Snblg
29 July 2022 22:21
1
Hello,
I have installed Manjaro cinnamon on a new machine, and after boot, I have to wait up to 30" to be able to use my mouse and get ethernet connected.
I have tried another mouse, another usb hub.
No problem under Windows on same machine.
No problem with the Manjaro usb key.
I did copy usb files on a Nvme partition; if I boot it using SuperGrubDisk2, it is fast, and no mouse /ethernet delay…
I did reinstall from scratch : same problem, even before updating (sudo pacman -Syu)
I cannot really see what happens using journalctl.
I did try another kernel … same problem.
Thanks in advance for any help.
Welcome to the forum!
Sorry, no one knows what “boot pb” is. Please refer to: How to Post and edit your topic title accordingly.
Please see [HowTo] Make support easier and post your system details along with the output of lsusb.
Snblg
30 July 2022 06:27
3
Hello Yochanan
Boot pb is a boot problem _ Linux is loaded, Cinnamon desktop is displayed.
But I mus twait 20 to 30 seconds before beiing able to use my mouse and the ethernet connection.
Snblg
3 August 2022 09:35
4
USB problem solved using default parameters (apps started on boot, cinnamon parameter GUI)
Today, I still do not understand why my Ethernet needs so much time to get connected.
I changed DHCP mode to fixed IP → same problem.
Snblg
9 August 2022 14:02
5
My problem is not solved. Ethernet, and mouse often need several seconds (±30) to be available.
Any help will be really appreciated.
No such problem on my older desktop !
Windows 11 is running fine.
My current desktop
Kernel: 5.15.59-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
Desktop: Cinnamon v: 5.4.9 tk: GTK v: 3.24.34 vt: 7 dm: LightDM v: 1.30.0
Type: Desktop Mobo: Micro-Star model: MPG Z690 FORCE WIFI (MS-7D30) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.70
date: 06/29/2022
Info: 16-core (8-mt/8-st) model: 12th Gen Intel Core i9-12900KS bits: 64
type: MST AMCP smt: enabled arch: Alder Lake rev: 2 cache: L1: 1.4 MiB
L2: 14 MiB L3: 30 MiB
Speed (MHz): avg: 837 high: 1297 min/max: 800/5298:5500:4000 cores:
1: 800 2: 801 3: 800 4: 800 5: 800 6: 800 7: 1297 8: 801 9: 800 10: 800
11: 1157 12: 673 13: 800 14: 800 15: 801 16: 801 17: 800 18: 800 19: 801
20: 961 21: 799 22: 800 23: 800 24: 800 bogomips: 164088
Device-1: Intel AlderLake-S GT1 vendor: Micro-Star MSI driver: i915
v: kernel ports: active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2,
HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0380
Device-2: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: Micro-Star MSI
driver: nvidia v: 515.65.01 arch: Ampere pcie: speed: 2.5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:2208 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: nvidia
gpu: i915,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1355x381mm (53.35x15.00")
s-diag: 1408mm (55.42")
Monitor-1: DP-4 res: 5120x1440 dpi: 130048 size: 1x1mm (0.04x0.04")
diag: 1mm (0.06") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1-3:2 bus-ID: 00:1f.3
chip-ID: 0db0:005a class-ID: 0300 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-3: Micro Star USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc
v: kernel pcie: speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0
chip-ID: 8086:15f3 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-14:6 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 3.18 TiB used: 1.19 TiB (37.2%)
ID-1: /dev/nvme0n1 vendor: MSI model: M480 2TB size: 1.82 TiB
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: EIFM21.2
temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Kingston model: SA2000M8500G size: 465.76 GiB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z42105
temp: 38.9 C scheme: GPT
ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
ID-1: / size: 71.54 GiB used: 27.97 GiB (39.1%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 499 MiB used: 27.8 MiB (5.6%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 114.79 GiB used: 39.52 GiB (34.4%) fs: ext4
dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 41.02 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3
System Temperatures: cpu: 26.0 C mobo: N/A gpu: nvidia temp: 48 C
Processes: 423 Uptime: 22m wakeups: 284 Memory: 31.14 GiB used: 2.36 GiB
(7.6%) Init: systemd v: 251 default: graphical Compilers: gcc: 12.1.1
clang: 14.0.6 Packages: pacman: 1531 Shell: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.20
Snblg
9 August 2022 16:01
6
I did find a problem : Nvidia driver.
No problem using video-modesetting driver, but login fails on 1st attempt.
Long Ethernet connection + mouse using video-nvidia driver, but login succeeds on 1st try !
I would like both login and fast Ethernet connection with my video driver !
Any idea ?
My video card is an RTX3080 Ti
Snblg
5 September 2022 05:06
7
Problem solved with KDE (Plasma).
I was using Cinnamon.
It seems Nvidia drivers are only supported by Nvidia on X11 servers.
Kde uses X11, Cinnamon does not !
KDE can use either X11 or Wayland and Cinnamon only uses X11. You can check with:
echo $XDG_SESSION_TYPE
