Update requests for packages built by Manjaro developers
it’s mobile repo, Reported in good category
@cfinnberg, linux64 not exists :wink: and linux64-broadcom-wl is removed (your last sync is too old)
As I said, this was me playing around with Manjaro databases. I have personally not installed any of the packages mentioned in there.
That’s the thing. plasma-dialer is in the repos and is dependant on a package that is not.
Well, it’s also normal x86_64 / stable branch.
PS: I don’t know why post had “plasma” and “kde” tags, as I’m fairly sure I didn’t select anything when creating it.
Thanks for doing that, I didn’t have time to fully address this earlier.
@cfinnberg I’ve merged your topic here. I appreciate you letting us know.
It is now since I saw his post earlier. :wink:
I have also removed beelink-kde-settings and minisforum-kde-settings. The related OEM ISO profiles were dropped recently and those packages were just missed leftovers.
Regarding Plasma Mobile packages: Unfortunately, upstream ARM development for mobile devices lately has been slow. Therefore ALARM and Manjaro ARM packaging has also been slow. Some Plasma Mobile and Phosh packages are also in the x86_64 repos as well for some tablets supporting that architecture.
By the way, I’m still mystified why certain tags seem to be automatically applied as well. Apparently it’s some new Discourse “feature”.
Can I ask what tool is that?
Edit: Ok. I should look up myself instead of asking :smiley: It’s in manjaro-check-repos and I have it already installed :smiley:
$ sudo pacman -Fyx bin/mbn
 core        2.4 MiB  3.53 MiB/s 00:01 [##################################################################] 100%
 extra        41.5 MiB  6.92 MiB/s 00:06 [##################################################################] 100%
 multilib        218.3 KiB   624 KiB/s 00:00 [##################################################################] 100%
usr/bin/mbn is owned by extra/manjaro-check-repos 0.9.9-3
usr/bin/mbn-gui is owned by extra/manjaro-check-repos 0.9.9-3
Yeah, I noticed (almost the same way :slight_smile: ). Thanks!
A post was merged into an existing topic: Update requests for packages imported from Arch Linux
Per the recent pipewire-pulse update (and subsequent bug report), noisetorch needs to have its dependencies updated, otherwise it blocks updates.
dependency pulseaudio needs to be changed to pulse-native-provider.
FYI: noisetorch does not appear listed in the manjaro gitlab, but it was built by manjaro team:
noisetorch package info
$ pacman -Qi noisetorch
Version         : 0.12.2-2
Description     : Real-time microphone noise suppression on Linux.
Architecture    : x86_64
URL             : https://github.com/noisetorch/NoiseTorch
Licenses        : GPL3
Groups          : None
Provides        : noisetorch
Depends On      : pulseaudio  polkit  hicolor-icon-theme
Optional Deps   : None
Required By     : None
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 7.17 MiB
Packager        : Philip Mueller <philm@manjaro.org>
Build Date      : Fri 26 Apr 2024 11:51:15 AM MDT
Install Date    : Fri 24 May 2024 07:00:17 PM MDT
Install Reason  : Explicitly installed
Install Script  : Yes
Validated By    : Signature
EDIT:
@philm thank you for updating noisetorch! looks like you missed the testing repo:
$ mbn info noisetorch -q
Branch         : unstable
Version        : 0.12.2-4
Repository     : extra
Build Date     : Thu 08 Aug 2024 03:53:09
Branch         : testing
Version        : 0.12.2-2   # <------------------------- !!!
Repository     : extra
Branch         : stable
Version        : 0.12.2-4
Repository     : extra
AUR            : ------
Version        : 0.12.2-4
Date           : Mon 05 Aug 2024 19:16:35
Url            : https://aur.archlinux.org/packages/noisetorch
Looks like manjaro-gnome-extension-settings might need attention.
Also it appears Testing kernels were skipped?
Stable branch has linux66 v 6.6.47-1
Testing branch has linux66 v 6.6.46-1
https://manjaristas.org/branch_compare?q=linux66
:package: :white_check_mark:
@philm :point_up:
@Yochanan
Seems on Testing mutter-x11-scaling does not match the gnome version.
Turns out 46.5-1 got lost in the shuffle. I just pushed 46.5-2 to testing.
New version of ZFS 2.3 released: Release zfs-2.3.0 · openzfs/zfs · GitHub
As this topic https://forum.manjaro.org/t/update-requests-for-packages-imported-from-arch-linux is not suitable for the description (this package is not in the Arch repository) I will ask here, can you update the appropriate packages ?
Thanks.
Most likely not. Zfs has still the older series maintained. It is better to wait on couple of point releases before you update a filesystem.
Please update manjaro-settings-manager to show kernel 6.12 as LTS + Recommended
A post was merged into an existing topic: Why is no kernel past linux66 recommended yet?
nvidia-driver-assistant is outdated FYI (current version is 0.9.57.01-1_all.deb while 0.18.86.15-1_all.deb is available; Index of /compute/cuda/repos/ubuntu2404/x86_64)
:white_check_mark: Coming along soon with manjaro-settings-manager 0.5.8-1.
:white_check_mark: Thanks, updated.
