Update Problem with ceph-libs 15.2.17-1 -> 16.2.7-1
[jake@P3 ~]$ yay -Syu
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
warning: aiksaurus: ignoring package upgrade (1.2.1-7 => 1.2.1-9)
warning: wine: ignoring package upgrade (5.9-1 => 7.18-1)
 there is nothing to do
:: Searching databases for updates...
:: Searching AUR for updates...
 -> aiksaurus: ignoring package upgrade (1.2.1-7 => 1.2.1-9)
 -> wine: ignoring package upgrade (5.9-1 => 7.18-1)
 -> Missing AUR Packages:  manjaro-documentation-en  manjaro-firmware
 -> Orphaned AUR Packages:  libguess
:: 1 Packages to upgrade.
1  aur/ceph-libs  15.2.17-1 -> 16.2.7-1
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
Odd issue on current Manjaro xfce/GPD Pocket 3–building ceph took five hours before it failed.
I use yay to rebuild Chrome, while querying pacman says “there is nothing to do.”
Should I keep pushing this ceph upgrade?
Do you need it?
If not, you should remove it before updating.
PS: See other threads about this, by searching.
Thank you for a lightening-fast response. I certainly don’t need ceph. From your link, I see that other users have uninstalled it rather than ignore it in pacman.conf. Which would you recommend given that it doesn’t appear necessary to my setup?
Thanks again.
Removing it would be my recommendation. I don’t have it on my installs. So rather save the space.
Great. Thanks for bringing me up to speed. Will mark your last post as the solution.
