If you can’t download pacman-static inside chroot, you could download it outside and copy it to the mounted location and use it then.
After the update, I would recommend reinstalling all your packages, something really bad happened during the update.
However, if this fails, you probably ran out of disk space or broken RAM or disk during the update and fixing it might take insufferable more time than a new install.
Olli
23 April 2022 11:15
25
same here. tried the same steps of @shadowsofnoxus yesterday with no success. don’t know but the keyrings are corrupted.
What have to do, pacman-static, with the keyrings?
bekzclz11:
broken RAM or disk
Nope: the hardware is sane.
Furthermore the mentioned issue has been encoutnered also by other people in this discussion.
I think today comes an update that solves this issue, can someone confirm?
In previous updates philm said:
You may have problems installing this update if the maintenance keys are missing
A possible solution could be:
sudo rm -r /etc/pacman.d/gnupg
sudo pacman-key --init
sudo pacman-key --populate manjaro
sudo pacman-key --populate archlinux
sudo pacman -Syvv manjaro-keyring # just to test for key-problems, as this would fail
However, we recommend to remove the signatures of the failed packages in /var/cache/pacman/pkg/ and get the replaced ones from Build-Server :
sudo rm -v /var/cache/pacman/pkg/*.sig
sudo pacman -Syvv
I had this error crop up, but didn’t fiddle with anything the last few days because I’ve been busy. When I ran this command it updated the keys and as far as I can tell everything is updating and working for me.
vini
25 April 2022 00:19
30
Problem started with (through GUI, did reinstall, no solution):
Preparing...
Warning: manjaro-keyring-20220421-1 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Using system disk as snapshot device for creating snapshots in BTRFS mode
/dev/dm-0 is mounted at: /run/timeshift/backup, options: rw,relatime,ssd,space_cache=v2,subvolid=5,subvol=/
Creating new backup...(BTRFS)
Saving to device: /dev/dm-0, mounted at path: /run/timeshift/backup
Created directory: /run/timeshift/backup/timeshift-btrfs/snapshots/2022-04-25_03-00-28
Created subvolume snapshot: /run/timeshift/backup/timeshift-btrfs/snapshots/2022-04-25_03-00-28/@
Created subvolume snapshot: /run/timeshift/backup/timeshift-btrfs/snapshots/2022-04-25_03-00-28/@home
Created control file: /run/timeshift/backup/timeshift-btrfs/snapshots/2022-04-25_03-00-28/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2022-04-25_03-00-28': ondemand
Removing snapshot: 2022-04-17_03-05-18
Deleting subvolume: @home (Id:988)
Deleted subvolume: @home (Id:988)
Destroying qgroup: 0/988
Destroyed qgroup: 0/988
Deleting subvolume: @ (Id:987)
Deleted subvolume: @ (Id:987)
Destroying qgroup: 0/987
Destroyed qgroup: 0/987
Deleted directory: /run/timeshift/backup/timeshift-btrfs/snapshots/2022-04-17_03-05-18
Removed snapshot: 2022-04-17_03-05-18
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Detecting snapshots ...
