Update requests for packages built by Manjaro developers
Have modified the package linux-latest on my test VM (KDE-Development Edition)
Dropped linux57 and linux58
Install the linux59
Can’t test Nvidia drivers but I have read the driver works now on Linux Kernel 5.9.x
… but not supported:
add: linux59-nvidia-390xx
with nvidia GPU(390xx branch) and kernel59 i get a black screen, (tty works fine). I can confirm its due to lack of linux59-nvidia-390xx for linux59
Unfortunately, it looks like supporting legacy drivers on Linux 5.9 is not as easy as it sounds.
2 posts were merged into an existing topic: Update requests for packages imported from Arch Linux
It is already in testing and unstable braches. Will make it to stable soon.
Thunderbird released 78.5 to fix security vulnerabilties. (78 branch is available in unstable and testing and was built by @nightmare-2021 )
Thanks a lot for the hard work. I can confirm that Nvidia driver 390 works here in Manjaro testing on a 5.9 kernel:
System:    Kernel: 5.9.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Graphics:  Device-1: NVIDIA GF116 [GeForce GTX 550 Ti] vendor: Gigabyte driver: nvidia v: 390.132
A post was merged into an existing topic: Update requests for packages imported from Arch Linux
Request to update mimic maintained by @philm
And update plasma5-applets-mycroft
Thanks and keep up the good work.
pulseaudio-modules-bt needs to be rebuild against new pulseaudio version 14.
Already updated in arch: https://aur.archlinux.org/packages/pulseaudio-modules-bt/
Last packager is : @philm
PKGBUILD has been updated!PKGBUILD 1.4-4 and later will automatically get the PulseAudio version.
https://aur.archlinux.org/cgit/aur.git/tree/PKGBUILD?h=pulseaudio-modules-bt
lib32-nvidia-utils
This has a dependency of nvidia-455xxx which is no longer avalable. Please Update?
Thy can also be found here
https://www.archlinux.org/packages/multilib/x86_64/lib32-nvidia-utils/
Thunderbird released 78.5.1 to fix security vulnerabilities. Last packager was @nightmare-2021.
Looks like this is now in all branches, thanks to the patch from the Arch bug tracker:
(upstream patch does not apply, it required backporting)
Actually the patch is from Gentoo. You can review it from Thomas Deutschmann’s patchset. It is file 38.
Weird. I don’t remember seeing the Gentoo email address when I looked at it, so unless a new commit history was force-pushed I must have been mistaken. :man_shrugging:
Still - it’s a bit strange that a patch pushed last week (when 83 was released):
has been replaced by one pushed yesterday (at the same time as the patch log for TB 78.5.1):
But, who knows. After all, what would be the point of trying to re-write a git history to hide the use of a certain source for a patch?
Hello @Ste74 - I’ve updated mutter-x11-scaling to 3.38.2. But i had to fix the latest upstream patch to compile with 3.38.2 - the Ubuntu developer is informed and it will be hopefully fixed upstream soon. There is also thanks to feedback from Ubuntu now a patched gnome-control-center-x11-scaling build with fixes for multi-monitor management and the toggle option from Ubuntu in case you are interested.
Cheers
Thank you, i look into it…
:+1:
Edit: added both on our repo :wink:
I think that Shotcut needs to be updated from 20.11.14 to 20.11.28:
I quote myself from such discussion:
While I was searching for a solution, firtsly I tried to replace mlt from community repo to AUR, but the problem was still there; then I downloaded a new release of Shotcut from the official repo: v20.11.28 Releases · mltframework/shotcut · GitHub
And all errors went away.
Furthermore, seems that Shotcut, now also needs rtaudio package.
I see that the last packager was Filipe Laíns.
EDIT
I see that Shotcut 20.11.28 has hit the unstable and testing repo this morning; such quick action :slight_smile:
2020-12-07_17-05
Can be also pushed to Stable branch?
For now I manually updated it from testing repo, don’t worry :+1:
A post was split to a new topic: Requesting kernel module build options
The nvidia driver needs an update, it is now at 460.32.03.
