help i dont know what to
> ~ lutris ✔
2022-03-16 22:04:40,190: Starting Lutris 0.5.9.1
2022-03-16 22:04:40,216: No cores found
2022-03-16 22:04:46,237: Startup complete
2022-03-16 22:04:46,237: Running AMD Mesa driver 21.3.7 on AMD Radeon RX 570 Series (POLARIS10, DRM 3.42.0, 5.15.28-1-MANJARO, LLVM 13.0.1) (0x67df)
2022-03-16 22:04:46,238: GPU: 1002:67DF 1849:5026 (amdgpu drivers)
[2022-03-16 22:04:46.260] [MANGOHUD] [info] [config.cpp:114] skipping config: '/usr/bin/MangoHud.conf' [ not found ]
[2022-03-16 22:04:46.260] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/python3.10.conf' [ not found ]
[2022-03-16 22:04:46.260] [MANGOHUD] [info] [config.cpp:119] parsing config: '/home/erick/.config/MangoHud/MangoHud.conf'
2022-03-16 22:04:50,559: Runtime disabled by system configuration
gamemodeauto:
lutris-wrapper: /usr/bin/steam
Started initial process 14078 from /usr/bin/steam WINE_FULLSCREEN_FSR=1 WINE_FULLSCREEN_FSR_STRENGTH=1 %command%
Start monitoring process.
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
steam.sh[14078]: Running Steam on manjarolinux 21.2.5 64-bit
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
steam.sh[14078]: STEAM_RUNTIME is enabled automatically
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
setup.sh[14152]: Steam runtime environment up-to-date!
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
steam.sh[14078]: Steam client's requirements are satisfied
ERROR: ld.so: object '/usr/lib/libgamemodeauto.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Installing breakpad exception handler for appid(steam)/version(1647446817)
Loaded SDL version 2.0.21-7140709
(steam:14212): Gtk-WARNING **: 22:04:53.216: Unable to locate theme engine in module_path: "adwaita",
gamemodeauto:
gamemodeauto:
gamemodeauto:
steamwebhelper.sh[14259]: Runtime for steamwebhelper: defaulting to /home/erick/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
gamemodeauto:
gamemodeauto:
steamwebhelper.sh[14259]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 28 milliseconds to initialize
gamemodeauto:
(steam:14212): GLib-CRITICAL **: 22:04:54.040: g_main_context_push_thread_default: assertion 'acquired_context' failed
(steam:14212): GLib-CRITICAL **: 22:04:54.040: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
(steam:14212): GLib-CRITICAL **: 22:04:54.047: g_main_context_push_thread_default: assertion 'acquired_context' failed
(steam:14212): GLib-CRITICAL **: 22:04:54.047: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
(steam:14212): GLib-CRITICAL **: 22:04:54.097: g_main_context_push_thread_default: assertion 'acquired_context' failed
(steam:14212): GLib-CRITICAL **: 22:04:54.097: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
(steam:14212): Gtk-WARNING **: 22:04:54.166: gtk_disable_setlocale() must be called before gtk_init()
local (potentially out of sync) copy of roaming config loaded - 236 bytes.