Found snapshot: 2022-04-25 03:00:29 | timeshift-btrfs/snapshots/2022-04-25_03-00-28/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2022-04-25 03:00:02 | timeshift-btrfs/snapshots/2022-04-25_03-00-02/@ | boot | N/A |
Found snapshot: 2022-04-25 02:53:52 | timeshift-btrfs/snapshots/2022-04-25_02-53-52/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2022-04-25 02:53:25 | timeshift-btrfs/snapshots/2022-04-25_02-53-25/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2022-04-24 22:00:01 | timeshift-btrfs/snapshots/2022-04-24_22-00-01/@ | daily | N/A |
Found snapshot: 2022-04-24 20:00:01 | timeshift-btrfs/snapshots/2022-04-24_20-00-01/@ | weekly | N/A |
Found snapshot: 2022-04-23 22:00:01 | timeshift-btrfs/snapshots/2022-04-23_22-00-01/@ | daily | N/A |
Found snapshot: 2022-04-23 15:48:56 | timeshift-btrfs/snapshots/2022-04-23_15-48-56/@ | boot | N/A |
Found snapshot: 2022-04-22 22:00:02 | timeshift-btrfs/snapshots/2022-04-22_22-00-02/@ | daily | N/A |
Found snapshot: 2022-04-22 14:59:36 | timeshift-btrfs/snapshots/2022-04-22_14-59-36/@ | boot | N/A |
Found snapshot: 2022-04-21 22:00:02 | timeshift-btrfs/snapshots/2022-04-21_22-00-02/@ | daily | N/A |
Found snapshot: 2022-04-21 15:31:34 | timeshift-btrfs/snapshots/2022-04-21_15-31-34/@ | boot | N/A |
Found snapshot: 2022-04-20 22:00:02 | timeshift-btrfs/snapshots/2022-04-20_22-00-02/@ | daily | N/A |
Found snapshot: 2022-04-17 20:00:01 | timeshift-btrfs/snapshots/2022-04-17_20-00-01/@ | weekly | N/A |
Found snapshot: 2022-04-17 11:37:02 | timeshift-btrfs/snapshots/2022-04-17_11-37-02/@ | boot | N/A |
Found snapshot: 2022-04-16 02:00:02 | timeshift-btrfs/snapshots/2022-04-16_02-00-02/@ | hourly | N/A |
Found snapshot: 2022-04-16 01:00:01 | timeshift-btrfs/snapshots/2022-04-16_01-00-01/@ | hourly | N/A |
Found snapshot: 2022-04-16 00:00:02 | timeshift-btrfs/snapshots/2022-04-16_00-00-02/@ | hourly | N/A |
Found snapshot: 2022-04-10 20:00:01 | timeshift-btrfs/snapshots/2022-04-10_20-00-01/@ | weekly | N/A |
Found snapshot: 2022-03-27 20:00:02 | timeshift-btrfs/snapshots/2022-03-27_20-00-01/@ | monthly | N/A |
Found 20 snapshot(s)
Unmount /tmp/grub-btrfs.vBQ7pxCcz0 .. Success
done
Reinstalling manjaro-keyring (20220421-1)...
==> Appending keys from manjaro.gpg...
gpg: error reading key: No public key
Error while configuring manjaro-keyring
==> Disabling revoked keys in keyring...
-> Disabled 2 keys.
==> Updating trust database...
gpg: next trustdb check due at 2022-05-02
Arming ConditionNeedsUpdate...
Refreshing PackageKit...
sudo pacman -Syvv manjaro-keyring outputs the same.
Tried @shadowsofnoxus solution, but
sudo pacman-key --populate archlinux manjaro
outputs:
sudo pacman-key --populate archlinux manjaro ✔
==> Appending keys from archlinux.gpg...
-> Disabled 2 keys.
Today I received an update of archlinux-keyring and went fine without errors.
The errors remains, however, for manjaro-keyring, which is packaged by philm, so I ping @philm : did you take a look on this package?
Are there any updates to fix this problem?
did you tried these commands:
sudo pacman -Syvv
sudo pacman -Syu
Do you actually have an error?
pamac reinstall manjaro-keyring archlinux-keyring should fix this. (Update your mirrors first.)
I am still getting the same error:
Reinstalling manjaro-keyring (20220421-1)... [1/2]
-> Disabled 2 keys.
gpg: next trustdb check due at 2022-05-06
Reinstalling archlinux-keyring (20220424-1)... [2/2]
Arming ConditionNeedsUpdate... [1/2]
Refreshing PackageKit... [2/2]
This did not work for me.
I think it was successful - it worked as it should have.
Feedback is important.
What responses did you get?
again: I think it worked and the
wasn’t needed
I posted the output above so there is nothing else to add.
The arch keyring reinstallation appears to work fine but there is still a gpg error for the manjaro keyring. There is nothing else for me to post other than what I pasted above when I tried to reinstall it.
yes, but the result is a successful transaction
IDK about the error messages in between.
It looks like the end result is fine.
That can be safely ignored. It just means there are two expired keys in the keyring. One is from a previous team member who’s very few remaining packages have been resigned and one is a current team member that currently has no packages in the repo.
Is it normal for it to continue disabling the two when syvv manjaro-keyring is ran?
The issue has been resolved with manjaro-keyring 20220503-1.
system
Closed
6 May 2022 04:29
43
