Hey guys,
So I have been trying to debug this for 2-3 hours now with no luck. I found some information it might be caused by glibc altho I am not sure if I updated that.
Anyway, both Signal and Wickr don’t work for me. Signal isn’t that much of a problem as I can do flatpak for that, but Wickr is a disaster for my work. Here is what I get as an error:
~ >>> wickrpro [134]
zsh: abort (core dumped) wickrpro
for signal
~ >>> signal-desktop [134]
Set Windows Application User Model ID (AUMID) { appUserModelId: ‘org.whispersystems.signal-desktop’ }
NODE_ENV production
NODE_CONFIG_DIR /snap/signal-desktop/335/opt/Signal/resources/app.asar/config
NODE_CONFIG {}
ALLOW_CONFIG_MUTATIONS undefined
HOSTNAME undefined
NODE_APP_INSTANCE undefined
SUPPRESS_NO_CONFIG_WARNING undefined
SIGNAL_ENABLE_HTTP undefined
userData: /home/gs/snap/signal-desktop/335/.config/Signal
config/get: Did not find user config file, cache is now empty object
x-attr dependncy did not load successfully
config/get: Did not find ephemeral config file, cache is now empty object
making app single instance
Error org.freedesktop.DBus.Error.Failed: cannot set “default-url-scheme-handler” setting to invalid value “sgnl”
zsh: segmentation fault (core dumped) signal-desktop
Hope some help might be provided!
oh here is a system report:
Computer
Processor Intel(R) Xeon(R) CPU W3680 @ 3.33GHz
Memory 32873MB (3764MB used)
Machine Type Tower
Operating System Manjaro Linux
User Name gs (gs)
Date/Time 8.11.2020 (нд) 1:09:32
Display
Resolution 3840x1080 pixels
OpenGL Renderer Radeon RX 580 Series (POLARIS10, DRM 3.38.0, 5.8.18-1-MANJARO, LLVM 10.0.1)
Session Display Server WaylandOperating System
Version
Kernel Linux 5.8.18-1-MANJARO (x86_64)
Version #1 SMP PREEMPT Sun Nov 1 14:10:04 UTC 2020
C Library GNU C Library / (GNU libc) 2.32
Distribution Manjaro Linux
Current SessionUptime 1 hour 8 minutes
Load Average 1,79, 1,78, 1,76
