I have a Thunderbolt hub with HDMI and three USB 3.1 ports.
HDMI works fine.
USB 3 devices work fine.
USB 2 devices are not detected, not listed with lsusb.
Any ideas?
Solved: I was using a USB C extension cable. I flipped the connection between the extension cable and the hub. Problem went away.
Why is always about flipping the cable when it comes to USB? lol
Which authorization type are you using? Not all Thunderbolt hubs are well supported.
It’s weird that USB2 is not working but USB3, which USB2 devices are you talking about?
Coincidentally, right after I read your post and waking up from suspension, my Thunderbolt connection was also dead and only USB3 devices worked after a reboot.
Using the LTS kernel 5.10 fixes this (hopefully for now.)
