Today Pamac prompted me to update, one of the apps was zsh-theme-powerlevel10k coming from AUR.
However, when I proceeded to update, I was prompted with the following:
The PGP key 8B060F8B9EB395614A669F2A90ACE942EB90C3DD is needed to verify zsh-theme-powerlevel10k source files.
Trust Roman Perepelitsa roman.perepelitsa@gmail.com and import the PGP key ?
I’m not familiar of who is who, and basic check shows that zsh-theme-powerlevel10k is maintained by yochananmarqos, packaged by Mark Wagie.
The name Roman Perepelitsa does not fit anywhere.
Naturally, I rejected the prompt, and here was the outcome:
Building zsh-theme-powerlevel10k...
==> Making package: zsh-theme-powerlevel10k 1.20.0-4 (Sun 23 Feb 2025 05:24:06 AM +08)
==> Retrieving sources...
-> Updating powerlevel10k git repo...
-> Found libgit2-tag-2ecf33948a4df9ef45a66c68b8ef24a5e60eaac6.tar.gz
powerlevel10k ... Passed
libgit2-tag-2ecf33948a4df9ef45a66c68b8ef24a5e60eaac6.tar.gz ... Passed
==> Verifying source file signatures with gpg...
powerlevel10k git repo ... FAILED (unknown public key 90ACE942EB90C3DD)
==> ERROR: One or more PGP signatures could not be verified!
Failed to build zsh-theme-powerlevel10k
I usually do not install anything from AUR explicitly.
And this app was “installed as a dependency for another package”.
So, is some app installed as official repo, got moved to AUR without user’s consent?
I updated my Pamac, and it is not present in official repo.
sudo pacman-mirrors --continent && sudo pacman -Syu INT ✘ 1m 55s
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
0.528 Bangladesh : http://mirror.xeonbd.com/manjaro/
0.451 Bangladesh : https://bd.mirror.vanehost.com/Manjaro/
1.429 China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
0.214 Indonesia : http://kartolo.sby.datautama.net.id/manjaro/
0.484 Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
0.645 Japan : https://mirror.phoepsilonix.love/manjaro/
0.636 Taiwan : http://free.nchc.org.tw/manjaro/
0.500 Taiwan : https://mirror.archlinux.tw/Manjaro/
::INFO Writing mirror list
::Indonesia : http://kartolo.sby.datautama.net.id/manjaro/stable
::Bangladesh : https://bd.mirror.vanehost.com/Manjaro/stable
::Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::Taiwan : https://mirror.archlinux.tw/Manjaro/stable
::Bangladesh : http://mirror.xeonbd.com/manjaro/stable
::Taiwan : http://free.nchc.org.tw/manjaro/stable
::Japan : https://mirror.phoepsilonix.love/manjaro/stable
::China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core is up to date
extra is up to date
multilib is up to date
warning: lua-luarepl: unknown key '%CHECKDEPENDS%perln' in sync database
error: could not read db 'extra' (Damaged tar archive)
^C
Interrupt signal received
Is the archive damaged at my end, or the server’s end?
sudo pacman -Scc INT ✘ 10s
Cache directory: /var/cache/pacman/pkg/
:: Do you want to remove ALL files from cache? [y/N] y
removing all files from cache...
Database directory: /var/lib/pacman/
:: Do you want to remove unused repositories? [Y/n] y
removing unused sync repositories...
sudo pacman -Syu zsh-theme-powerlevel10k ✔ 18s
core is up to date
extra is up to date
error: target not found: zsh-theme-powerlevel10k
bash <(curl -s https://gitlab.com/cscs/mapare/-/raw/main/mapare) -K 1 ✘ 9s
Manjaro Package Restore
Retrieve and reinstall package lists
Keyring Assistant
Clearing the package cache may be useful to remove corrupted packages.
Remove unused repositories and ALL files from cache (y/N)? y
Done
Remove local pacman keys (y/N)? y
Done
Download current keyring packages (y/N)? y
Done
Install downloaded keyring packages (y/N)? y
loading packages...
warning: archlinux-keyring-20250123-1 is up to date -- reinstalling
warning: manjaro-keyring-20230719-3 is up to date -- reinstalling
resolving dependencies...
Packages (2) archlinux-keyring-20250123-1 manjaro-keyring-20230719-3
Total Installed Size: 1.77 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(2/2) checking keys in keyring [###########################################################################] 100%
(2/2) checking package integrity [###########################################################################] 100%
(2/2) loading package files [###########################################################################] 100%
(2/2) checking for file conflicts [###########################################################################] 100%
(2/2) checking available disk space [###########################################################################] 100%
(1/2) reinstalling archlinux-keyring [###########################################################################] 100%
(2/2) reinstalling manjaro-keyring [###########################################################################] 100%
>>> Run `pacman-key --init` to set up your pacman keyring.
>>> Then run `pacman-key --populate manjaro` to install the Manjaro keyring.
(1/4) Reloading system manager configuration...
(2/4) Restarting marked services...
(3/4) Arming ConditionNeedsUpdate...
(4/4) Refreshing PackageKit...
Done
Initialize and populate keys (y/N)? y
gpg: /etc/pacman.d/gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
gpg: starting migration from earlier GnuPG versions
gpg: porting secret keys from '/etc/pacman.d/gnupg/secring.gpg' to gpg-agent
gpg: migration succeeded
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/22F8529999FDDF186367C0516B5A3E9D4E1550D3.rev'
gpg: Done
==> Updating trust database...
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 0 trust: 0-, 0q, 0n, 0m, 0f, 1u
==> Appending keys from manjaro.gpg...
==> Appending keys from archlinux.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signed 23 keys.
==> Importing owner trust values...
gpg: inserting ownertrust of 4
gpg: setting ownertrust to 4
==> Disabling revoked keys in keyring...
-> Disabled 53 keys.
gpg: Note: third-party key signatures using the SHA1 algorithm are rejected
gpg: (use option "--allow-weak-key-signatures" to override)
gpg: depth: 0 valid: 1 signed: 20 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 20 signed: 101 trust: 0-, 0q, 0n, 20m, 0f, 0u
gpg: depth: 2 valid: 78 signed: 21 trust: 78-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2025-06-16
Done
Reset mirror pool (y/N)? y
The update list is long, so I will just skip this part.
Again, long list, so I will skip.
core is up to date
extra is up to date
If those steps go okay, then you should have a new /var/lib/pacman/sync directory with the databases in it, and you can remove the /var/lib/pacman/sync.old directory:
sudo rm -fr /var/lib/pacman/sync.old
You should then refresh your Pamac databases. Leave the AUR out of it for this first step:
