Update issue with zsh-theme-powerlevel10k
Done.
Proceeded OK.
Done.
Error: could not read db 'extra' (Damaged tar archive)
Warning: lua-luarepl: unknown key '%CHECKDEPENDS%perln' in sync database
Nothing to do.
The console generated too much error in short time, and overflooded the screen.
Okay - to me that looks like you might have a bad mirror set in Pamac. Open the Pamac GUI, then open the Preferences. On the “General” tab, scroll down to “Official Repositories” and change “Use mirrors from” to Global.
Then close the Pamac GUI and run the
pamac update --no-aur --force-refresh
command again, and if that works, run the final command
pamac update --aur --force-refresh
The original is already set as “Worldwide”.
So there is nothing to do.
pamac update --no-aur --force-refresh         ✔
Preparing...
Authenticating as: Usagi (shurato77)
Password:
Refreshing core.db...
Refreshing extra.db...
Refreshing multilib.db...
Refreshing core.files...
Refreshing extra.files...
Refreshing multilib.files...
The error continues non-stop.
Nothing to do.
:man_facepalming:
We’re getting there - there is just another database folder that needs to be cleaned and rebuilt.
Run this command (replacing the 2 instances of “scotty” with your username):
sudo mv /tmp/pamac-scotty/dbs/sync /tmp/pamac-scotty/dbs/sync.old
Then run the
and
commands again. I just did that and a new /tmp/pamac-scotty/dbs/sync directory was created with the freshly downloaded databases.
If that works fine, then remove the sync.old directory (and don’t forget to replace “scotty” with your username):
sudo rm -fr /tmp/pamac-scotty/dbs/sync.old
Done.
pamac update --no-aur --force-refresh         ✔  4s 
Preparing...
Authenticating as: ssss (ssss)
Password:
Nothing to do.
Done.
Ok, now the 2 commands proceeded with no error, and Pamac also proceeded with update with no error.
Seems like you got it resolved!
Thank you very much!
