I’ve been trying to update-grub and it takes ~30 mins and then crashes Manjaro (black screen).
Have any of you encountered this before and know a solution? Please tell me if I can provide some more information, I’m new and don’t know how to do that.
result of inxi --admin --verbosity=7 --filter --no-host --width :
Kernel: 5.18.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=9e40985b-cd55-40b5-8a42-ce29331d84a2 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 2
Type: Laptop System: LENOVO product: 20T8006QGE v: ThinkPad E15 Gen 2
Mobo: LENOVO model: 20T8006QGE serial: <superuser required> UEFI: LENOVO
v: R1AET41W (1.17 ) date: 11/11/2021
ID-1: BAT0 charge: 38.5 Wh (86.3%) condition: 44.6/45.0 Wh (99.1%)
volts: 11.9 min: 11.1 model: Sunwoda 5B10X025 type: Li-poly serial: <filter>
status: discharging cycles: 63
RAM: total: 14.86 GiB used: 1.89 GiB (12.7%)
RAM Report:
Info: model: AMD Ryzen 5 PRO 4650U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x60 (96) stepping: 1 microcode: 0x8600103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1396 high: 1404 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1397 2: 1396
3: 1397 4: 1397 5: 1397 6: 1396 7: 1397 8: 1397 9: 1396 10: 1387 11: 1404
12: 1395 bogomips: 50321
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN 5.1
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b725 class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
alternate: fbdev,vesa gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.46 5.18.7-1-MANJARO)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.18.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Lenovo driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8852 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Local Storage: total: 238.47 GiB used: 126.52 GiB (53.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNT256G MEMORY size: 238.47 GiB block-size: physical: 512 B
rev: 0109AELA temp: 29.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 126.52 GiB (54.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 9e40985b-cd55-40b5-8a42-ce29331d84a2
label: NO_LABEL uuid: 15F1-0E6A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Chicony Integrated Camera type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix FingerPrint Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 27c6:55a4 class-ID: ef00
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): fan-1: 1800 fan-2: 1800
Processes: 282 Uptime: 0m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1342
lib: 366 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
