As my HDMI to HDMI connection is not working, I am using a USB-C-HDMI which is working but has input lag. From my research that comes from USB-C to HDMI being handled by the CPU instead of GPU, is there a way to adjust that?
Mouse moves quickly normally, mouse clicks and keyboard hits take ages to adjust things
edit: Cant watch videos on the second monitor either, extreme lag.
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=415d8219-ad78-4626-ab10-536750de4619 rw quiet
resume=UUID=5dd48583-a3fe-4bb0-af56-f4678bff9466 udev.log_priority=3
nvidia-drm.modeset=1
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Strix G713RS_G713RS v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G713RS v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713RS.320 date: 07/29/2022
ID-1: BAT0 charge: 86.0 Wh (100.0%) condition: 86.0/90.0 Wh (95.5%)
volts: 17.1 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown
serial: <filter> status: full
System RAM: available: 30.62 GiB used: 7.34 GiB (24.0%)
Info: model: AMD Ryzen 9 6900HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1561 high: 2083 min/max: 1600/4934 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1794 2: 2083
3: 1600 4: 1600 5: 1345 6: 1600 7: 1405 8: 1401 9: 1830 10: 1600 11: 1399
12: 1411 13: 1600 14: 1560 15: 1383 16: 1367 bogomips: 105455
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: ASUSTeK driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm
non-free: 530.xx+ status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: DP-6
empty: HDMI-A-1,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:249c class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5 bus-ID: 05:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 60.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
s-diag: 1245mm (49.01")
Monitor-1: DP-6 mapped: DP-1-0 note: disabled pos: right model: ASUS VG249
serial: <filter> built: 2021 res: 1920x1080 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: BOE Display 0x0a69
built: 2021 res: 2560x1440 hz: 240 dpi: 171 gamma: 1.2
size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Graphics (rembrandt
LLVM 15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
Device-4: Generalplus USB Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2.3:4 chip-ID: 1b3f:2008 class-ID: 0300
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 0489:e0e2
Local Storage: total: 953.87 GiB used: 772.54 GiB (81.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA1T0TFK
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V5MA010 temp: 35.9 C
scheme: GPT
ID-1: / raw-size: 944.77 GiB size: 928.86 GiB (98.32%)
used: 771.38 GiB (83.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 415d8219-ad78-4626-ab10-536750de4619
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: F729-D657
ID-1: swap-1 type: partition size: 8.8 GiB used: 1.16 GiB (13.1%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 5dd48583-a3fe-4bb0-af56-f4678bff9466
Device-1: 1-3:2 info: ASUSTek N-KEY Device type: keyboard
driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:19b6 class-ID: 0301
Device-2: 1-4:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Hub-4: 3-2:2 info: Genesys Logic USB 2.0 Hub / D-Link DUB-H4 ports: 4
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
chip-ID: 05e3:0606 class-ID: 0900
Device-1: 3-2.1:3 info: [Maxxter] USB GAMING MOUSE type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 18f8:1286 class-ID: 0301
Device-2: 3-2.3:4 info: Generalplus USB Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-7: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-9: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-10: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 9-1:2 info: Realtek BillBoard Device type: billboard driver: N/A
interfaces: 1 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 2mA chip-ID: 0bda:2172 class-ID: 1100 serial: <filter>
Hub-11: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 69.2 C mobo: N/A gpu: amdgpu temp: 60.0 C
Fan Speeds (RPM): cpu: 2300
Processes: 386 Uptime: 16m wakeups: 13 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1599 pm: pacman pkgs: 1592 libs: 429 tools: pamac,yay pm: flatpak
pkgs: 7 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.27
