Hello everyone,
I have a habit of adding custom commands like mkcdir (to make dir & do a cd into the newly created directory or combination of ls with it parameters to make shorthands, like ll).
mkcdir example: (taken from unix stackexchange)
mkcdir ()
mkdir -p -- "$1" &&
cd -P -- "$1"
Up until now, I would enter the above function in .bashrc and do a source .bashrc. That would make the change become available in the current bash terminal instance as well as the new ones.
However, in manjaro-gnome-21.2.2 when I add the above mentioned function and do source .bashrc, the change does not stick across terminals.
# ~/.bashrc
[[ $- != *i* ]] && return
colors() {
local fgc bgc vals seq0
printf "Color escapes are %s\n" '\e[${value};...;${value}m'
printf "Values 30..37 are \e[33mforeground colors\e[m\n"
printf "Values 40..47 are \e[43mbackground colors\e[m\n"
printf "Value 1 gives a \e[1mbold-faced look\e[m\n\n"
# foreground colors
for fgc in {30..37}; do
# background colors
for bgc in {40..47}; do
fgc=${fgc#37} # white
bgc=${bgc#40} # black
vals="${fgc:+$fgc;}${bgc}"
vals=${vals%%;}
seq0="${vals:+\e[${vals}m}"
printf " %-9s" "${seq0:-(default)}"
printf " ${seq0}TEXT\e[m"
printf " \e[${vals:+${vals+$vals;}}1mBOLD\e[m"
done
echo; echo
done
[ -r /usr/share/bash-completion/bash_completion ] && . /usr/share/bash-completion/bash_completion
# Change the window title of X terminals
case ${TERM} in
xterm*|rxvt*|Eterm*|aterm|kterm|gnome*|interix|konsole*)
PROMPT_COMMAND='echo -ne "\033]0;${USER}@${HOSTNAME%%.*}:${PWD/#$HOME/\~}\007"'
screen*)
PROMPT_COMMAND='echo -ne "\033_${USER}@${HOSTNAME%%.*}:${PWD/#$HOME/\~}\033\\"'
esac
use_color=true
# Set colorful PS1 only on colorful terminals.
# dircolors --print-database uses its own built-in database
# instead of using /etc/DIR_COLORS. Try to use the external file
# first to take advantage of user additions. Use internal bash
# globbing instead of external grep binary.
safe_term=${TERM//[^[:alnum:]]/?} # sanitize TERM
match_lhs=""
[[ -f ~/.dir_colors ]] && match_lhs="${match_lhs}$(<~/.dir_colors)"
[[ -f /etc/DIR_COLORS ]] && match_lhs="${match_lhs}$(</etc/DIR_COLORS)"
[[ -z ${match_lhs} ]] \
&& type -P dircolors >/dev/null \
&& match_lhs=$(dircolors --print-database)
[[ $'\n'${match_lhs} == *$'\n'"TERM "${safe_term}* ]] && use_color=true
if ${use_color} ; then
# Enable colors for ls, etc. Prefer ~/.dir_colors #64489
if type -P dircolors >/dev/null ; then
if [[ -f ~/.dir_colors ]] ; then
eval $(dircolors -b ~/.dir_colors)
elif [[ -f /etc/DIR_COLORS ]] ; then
eval $(dircolors -b /etc/DIR_COLORS)
fi
fi
if [[ ${EUID} == 0 ]] ; then
PS1='\[\033[01;31m\][\h\[\033[01;36m\] \W\[\033[01;31m\]]\$\[\033[00m\] '
else
PS1='\[\033[01;32m\][\u@\h\[\033[01;37m\] \W\[\033[01;32m\]]\$\[\033[00m\] '
fi
alias ls='ls --color=auto'
alias grep='grep --colour=auto'
alias egrep='egrep --colour=auto'
alias fgrep='fgrep --colour=auto'
else
# show root@ when we don't have colors
PS1='\u@\h \W \$ '
else
PS1='\u@\h \w \$ '
fi
fi
unset use_color safe_term match_lhs sh
#alias cp="cp -i" # confirm before overwriting something
#alias df='df -h' # human-readable sizes
#alias free='free -m' # show sizes in MB
#alias np='nano -w PKGBUILD'
#alias more=less
xhost +local:root > /dev/null 2>&1
# Bash won't get SIGWINCH if another process is in the foreground.
# Enable checkwinsize so that bash will check the terminal size when
# it regains control. #65623
# http://cnswww.cns.cwru.edu/~chet/bash/FAQ (E11)
shopt -s checkwinsize
shopt -s expand_aliases
# export QT_SELECT=4
# Enable history appending instead of overwriting. #139609
shopt -s histappend
# # ex - archive extractor
# # usage: ex <file>
ex ()
if [ -f $1 ] ; then
case $1 in
*.tar.bz2) tar xjf $1 ;;
*.tar.gz) tar xzf $1 ;;
*.bz2) bunzip2 $1 ;;
*.rar) unrar x $1 ;;
*.gz) gunzip $1 ;;
*.tar) tar xf $1 ;;
*.tbz2) tar xjf $1 ;;
*.tgz) tar xzf $1 ;;
*.zip) unzip $1 ;;
*.Z) uncompress $1;;
*.7z) 7z x $1 ;;
*) echo "'$1' cannot be extracted via ex()" ;;
esac
else
echo "'$1' is not a valid file"
fi
# custom aliases
alias ll='ls -alF'
# custom functions
mkcdir ()
mkdir -p -- "$1" &&
cd -P -- "$1"
Output of running source .bashrc
zsh: command not found: shopt
zsh: command not found: complete
/usr/share/bash-completion/bash_completion:1567: parse error near `|'
.bashrc:type:64: bad option: -P
mkcdir & ll works in this instance.
However, in new terminal instances,
$ mkcdir
zsh: correct 'mkcdir' to 'mkdir' [nyae]? n
zsh: command not found: mkcdir
How do I fix this? Please advice. Thank You.
About System:
gnome version: 41.3
Windowing system: X11
