JohnML
2 December 2021 16:02
1
I’m anxious to loose my working ethernet connection if Kernel 5.13 becomes EOL
I used manjaro-log-helper for two boot protocols.
No chance to use pastebinit, so i uploaded it to my google drive. Hope that works!
You see two boot protocols one with kernel 5.13 ( working ) and the other with faulty kernel 5.10
What is the cause for that issue with kernel 5.10?
Manjaro-helper-log on my google account
You can try kernel 5.14 or kernel 5.15.
The driver, r8152-dkms was updated on 11/19/2021. Have you updated and tried with 5.15 as 5.15 will be the new LTS kernel when 5.16 is marked as stable.
JohnML
2 December 2021 16:38
4
So my google-drive worked? Great
I’ll try that after my Quinoa-meal thats just cooking.
Driver is allways part of kernel, i think?!
I was looking at the driver in the AUR (r8152-dkms), but I would still give 5.15 a look as I think I read that 5.14 is soon to be EOL in one of the announcement threads. You are correct, it is included in the kernel, so the dkms version should not be needed.
JohnML
2 December 2021 17:43
6
Kernel 5.14 and 5.15 did not work!
I have a multiple boot with Win10, Mint, Manjaro (only Kernel 5.13), Deepin they all work flawlessly
For example inxi -F on Mint:
System: Host: Mint Kernel: 5.11.0-40-generic x86_64 bits: 64 Desktop: Cinnamon 5.0.7 Distro: Linux Mint 20.2 Uma
Machine: Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL serial: PF1WPMZJ
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: PF1WPMZJ UEFI: LENOVO v: BYCN29WW date: 10/10/2019
Battery: ID-1: BAT0 charge: 62.6 Wh condition: 65.3/62.0 Wh (105%)
CPU: Topology: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP L2 cache: 8192 KiB
Speed: 882 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 882 2: 804 3: 1073 4: 674 5: 1041 6: 764 7: 972 8: 684
Graphics: Device-1: Intel Iris Plus Graphics G7 driver: i915 v: kernel
Device-2: NVIDIA GP108M [GeForce MX250] driver: nvidia v: 460.91.03
Display: server: X.Org 1.20.11 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce MX250/PCIe/SSE2 v: 4.6.0 NVIDIA 460.91.03
Audio: Device-1: Intel Smart Sound Audio driver: sof-audio-pci
Sound Server: ALSA v: k5.11.0-40-generic
Network: Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter driver: iwlwifi
IF: wlp0s20f3 state: up mac: 04:33:c2:02:de:51
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
IF: enx4ce173421f6b state: up speed: 1000 Mbps duplex: full mac: 4c:e1:73:42:1f:6b
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
IF: enx00e04c680d55 state: down mac: 00:e0:4c:68:0d:55
Drives: Local Storage: total: 1.86 TiB used: 233.44 GiB (12.3%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB
ID-2: /dev/sda type: USB vendor: Western Digital model: WD10EARX-00N0YB0 size: 931.51 GiB
ID-3: /dev/sdb type: USB vendor: Kingston model: DataTraveler 2.0 size: 14.54 GiB
Partition: ID-1: / size: 57.90 GiB used: 14.10 GiB (24.3%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: swap-1 size: 16.67 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p9
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 40 C
Info: Processes: 299 Uptime: 3m Memory: 15.20 GiB used: 926.2 MiB (6.0%) Shell: bash inxi: 3.0.38
No idea what to learn from that?!
kisun
2 December 2021 17:54
7
What driver shows ‘inxi’ in Manjaro 5.13 and 5.14 for this device? Is it the same like here in mint (driver: r8152)?
JohnML
2 December 2021 18:30
8
Kernel 5.13
Kernel 5.14
Network: Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi
IF: wlp0s20f3 state: down mac: c6:3f:14:00:09:bd
IF-ID-1: pan1 state: down mac: 7a:5c:6a:f4:06:56
Kernel 5.15
IF: wlp0s20f3 state: down mac: 0a:b0:52:ea:f4:08
So except Kernel 5.13 the Network driver is NOT loaded … very strange!
Perhaps this driver is missing in these Kernels??
kisun
2 December 2021 18:34
9
For 5.13 and 5.14 you posted the wifi device not the ethernet one. ‘Device-2’ should be the ethernet device which was ‘up’ in mint. Could you correct this?
JohnML
2 December 2021 18:42
10
Have a look at this:
System: Host: manjaro Kernel: 5.14.18-1-MANJARO x86_64 bits: 64 Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO v: BYCN29WW
date: 10/10/2019
Battery: ID-1: BAT0 charge: 63.7 Wh (97.5%) condition: 65.3/62.0 Wh (105.3%)
CPU: Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP cache: L2: 2 MiB
Speed: 1153 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1195 2: 1283 3: 1281 4: 1261 5: 1290 6: 1251 7: 1229
8: 1227
Device-2: NVIDIA GP108M [GeForce MX250] driver: nvidia v: 495.44
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.21.1.1 driver: loaded: modesetting,nvidia unloaded: nouveau resolution:
1: 1920x1080~60Hz 2: 1920x1080~60Hz
Audio: Device-1: Intel Ice Lake-LP Smart Sound Audio driver: sof-audio-pci-intel-icl
Sound Server-1: ALSA v: k5.14.18-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb
Drives: Local Storage: total: 2.08 TiB used: 395.85 GiB (18.6%)
ID-3: /dev/sdb type: USB vendor: SanDisk model: Ultra size: 233.25 GiB
ID-4: /dev/sdc type: USB vendor: Kingston model: DataTraveler 2.0 size: 14.54 GiB
Partition: ID-1: / size: 57.9 GiB used: 35.59 GiB (61.5%) fs: ext4 dev: /dev/nvme0n1p8
ID-2: /boot/efi size: 259.5 MiB used: 114.1 MiB (44.0%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 16.67 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p9
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A
Info: Processes: 274 Uptime: 0m Memory: 15.2 GiB used: 1.88 GiB (12.4%) Shell: Bash inxi: 3.3.09
And this:
System: Host: manjaro Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 Desktop: Xfce 4.16.0 Distro: Manjaro Linux
date: 10/10/2019
Speed: 1110 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1176 2: 1171 3: 1109 4: 1153 5: 1081 6: 1138 7: 1152
8: 1091
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
ID-2: /dev/sda type: USB vendor: SanDisk model: Ultra size: 233.25 GiB
ID-3: /dev/sdb type: USB vendor: Western Digital model: WD10EARX-00N0YB0 size: 931.51 GiB
Partition: ID-1: / size: 57.9 GiB used: 35.58 GiB (61.5%) fs: ext4 dev: /dev/nvme0n1p8
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A
Info: Processes: 279 Uptime: 2m Memory: 15.2 GiB used: 1.87 GiB (12.3%) Shell: Bash inxi: 3.3.09
Conclusion; no Ethernet driver?!!
kisun
2 December 2021 18:47
11
Very strange. Are there any drivers blacklisted in ‘/etc/modprobe.d/’?
JohnML
2 December 2021 19:04
12
Yes, there are three files in this directory:
File1 /etc/modprobe.d/blacklist-john1.conf
# von mir ergänzt laut https://wiki.archlinux.org/index.php/Lenovo_Yoga_c940#Overview
blacklist snd_hda_intel
blacklist snd_soc_skl
File2 blacklist-nvidia-nouveau.conf
blacklist nouveau
options nouveau modeset=0
File 3 mhwd-gpu.conf
## Generated by mhwd - Manjaro Hardware Detection
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
options nvidia "NVreg_DynamicPowerManagement=0x02"
the first *.conf is written from me but i can’t remember anything!
kisun
2 December 2021 19:31
13
There should not be the problem.
It is above my knowledge if ‘inxi’ shows devices only if drivers were available and if kernel 5.14/5.15 has this network driver inbuild.
As @jrichard326 said above there is ‘r8152-dkms’-driver in the AUR. Have your try to use this one? Be sure that kernel headers for the pointed kernel are installed befor installing dkms-driver.
JohnML
2 December 2021 19:48
14
I tested this:
lsmod|grep r8152
For 5.13 it shows:
r8152 131072 1 r8153_ecm
mii 16384 2 usbnet,r8152
For 5.14 it shows NOTHING
I think r8152 is not part of these Kernels? But thats far beyond my knowledge!
I stay with kernel 5.13 as long as possible.
But i don’t know how long that will be.
Perhaps some devs will read that post and can make the correct conclusion … I’m just a user
5.13 already has been declared EOL and will not receive any further updates, see
Hello community,
After a month of hard work, we are happy to present this stable branch update to you, our community! Please take this update with care!
Especially Nvidia Fermi and Keppler users should read the Troubleshoot post to avoid non-loading desktops …
[image]
This brings also our first preview release of 21.2 we call Qonos
We updated our Kernels. Note that 5.13 series is marked EOL and 5.12 got removed!
We added the RC1 of linux516. So far only the Nvidia 470xx driver builds again…
Manjaro does not develop the linux kernel. It’s been declared EOL by linux kernel developers.
I don’t know if this is meaningful, but I find the following in lib/modules on Kernel 5.15.6-1 (unstable):
/usr/lib/modules/5.15.6-1-MANJARO/build/include/linux/usb/r8152.h
have added linux514-headers and linux5.15-headers ?
JohnML
3 December 2021 07:11
18
Yes, they are present because of NVIDIA?!!
trouble on drivers 8152/8153 ??
JohnML
3 December 2021 07:29
20
Yes, see above: USB-C connection … but first breakfast
