Updating Zoom - issues with pamac
Step 1: Dowload zoom_x86_64.tar.xz
I have downloaded the file: zoom_x86_64.tar.xz
Zoom update
Step 2: Using a graphical installer
I don’t manage to open the file with pamac, as written in the instruction. When I double click on it, nothing happens. I cannot choose pamac to open the file.
Step 3: Using the terminal
When I navigate with the Terminal to the Download folder and enter:
sudo pacman -U zoom_x86_64.pkg.tar.xz
I recieve an error message:
“Failed to execute child process. Execution of child process >>/home/user/Downloads/zoom_x86_64.tar.xz<< failed: Failed to execve: Permission denied.”
or just
“sudo: pacmac: command not found.”
Step 4: Trying to resolve “pacman: command not found”
According to this link, I have tried the proposed solutions, none of which worked (the same error message persists:
Step 5: sudo snap refresh zoom-client
I don’t remember how I installed Zoom back then and I followed this guide to enter ‘sudo snap refresh zoom-client’ in the terminal.
How to update ZOOM?
Here I receive the message: “error: snap “zoom-client” is not installed”
Step 6: start pamac
When I manually click on “start pamac” in the search bar of Manjaro, nothing happens.
Step 7: Add/Remove Software.
When I search for pamac in the search bar of Manjaro, I also get “Add/Remove Software” as an option. Is that pamac? If I search for Zoom there, there is no entry.
Please use the search function. There are several threads about especially installing Zoom.
It seems you are mixing installs from all over the places with non existing commands.
There is zoom package in the repository. Make sure your mirrors are updated too
sudo pacman-mirrors -f5
and you install zoom with pacman from terminal with this command, aslo making sure you update the system:
sudo pacman -Syyu zoom
or with pamac with this command:
pamac install zoom
So, what exact command did you use because pacmac does not exist?
Please consider that chasing this all over the places, from different sources installs is not ideal to provide help.
Doesn’t seem so.
https://packages.manjaro.org/?query=zoom
Ah, indeed. My eyesight is getting worse every day, plus i forgot that i have herecura repo enabled and that is from where i get it, as my /etc/pacman.conf has since forever this …
[herecura]
Server = https://repo.herecura.eu/$repo/$arch
So, @Jucala - my above indication only works with herecura enabled if using pacman but if you use AUR then the pamac command still applies.
You enable the AUR in pamac (Add/Remove Software) for it to show in a search.
https://aur.archlinux.org/packages/zoom
This is not an archive in pacman format - for that it has to be <name.pkg.tar.zst>
The simplest method is to run
pamac build zoom
The manual curios way
When one dissect the PKGBUILD from AUR is reveal it’s zoom origin using the older xz compression format.
PKGBUILD details
# Maintainer: Gordian Edenhofer <gordian.edenhofer@gmail.com>
pkgname=zoom
pkgver=5.14.0
_subver=1720
pkgrel=1
pkgdesc="Video Conferencing and Web Conferencing Service"
arch=('x86_64')
license=('custom')
url="https://zoom.us/"
depends=('fontconfig' 'glib2' 'libpulse' 'libsm' 'ttf-font' 'libx11' 'libxtst' 'libxcb'
	'libxcomposite' 'libxfixes' 'libxi' 'libxcursor' 'libxkbcommon-x11' 'libxrandr'
	'libxrender' 'libxshmfence' 'libxslt' 'mesa' 'nss' 'xcb-util-image'
	'xcb-util-keysyms' 'dbus' 'libdrm')
optdepends=('pulseaudio-alsa: audio via PulseAudio'
	'qt5-webengine: SSO login support'
	'ibus: remote control'
	'picom: extra compositor needed by some window managers for screen sharing'
	'xcompmgr: extra compositor needed by some window managers for screen sharing')
options=(!strip)
source=("${pkgname}-${pkgver}.${_subver}_orig_x86_64.pkg.tar.xz"::"https://cdn.zoom.us/prod/${pkgver}.${_subver}/zoom_x86_64.pkg.tar.xz")
sha512sums=('ed2658c93b4b5fbe2014f437162ad62023ab61ca183ce6412f3414b0de349311b0b061659c8ab3c744b0554ceb1ab170ac7b914a6547b2e4aaa123cad1355d58')
prepare() {
	sed -i 's/Zoom\.png/Zoom/g' "${srcdir}/usr/share/applications/Zoom.desktop"
	sed -i 's/StartupWMClass=Zoom/StartupWMClass=zoom/g' "${srcdir}/usr/share/applications/Zoom.desktop"
package() {
	cp -dpr --no-preserve=ownership opt usr "${pkgdir}"
pkgver=5.14.0
_subver=1720
zoompkg=https://cdn.zoom.us/prod/${pkgver}.${_subver}/zoom_x86_64.pkg.tar.xz
curl -O $zoompkg
sudo pacman -U zoom_86_64_pkg.tar.xz
Downloading and installing the package works without any hickups.
