Would this work to zero the critical initial sectors when normal formatting tools don’t work?
dd if=/dev/zero of=/dev/sdY bs=4k count=1 status=progress
where “Y” in sdY is the actual USB drive.
It has been around for a long time in Tutorials section
You cannot do that - the command may return OK but it won’t work.
In the Tutorials section is a utility script to handle the task
If @cscs suggestion in #10 is failing - it is likely end of life - it happens more often than you think.
Simple alternative is install package
grml-rescueboot
See also explanation for Debian
http://wiki.grml.org/doku.php?id=rescueboot
Now its as simple as copy your *.iso to
/boot/grml/
then update-grub and you have aditional boot entry for your *.iso
I just tried an it does not work for just ANY iso. By default it works for their grml images. The grub script there is optimized for those images, if you put a manjaro iso it will not find vmlinuz, initrd etc. where it looks.
So for a manjaro iso you have to use the method from the How-to.
Just veryfied with booting
manjaro-xfce-21.3.7-220816-linux515.iso
from the new grub-menue entry … it works!
Sysinfo
Generated on 2023-06-24 11:49:1687600193
#################### inxi -Fxzc0 ########################
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1 Desktop: Xfce v: 4.18.1
Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO
v: BYCN39WW date: 05/28/2021
ID-1: BAT0 charge: 63.6 Wh (97.4%) condition: 65.3/62.0 Wh (105.3%) volts: 17.1 min: 15.4
model: LGC L19L4PD2 status: full
Info: quad core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5 cache:
L1: 320 KiB L2: 2 MiB L3: 8 MiB
Speed (MHz): avg: 1350 high: 1500 min/max: 400/3900 cores: 1: 1500 2: 1396 3: 608 4: 1500
5: 1301 6: 1500 7: 1500 8: 1500 bogomips: 23968
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel arch: Gen-11
bus-ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: nvidia v: 530.41.03 arch: Pascal
bus-ID: 2b:00.0
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB bus-ID: 3-5:5
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting,nvidia unloaded: nouveau
dri: iris gpu: i915 resolution: 1: 1920x1080~60Hz 2: N/A
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Iris Plus Graphics (ICL GT2)
direct-render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo driver: sof-audio-pci-intel-icl
bus-ID: 00:1f.3
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api
Server-1: sndiod v: N/A status: off
Server-2: PipeWire v: 0.3.70 status: active
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB bus-ID: 2-1.4:4
IF: enp0s13f0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: pan1 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 3-10:14
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 1.84 TiB used: 445.39 GiB (23.6%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB temp: 45.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10EARX-00N0YB0 size: 931.51 GiB type: USB
ID-1: / size: 57.85 GiB used: 41.66 GiB (72.0%) fs: ext4 dev: /dev/nvme0n1p8
ID-2: /boot/efi size: 259.5 MiB used: 114.8 MiB (44.2%) fs: vfat dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 16.67 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p9
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 284 Uptime: 6m Memory: available: 15.19 GiB used: 2.71 GiB (17.8%) Init: systemd
Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1987 Client: Unknown Client: wrapper-2.0
inxi: 3.3.27
If i recall it correct i just installed the package and copied the *.iso to the now existing /boot/grml folder plus update-grub
Never needed it because Manjaro just works for years now
But i now think its useless for your usecase because /boot/grml is part of the system you want to fix?!
I make a full backup every night with backintime, never fixed a ruined system because its easy to restore with backintime.