gamemodeauto:
INFO: process vulkandriverquery is blacklisted in MangoHud
[2022-03-16 22:04:55.056] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.local/share/Steam/ubuntu12_64/MangoHud.conf' [ not found ]
[2022-03-16 22:04:55.056] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/vulkandriverquery.conf' [ not found ]
[2022-03-16 22:04:55.056] [MANGOHUD] [info] [config.cpp:119] parsing config: '/home/erick/.config/MangoHud/MangoHud.conf'
[2022-03-16 22:04:55.599] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.local/share/Steam/ubuntu12_32/MangoHud.conf' [ not found ]
[2022-03-16 22:04:55.599] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/vulkandriverquery.conf' [ not found ]
[2022-03-16 22:04:55.599] [MANGOHUD] [info] [config.cpp:119] parsing config: '/home/erick/.config/MangoHud/MangoHud.conf'
Connectivity test: result=Connected, in progress=0
roaming config store loaded successfully - 236 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 5ms
(steam:14212): Gtk-WARNING **: 22:04:59.741: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:04:59.741: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
(steam:14212): Gtk-WARNING **: 22:04:59.742: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:04:59.742: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
Failed to init SteamVR because it isn't installed
gamemodeauto:
ExecCommandLine: "'/home/erick/.local/share/Steam/ubuntu12_32/steam' 'WINE_FULLSCREEN_FSR=1' 'WINE_FULLSCREEN_FSR_STRENGTH=1' '%command%'"
System startup time: 7.21 seconds
BuildCompleteAppOverviewChange: 127
(steam:14212): Gtk-WARNING **: 22:05:00.807: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:05:00.807: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
RegisterForAppOverview 1: 7ms
RegisterForAppOverview 2: 7ms
(steam:14212): Gtk-WARNING **: 22:05:01.137: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:05:01.137: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
(steam:14212): Gtk-WARNING **: 22:05:01.139: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:05:01.139: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
ExecuteSteamURL: "steam://open/library/view/home"
(steam:14212): Gtk-WARNING **: 22:05:09.338: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:05:09.338: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
(steam:14212): Gtk-WARNING **: 22:05:09.351: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:05:09.351: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
CAPIJobRequestUserStats - Server response failed 2
GameAction [AppID 4234365375, ActionID 1] : LaunchApp changed task to SynchronizingControllerConfig with ""
(steam:14212): Gtk-WARNING **: 22:05:30.506: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:05:30.506: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
GameAction [AppID 4234365375, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 4234365375, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 4234365375, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 4234365375, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/erick/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=4234365375 -- '/run/media/erick/games for linuxs/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/erick/.local/share/Steam/compatibilitytools.d/GE-Proton7-9'/proton waitforexitandrun "/run/media/erick/games for linuxs/ELDEN RING/Game/eldenring.exe" WINE_FULLSCREEN_FSR=1 WINE_FULLSCREEN_FSR_STRENGTH=1 PROTON_NO_FSYNC=1 gamemoderun %command%\0
Game process added : AppID 0 "/home/erick/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=4234365375 -- '/run/media/erick/games for linuxs/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/erick/.local/share/Steam/compatibilitytools.d/GE-Proton7-9'/proton waitforexitandrun "/run/media/erick/games for linuxs/ELDEN RING/Game/eldenring.exe" WINE_FULLSCREEN_FSR=1 WINE_FULLSCREEN_FSR_STRENGTH=1 PROTON_NO_FSYNC=1 gamemoderun %command%", ProcID 14857, IP 0.0.0.0:0
GameAction [AppID 4234365375, ActionID 1] : LaunchApp changed task to Completed with ""
ERROR: ld.so: object '/home/erick/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
(steam:14212): Gtk-WARNING **: 22:05:30.766: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:05:30.766: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
ERROR: ld.so: object '/home/erick/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
gamemodeauto:
gamemodeauto:
pid 14864 != 14861, skipping destruction (fork without exec?)
(steam:14212): Gtk-WARNING **: 22:05:30.826: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:05:30.826: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
gamemodeauto: dlopen failed - libgamemode.so: cannot open shared object file: No such file or directory
ProtonFixes[15055] INFO: Running protonfixes
ProtonFixes[15055] INFO: Running checks
ProtonFixes[15055] INFO: All checks successful
ProtonFixes[15055] INFO: Using global defaults for UNKNOWN (0)
ProtonFixes[15055] INFO: No protonfix found for UNKNOWN (0)
Game process removed: AppID 0 "/home/erick/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=4234365375 -- '/run/media/erick/games for linuxs/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/erick/.local/share/Steam/compatibilitytools.d/GE-Proton7-9'/proton waitforexitandrun "/run/media/erick/games for linuxs/ELDEN RING/Game/eldenring.exe" WINE_FULLSCREEN_FSR=1 WINE_FULLSCREEN_FSR_STRENGTH=1 PROTON_NO_FSYNC=1 gamemoderun %command%", ProcID 14857
ThreadGetProcessExitCode: no such process 15056
ThreadGetProcessExitCode: no such process 15055
ThreadGetProcessExitCode: no such process 14862
ThreadGetProcessExitCode: no such process 14861
Uploaded AppInterfaceStats to Steam
(steam:14212): Gtk-WARNING **: 22:08:38.003: gtk_disable_setlocale() must be called before gtk_init()
(steam:14212): GLib-CRITICAL **: 22:08:38.003: unquote_string_inplace: assertion 'err == NULL || *err == NULL' failed
ExecuteSteamURL: "steam://open/downloads"
GameAction [AppID 1196590, ActionID 2] : LaunchApp changed task to ProcessingInstallScript with ""
gamemodeauto:
gamemodeauto:
Proton: Upgrading prefix from 7.0-100 to GE-Proton7-9 (/run/media/erick/games for linuxs/SteamLibrary/steamapps/compatdata/1196590/)
Proton: Prefix has an invalid version?! You may want to back up user files and delete this prefix.
fsync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
[2022-03-16 22:09:11.194] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/wine-explorer.conf' [ not found ]
[2022-03-16 22:09:11.194] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.local/share/Steam/compatibilitytools.d/GE-Proton7-9/files/bin/MangoHud.conf' [ not found ]
[2022-03-16 22:09:11.194] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2022-03-16 22:09:11.194] [MANGOHUD] [info] [config.cpp:119] parsing config: '/home/erick/.config/MangoHud/MangoHud.conf'
sh: 1: glxinfo: not found
[2022-03-16 22:09:11.344] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/wine-explorer.conf' [ not found ]
[2022-03-16 22:09:11.344] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.local/share/Steam/compatibilitytools.d/GE-Proton7-9/files/bin/MangoHud.conf' [ not found ]
[2022-03-16 22:09:11.344] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2022-03-16 22:09:11.344] [MANGOHUD] [info] [config.cpp:119] parsing config: '/home/erick/.config/MangoHud/MangoHud.conf'
ERROR: ld.so: object '/run/host/usr/lib/libgamemodeauto.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
wine: configuration in L"/run/media/erick/games for linuxs/SteamLibrary/steamapps/compatdata/1196590/pfx" has been updated.
GameAction [AppID 1196590, ActionID 2] : LaunchApp changed task to RunningInstallScript with ""
Unhandled Exception:
System.IO.DirectoryNotFoundException: Could not find a part of the path "C:\users\steamuser\AppData\Local\Temp\wmpsupport.htm".
at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x00164] in <76a792d7a3364aecae261f1ecb04e91e>:0
at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.IO.FileOptions options) [0x00000] in <76a792d7a3364aecae261f1ecb04e91e>:0
at (wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare,int,System.IO.FileOptions)
at System.IO.StreamReader..ctor (System.String path, System.Text.Encoding encoding, System.Boolean detectEncodingFromByteOrderMarks, System.Int32 bufferSize) [0x00055] in <76a792d7a3364aecae261f1ecb04e91e>:0
at System.IO.StreamReader..ctor (System.String path, System.Boolean detectEncodingFromByteOrderMarks) [0x00007] in <76a792d7a3364aecae261f1ecb04e91e>:0
at System.IO.StreamReader..ctor (System.String path) [0x00000] in <76a792d7a3364aecae261f1ecb04e91e>:0
at (wrapper remoting-invoke-with-check) System.IO.StreamReader..ctor(string)
at System.IO.File.OpenText (System.String path) [0x0000e] in <76a792d7a3364aecae261f1ecb04e91e>:0
at InstallerMessage.Form1.StartupCheck () [0x00012] in <97366582d6c94629b2d1f5de409f2ebd>:0
at InstallerMessage.Form1..ctor () [0x00006] in <97366582d6c94629b2d1f5de409f2ebd>:0
at (wrapper remoting-invoke-with-check) InstallerMessage.Form1..ctor()
at InstallerMessage.Program.Main () [0x0000b] in <97366582d6c94629b2d1f5de409f2ebd>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.IO.DirectoryNotFoundException: Could not find a part of the path "C:\users\steamuser\AppData\Local\Temp\wmpsupport.htm".
