Hi all, this morning I bought a new Hyperdrive hub 18 ports for setup my laptop with multiple monitors, and accidentally it doesn’t work as well.
I tried to installed the Display Link following the guildeline from Arch, and just only one monitor detected. Please help me to have the second monitor work, thank you guys.
xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x49 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 7 associated providers: 0 name:modesetting
╰─ mhwd -li -d ─╯
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Warning: no installed configs for USB devices found!
Bus 002 Device 005: ID 05e3:0754 Genesys Logic, Inc. USB Storage
Bus 002 Device 004: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 002 Device 003: ID 2109:0817 VIA Labs, Inc. USB3.0 Hub
Bus 002 Device 002: ID 2109:0822 VIA Labs, Inc. USB3.1 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 001 Device 003: ID 0bda:5650 Realtek Semiconductor Corp. Integrated Webcam_HD
Bus 001 Device 007: ID 2109:8818 VIA Labs, Inc. USB-C Device
Bus 001 Device 006: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 011: ID 05ac:024f Apple, Inc. Aluminium Keyboard (ANSI)
Bus 001 Device 010: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 001 Device 009: ID 14cd:8601 Super Top 4-Port hub
Bus 001 Device 008: ID 0d8c:0147 C-Media Electronics, Inc. USB Advanced Audio Device
Bus 001 Device 005: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
Bus 001 Device 002: ID 2109:2822 VIA Labs, Inc. USB2.0 Hub
Since you didn’t give any information about your actual system, I can only assume that it doesn’t support more than 2 screens.
Did you allow DP over Thunderbolt/USB-C in the UEFI? Does anything work from the hub?
Fabby
August 2, 2021, 4:02pm
#3
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Thank you, I’ve checked my laptop specs here
╰─ inxi --admin --verbosity=7 --filter --no-host --width ─╯
Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c1592dc9-17bd-4888-89a8-a1acf68797ee rw quiet
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude 5490 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0FDHF4 v: A00 serial: <filter> UEFI: Dell v: 1.10.1
date: 07/19/2019
ID-1: BAT0 charge: 68.0 Wh (100.0%) condition: 68.0/68.0 Wh (100.0%)
volts: 8.6 min: 7.6 model: LGC-LGC8.820 DELL DV9NT type: Li-poly
serial: <filter> status: Full
Device-1: hid-20:73:10:01:02:3a-battery model: MINILA-R Convertible
serial: N/A charge: N/A status: Discharging
RAM: total: 31.22 GiB used: 17.98 GiB (57.6%)
Info: Quad Core model: Intel Core i7-8650U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 8 MiB bogomips: 33615
Speed: 800 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Realtek Integrated Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0bda:5650 class-ID: 0e02 serial: <filter>
loaded: modesetting unloaded: intel display-ID: :0 screens: 1
Screen-1: 0 s-res: 5360x2520 s-dpi: 96 s-size: 1414x665mm (55.7x26.2")
s-diag: 1563mm (61.5")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Monitor-3: DP-1-3 res: 3440x1440 dpi: 110 size: 797x334mm (31.4x13.1")
diag: 864mm (34")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Device-2: C-Media USB Advanced Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.1.1:42
chip-ID: 0d8c:0147 class-ID: 0300
Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: f040 bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f040
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-1.1.3:28 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20f0u1u1u3 state: down mac: <filter>
IF-ID-1: br-41a70c737872 state: down mac: <filter>
IF-ID-2: br-90216388976d state: down mac: <filter>
IF-ID-3: br-f59dda48acb0 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-4: docker0 state: down mac: <filter>
IF-ID-5: vethcd23c22 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: vethd04e321 state: up speed: 10000 Mbps duplex: full mac: <filter>
bus-ID: 1-7:4 chip-ID: 8087:0a2b class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 6 state: up address: <filter>
Local Storage: total: 476.94 GiB used: 352.7 GiB (74.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 SATA 512GB
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: L022 scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.16 GiB (98.22%)
used: 352.7 GiB (75.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: c1592dc9-17bd-4888-89a8-a1acf68797ee
used: 376 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0439-3B99
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Hub-2: 1-1:40 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2822 class-ID: 0900
Hub-3: 1-1.1:41 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 1-1.1.1:42 info: C-Media USB Advanced Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0147 class-ID: 0300
Hub-4: 1-1.1.2:43 info: Super Top 4-Port hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 14cd:8601 class-ID: 0900
Device-1: 1-1.1.2.1:44 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-2: 1-1.5:45 info: VIA Labs USB-C Device type: Billboard driver: N/A
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 2109:8818
class-ID: 1100 serial: <filter>
Device-3: 1-5:3 info: Realtek Integrated Webcam_HD type: Video
Device-4: 1-7:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-6: 2-1:26 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 2109:0822 class-ID: 0900
Hub-7: 2-1.1:27 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 2-1.1.3:28 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.2 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Device-2: 2-1.1.4:29 info: Genesys Logic USB Storage type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
chip-ID: 05e3:0754 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2997
Processes: 431 Uptime: 1d 1h 51m wakeups: 156 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 2026
pacman: 2021 lib: 490 flatpak: 5 Shell: Zsh v: 5.8 running-in: konsole
inxi: 3.3.06
Fabby
August 14, 2021, 8:38am
#5
vuthanhdat:
Try 5.10 LTS and if that doesn’t work, try 5.14 Stable.
vuthanhdat:
multiple monitors
If that’s more than 2: An UHD 620 isn’t the most powerful Graphics chip. Try HD (not UHD) on maximum 2 monitors
This is unrelated to your current issue, but that’s an alert, so please read this:
https://wiki.manjaro.org/index.php?title=Swap
