d8-8461-e08be0384d19
  ID-3: /dev/sda3 maj-min: 8:3 size: 488.28 GiB fs: ext4 label: Backup
    uuid: 9795c9fe-544d-4786-917e-98eb834fd31c
  Device-1: 1-5:23 info: TEAC Floppy type: mass storage driver: usb-storage
    interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0644:0000 class-ID: 0804
  Device-2: 1-8:2 info: Bison BisonCam NB Pro type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:9102 class-ID: 0e02
  Device-3: 1-14:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  System Temperatures: cpu: 43.0 C mobo: 42.0 C
  Fan Speeds (rpm): cpu: 2225
  Packages: 2305 pm: pacman pkgs: 2219 libs: 578 tools: gnome-software,pamac
    pm: flatpak pkgs: 49 pm: snap pkgs: 37
    1: https://manjaro.ynh.ovh/stable/$repo/$arch
    2: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    3: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    4: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    5: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    6: https://mirror.init7.net/manjaro/stable/$repo/$arch
    7: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    8: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    9: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    10: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    11: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    12: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    13: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    14: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    15: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    16: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    17: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    18: https://mirror.23m.com/manjaro/stable/$repo/$arch
    19: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    20: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    21: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    22: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    23: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    24: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 431
  1: cpu: 22.2% command: localsearch-extractor-3 pid: 57229
    mem: 38.7 MiB (0.1%)
  2: cpu: 6.8% command: firefox pid: 56245 mem: 403.4 MiB (1.2%)
  3: cpu: 4.1% command: firefox pid: 56549 mem: 357.2 MiB (1.1%)
  4: cpu: 1.6% command: firefox pid: 56295 mem: 362.4 MiB (1.1%)
  5: cpu: 0.8% command: firefox pid: 3933 mem: 1084.8 MiB (3.4%)
  Memory top: 5 of 431
  1: mem: 1997.9 MiB (6.2%) command: java pid: 43605 cpu: 0.2%
  2: mem: 1084.8 MiB (3.4%) command: firefox pid: 3933 cpu: 0.8%
  3: mem: 772.8 MiB (2.4%) command: thunderbird pid: 6200 cpu: 0.1%
  4: mem: 519.1 MiB (1.6%) command: gnome-shell pid: 2267 cpu: 0.5%
  5: mem: 403.4 MiB (1.2%) command: firefox pid: 56245 cpu: 6.8%
  Processes: 431 Power: uptime: 6d 24m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 20 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.42 GiB services: gsd-power,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.39
I cannot remember when I last saw that kind of storage media - oh wait - yesterday in ncis origins when they began typing in old case files.
udisks2 service is in charge on mounting removable devices.
When the service encounters an error in the file system - it may choose to mount anyway but in order to prevent further damage it is mounted as read-only.
I have several vintage computers from the 80’s and 90’s and floppy disks are often the only way to get started until I can get a better storage option. I’m currently working on an Amstrad PPC640 and trying to get a CF based hard drive working but I need to boot from a 3 1/2 floppy first.
i have a question: you’re talking about a real physical floppy-drive and not floppy-images ?
if so this link might be helpful. mounting a physical /dev/fdo using the floppy-module might need to adjust the owners-group similar to this
Just put an entry for it in /etc/fstab and be done with it. The tutorial below will explain how to do it. :backhand_index_pointing_down:
