I bought this usb-c to ethernet adaptor
https://www.amazon.co.uk/Gigabit-1000Mbps-Ethernet-Adapter-Network/dp/B00LLUEJFU/ref=sr_1_16?dchild=1&keywords=ugreen+adapter&qid=1618917509&sr=8-16
I installed the AX88179 driver from AUR but I still can’t get connectivity.
I get this in my journal:
usb 2-1: device not accepting address 18, error -71
usb usb2-port1: unable to enumerate USB device
Any idea how to fix that?
I have a USB 3 Ethernet adapter that uses AX88179 and I did not have to install any driver for it as it was included in the kernel (as of kernel 3.9). That (Plugable brand) adapter works flawlessly. I have two other Trendnet brand adapters (Asix AX88179)that work flawlessly. An inxi output might help here in diagnosing and fixing the issue.
https://cateee.net/lkddb/web-lkddb/USB_NET_AX88179_178A.html
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
inxi output:
CPU: Quad Core Intel Core i7-8550U (-MT MCP-) speed/min/max: 873/400/4000 MHz Kernel: 5.11.14-1-MANJARO x86_64 Up: 2h 29m
Mem: 3905.4/15709.6 MiB (24.9%) Storage: 476.94 GiB (5.2% used) Procs: 251 Shell: Zsh inxi: 3.3.04
Did you read the page? Your issue is network related and you posted no network information.
Full info bellow.
I’ve plugged in another adapter that does work:
Device-1: 4-2:2 info: Realtek RTL8153 Gigabit Ethernet Adapter type: Network
driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 288mA
So ignore that please.
inxi --admin --verbosity=7 --filter --no-host --width ─╯
Kernel: 5.11.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=05b7f982-7fbf-4054-9c05-fb20c1b5b114 ro quiet apparmor=1
security=apparmor resume=UUID=df2c89a5-46c4-4040-8008-18a0ffd168f9
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Laptop System: Dell product: XPS 13 9370 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0F6P3V v: A00 serial: <filter> UEFI: Dell v: 1.13.1
date: 07/08/2020
ID-1: BAT0 charge: 29.9 Wh (62.7%) condition: 47.7/52.0 Wh (91.8%)
volts: 8.3 min: 7.6 model: SMP DELL G8VCF6C type: Li-poly serial: <filter>
status: Charging
RAM: total: 15.34 GiB used: 3.76 GiB (24.5%)
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 cache: L2: 8 MiB bogomips: 32012
Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 702 7: 796 8: 742
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3288x1080 s-dpi: 96 s-size: 870x286mm (34.3x11.3")
s-diag: 916mm (36.1")
Monitor-1: eDP1 res: 1368x768 hz: 60 dpi: 120 size: 290x170mm (11.4x6.7")
diag: 336mm (13.2")
Monitor-2: DP1 res: 1920x1080 hz: 60 dpi: 80 size: 610x350mm (24.0x13.8")
diag: 703mm (27.7")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.11.14-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
port: f040 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-2:2 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp57s0u2 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 1-7:2
chip-ID: 0489:e0a2 class-ID: e001
Local Storage: total: 476.94 GiB used: 25.04 GiB (5.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KXG50ZNV512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: AADA4102 temp: 45.9 C scheme: GPT
ID-1: / raw-size: 459.76 GiB size: 451.55 GiB (98.21%)
used: 25.03 GiB (5.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 05b7f982-7fbf-4054-9c05-fb20c1b5b114
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: EED6-7A14
ID-1: swap-1 type: partition size: 16.88 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: df2c89a5-46c4-4040-8008-18a0ffd168f9
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:5 info: Samsung USB Type-C HDTV Adapter type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 04e8:a025 class-ID: 1100 serial: <filter>
Device-2: 1-7:2 info: Foxconn / Hon Hai type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0489:e0a2
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.0 C mobo: 43.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 4697
Processes: 259 Uptime: 3h 10m wakeups: 4174 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1275
lib: 385 flatpak: 0 Shell: Zsh v: 5.8 running-in: xfce4-terminal
inxi: 3.3.04