GameAction [AppID 1196590, ActionID 2] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 1196590, ActionID 2] : LaunchApp changed task to SynchronizingControllerConfig with ""
GameAction [AppID 1196590, ActionID 2] : LaunchApp changed task to ProcessingShaderCache with ""
Fossilize INFO: Setting autogroup scheduling.
GameAction [AppID 1196590, ActionID 2] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 1196590, ActionID 2] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 1196590, ActionID 2] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 1196590, ActionID 2] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0WINE_FULLSCREEN_FSR=1 WINE_FULLSCREEN_FSR_STRENGTH=1 /home/erick/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1196590 -- '/run/media/erick/games for linuxs/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/erick/.local/share/Steam/compatibilitytools.d/GE-Proton7-9'/proton waitforexitandrun '/run/media/erick/games for linuxs/SteamLibrary/steamapps/common/Resident Evil Village BIOHAZARD VILLAGE/re8.exe'\0
Game process added : AppID 1196590 "WINE_FULLSCREEN_FSR=1 WINE_FULLSCREEN_FSR_STRENGTH=1 /home/erick/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1196590 -- '/run/media/erick/games for linuxs/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/erick/.local/share/Steam/compatibilitytools.d/GE-Proton7-9'/proton waitforexitandrun '/run/media/erick/games for linuxs/SteamLibrary/steamapps/common/Resident Evil Village BIOHAZARD VILLAGE/re8.exe'", ProcID 17017, IP 0.0.0.0:0
gamemodeauto:
gamemodeauto:
pid 17021 != 17018, skipping destruction (fork without exec?)
GameAction [AppID 1196590, ActionID 2] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 1196590, ActionID 2] : LaunchApp changed task to Completed with ""
ProtonFixes[17230] INFO: Running protonfixes
ProtonFixes[17230] INFO: Running checks
ProtonFixes[17230] INFO: All checks successful
ProtonFixes[17230] INFO: Using global defaults for "Resident Evil Village" (1196590)
ProtonFixes[17230] INFO: No protonfix found for "Resident Evil Village" (1196590)
ThreadGetProcessExitCode: no such process 17233
ThreadGetProcessExitCode: no such process 17231
ThreadGetProcessExitCode: no such process 17019
Game process updated : AppID 1196590 "WINE_FULLSCREEN_FSR=1 WINE_FULLSCREEN_FSR_STRENGTH=1 /home/erick/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1196590 -- '/run/media/erick/games for linuxs/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/erick/.local/share/Steam/compatibilitytools.d/GE-Proton7-9'/proton waitforexitandrun '/run/media/erick/games for linuxs/SteamLibrary/steamapps/common/Resident Evil Village BIOHAZARD VILLAGE/re8.exe'", ProcID 17232, IP 0.0.0.0:0
Setting breakpad minidump AppID = 1196590
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198965533111 [API loaded no]
[2022-03-16 22:10:04.824] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/wine-explorer.conf' [ not found ]
[2022-03-16 22:10:04.824] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.local/share/Steam/compatibilitytools.d/GE-Proton7-9/files/bin/MangoHud.conf' [ not found ]
[2022-03-16 22:10:04.824] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2022-03-16 22:10:04.824] [MANGOHUD] [info] [config.cpp:119] parsing config: '/home/erick/.config/MangoHud/MangoHud.conf'
[2022-03-16 22:10:04.946] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/wine-explorer.conf' [ not found ]
[2022-03-16 22:10:04.946] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.local/share/Steam/compatibilitytools.d/GE-Proton7-9/files/bin/MangoHud.conf' [ not found ]
[2022-03-16 22:10:04.946] [MANGOHUD] [info] [config.cpp:114] skipping config: '/home/erick/.config/MangoHud/wine64-preloader.conf' [ not found ]
[2022-03-16 22:10:04.946] [MANGOHUD] [info] [config.cpp:119] parsing config: '/home/erick/.config/MangoHud/MangoHud.conf'
pid 17234 != 17233, skipping destruction (fork without exec?)
