Update of manjaro-keyring gave errors
Today, in Pamac, I got the update of the package manjaro-keyring (20220421-1), and at the end of installation I got a window which said:
Error while configuring manjaro-keyring
These are the logs:
Resolving dependencies...
Checking inter-conflicts...
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Installing manjaro-keyring (20220421-1)...
==> Appending keys from manjaro.gpg...
gpg: error reading key: No public key
==> Disabling revoked keys in keyring...
  -> Disabled 2 keys.
==> Updating trust database...
gpg: next trustdb check due at 2022-05-02
Are just warnings or something gone bad?
EDIT: furthermore, if I execute sudo pacman-key --refresh-keys I get a lot of “no data” and “Connection refused”.
I’ve had the same errors, and I’ve applied the same solution, but I’m still getting those same errors when reinstalling manjaro-keyring.
I had the exact same error updating manjaro-keyring this morning in pamac.
I refreshed the keys and then reinstalled manjaro-keyring and got the same error:
(1/1) reinstalling manjaro-keyring                      [#############################] 100%
gpg: public key DB323392796CA067 is 3037 days newer than the signature
  -> Disabled 2 keys.
(1/2) Arming ConditionNeedsUpdate...
(2/2) Refreshing PackageKit...
manjaro-keyring update via pamac GUI pops up error messages, yet the update appears to have succeded? “Transaction successfully finished.”
Preparing...
Download of manjaro-keyring (20220421-1) started
Download of manjaro-keyring (20220421-1) finished
Checking keyring...
Upgrading manjaro-keyring (20210910-2 -> 20220421-1)...
  -> Disabled 2 keys.
I thought I’d try re-installl manjaro-keys just to be certain that “all was well”… and it pops up the errors again…
Yeah! Same here, so I’m not the unique one! The Manjaro Keyring update came in today, not within the usual monthly update. Have a nice day!..
I had an update for Thunderbird today and got the keyring issue:
Vorbereitung...
Synchronisiere Paketdatenbanken...
Warnung: libreoffice-fresh-rpm: ignoring package upgrade (6.4.7-2 => 7.3.0-1)
Warnung: lib32-mesa: Lokale Version (22.0.0-1) ist neuer als multilib (21.3.8-2)
Warnung: manjaro-hello: Lokale Version (0.6.7-2) ist neuer als extra (0.6.6-11)
Warnung: python-pyqt5: Lokale Version (5.15.6-7.1) ist neuer als extra (5.15.6-7)
Abhängigkeiten werden aufgelöst...
Interne Konflikte werden ĂĽberprĂĽft...
Herunterladen von manjaro-keyring (20220421-1) gestartet
Herunterladen von manjaro-keyring (20220421-1) beendet
ĂśberprĂĽfe SchlĂĽsselring...
Integrität wird überprüft...
Paketdateien werden geladen...
Dateikonflikte werden ĂĽberprĂĽft...
ĂśberprĂĽfe verfĂĽgbaren Speicherplatz...
Erneuere manjaro-keyring (20210910-2 -> 20220421-1)...
==> FĂĽge SchlĂĽssel aus manjaro.gpg hinzu...
gpg: error reading key: Kein öffentlicher Schlüssel
Fehler beim Konfigurieren von manjaro-keyring
==> Mache widerrufene SchlĂĽssel im SchlĂĽsselbund unbrauchbar...
  -> Disabled 2 keys.
==> Aktualisiere Trust-Datenbank...
gpg: nächste "Trust-DB"-Pflichtüberprüfung am 2022-05-02
Herunterladen von thunderbird-i18n-de (91.8.1-1) gestartet
Herunterladen von thunderbird (91.8.1-0.1) gestartet
Herunterladen von thunderbird-i18n-de (91.8.1-1) beendet
Herunterladen von thunderbird-i18n-en-us (91.8.1-1) gestartet
Herunterladen von thunderbird-i18n-en-us (91.8.1-1) beendet
Herunterladen von thunderbird (91.8.1-0.1) beendet
Starte Pre-Transaction-Hooks...
Remove Thunderbird Distribution Settings
Erneuere thunderbird (91.8.0-1 -> 91.8.1-0.1)...
Erneuere thunderbird-i18n-de (91.8.0-1 -> 91.8.1-1)...
Erneuere thunderbird-i18n-en-us (91.8.0-1 -> 91.8.1-1)...
Starte Post-Transaction-Hooks...
Updating icon theme caches...
Copy Thunderbird Distribution Settings
Updating the desktop file MIME type cache...
Vorgang erfolgreich abgeschlossen.```
Up to now, I did not anything else. Please advice, in case I should ...
Thank You!
When updating Manjaro today, using pamac:
reinstalling manjaro-keyring [########################################] 100%
   -> Disabled 2 keys.
gpg: next trust database check on 2022-05-02
+1
thunderbird keyring is corrupt
Same here, the manjaro-keyring update (or was it manjaro-pgp?) was packaged with the Thunderbird update for me too. However when I refresh to find new updates, it says everything is up to date. So I’m assuming it’s all fine for now.
I didn’t backup my system with timeshift… should i worried about this update?
Is it safe to restart my PC, after this error?
I just try to update a single package, few KB and got a error in Pamac UI.
Preparing...
Warning: lib32-mesa: local (22.0.0-1) is newer than multilib (21.3.8-2)
Warning: manjaro-hello: local (0.6.7-2) is newer than extra (0.6.6-11)
Warning: python-pyqt5: local (5.15.6-7.1) is newer than extra (5.15.6-7)
Checking keyring...
  -> Disabled 2 keys.
Should i worry, that my system won’t boot after a restart?
I encountered the same problem concerning the manjaro-keyring as well. Why do I have to restart at all?
You don’t have to. Just wait for the next update which should fix this.
would be nice if there were news from the manjaro-team if this issue will/is solved. actually the updatemanager still resides on the keyring-update that causes the failures. will it be fixed soon ?
Atleast i have no see any issues yet from this update errors.
I too am waiting for a solution. Hopefully we get some news or a fix soon.
same problem here i tried doing
but it just get stuck mid way
Yay! i got fixed i just reset all key and readd them by using following command
Remove all keys
sudo rm -rf /etc/pacman.d/gnupg
Reinitialize files & folders for keys
sudo pacman-key --init
Repopulate keys
sudo pacman-key --populate archlinux manjaro
Reinstall latest keyrings
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
Refresh the signature keys
Now you can upgrade your packages
sudo pacman -Syu
When I execute sudo pacman-key --refresh-keys I still get a lot of “No data” and “Connection timed out”.