Game process removed: AppID 1196590 "WINE_FULLSCREEN_FSR=1 WINE_FULLSCREEN_FSR_STRENGTH=1 /home/erick/.local/s
ThreadGetProcessExitCode: no such process 17297
ThreadGetProcessExitCode: no such process 17273
ThreadGetProcessExitCode: no such process 17250
ThreadGetProcessExitCode: no such process 17241
ThreadGetProcessExitCode: no such process 17238
ThreadGetProcessExitCode: no such process 17236
ThreadGetProcessExitCode: no such process 17232
ThreadGetProcessExitCode: no such process 17230
ThreadGetProcessExitCode: no such process 17018
Game 1196590 created interface STEAMAPPLIST_INTERFACE_VERSION001 / AppList
Game 1196590 created interface STEAMAPPS_INTERFACE_VERSION008 / Apps
Game 1196590 created interface STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
Game 1196590 created interface STEAMHTTP_INTERFACE_VERSION002 / HTTP
Game 1196590 created interface STEAMINVENTORY_INTERFACE_V002 / Inventory
Game 1196590 created interface STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
Game 1196590 created interface STEAMMUSIC_INTERFACE_VERSION001 / Music
Game 1196590 created interface STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
Game 1196590 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
Game 1196590 created interface STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
Game 1196590 created interface STEAMUGC_INTERFACE_VERSION010 / UGC
Game 1196590 created interface STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
Game 1196590 created interface STEAMVIDEO_INTERFACE_V002 / Video
Game 1196590 created interface SteamController006 / Controller
Game 1196590 created interface SteamFriends015 / Friends
Game 1196590 created interface SteamMatchMaking009 / Matchmaking
Game 1196590 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 1196590 created interface SteamNetworking005 / Networking
Game 1196590 created interface SteamUser019 / User
Game 1196590 created interface SteamUtils009 / Utils
Game 1196590 method call count for IClientAppManager::GetAppInstallState : 2
Game 1196590 method call count for IClientUtils::RecordSteamInterfaceCreation : 22
Game 1196590 method call count for IClientUtils::GetSteamUILanguage : 1
Game 1196590 method call count for IClientUtils::GetAppID : 24
Game 1196590 method call count for IClientUser::GetSteamID : 1
[2022-03-16 22:04:50] Startup - updater built Mar 14 2022 19:48:46
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2022-03-16 22:04:51] Loading cached metrics from disk (/home/erick/.local/share/Steam/package/steam_client_me
trics.bin)
[2022-03-16 22:04:51] Using the following download hosts for Public, Realm steamglobal
[2022-03-16 22:04:51] 1. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, so
urce = 'update_hosts_cached.vdf'
[2022-03-16 22:04:51] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100
, source = 'update_hosts_cached.vdf'
[2022-03-16 22:04:51] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source =
'baked in'
[2022-03-16 22:04:51] Checking for update on startup
[2022-03-16 22:04:51] Checking for available updates...
[2022-03-16 22:04:51] Downloading manifest: https://cdn.akamai.steamstatic.com/client/steam_client_ubuntu12
[2022-03-16 22:04:52] Download skipped: /client/steam_client_ubuntu12 version 1647446817, installed version 16
47446817, existing pending version 0
[2022-03-16 22:04:52] Nothing to do
[2022-03-16 22:04:52] Verifying installation...
[2022-03-16 22:04:52] Performing checksum verification of executable files
[2022-03-16 22:04:53] Verification complete
src/common/pipes.cpp (885) : stalled cross-thread pipe.
ASS64): ignored.
assert_20220316221753_104.dmp[20590]: Uploading dump (out-of-process)
/tmp/dumps/assert_20220316221753_104.dmp
src/clientdll/steamclient.cpp (854) : bufRet.TellPut() == sizeof(uint8)
assert_20220316221753_104.dmp[20590]: Finished uploading minidump (out-of-process): success = yes
assert_20220316221753_104.dmp[20590]: response: CrashID=bp-3a411c0e-bd03-45c5-8c1c-104a02220316
assert_20220316221753_104.dmp[20590]: file ''/tmp/dumps/assert_20220316221753_104.dmp'', upload yes: ''CrashID
=bp-3a411c0e-bd03-45c5-8c1c-104a02220316''
Thread "CJobMgr::m_WorkThreadPool:1" (ID 14399) failed to shut down
