pacman -Syu returns
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: plymouth: local (24.004.60-6) is newer than extra (22.02.122-18)
there is nothing to do
More information about the system
> inxi -zv8
12System:
12Kernel 6.6.25-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 13.2.1 12clocksource tsc 12avail acpi_pm
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDEM_2314 quiet systemd.show_status=1 splash driver=free nouveau.modeset=1
i915.modeset=1 radeon.modeset=1
12Desktop KDE Plasma 12v ERR-101 12tk Qt 12v N/A 12dm N/A 12Distro Manjaro 12base Arch Linux
12Machine:
12Type Laptop 12System LENOVO 12product 20XWCTO1WW 12v ThinkPad X1 Carbon Gen 9 12serial <filter> 12Chassis
12type 10 12serial <filter>
12Mobo LENOVO 12model 20XWCTO1WW 12serial <filter> 12part-nu LENOVO_MT_20XW_BU_Think_FM_ThinkPad X1
Carbon Gen 9 12uuid 7705b1d2-f5f3-11eb-80f0-902e16ae5c1a 12UEFI LENOVO 12v N32ET66W (1.42 )
12date 06/15/2021
12Battery:
12ID-1 BAT0 12charge 51.1 Wh (95.5%) 12condition 53.5/57.0 Wh (93.9%) 12volts 15.7 12min 15.4
12model Sunwoda 5B10W13975 12type Li-poly 12serial <filter> 12status not charging 12cycles 16
12Memory:
12System RAM 12total 32 GiB 12available 31.08 GiB 12used 3.61 GiB (11.6%) 12igpu 64 MiB
12Array-1 12capacity 3.97 TiB 12note check 12slots 8 12note check 12modules 8 12EC None 12max-module-size N/A
12Device-1 Controller0-ChannelA 12type LPDDR4 12detail synchronous 12size 4 GiB 12speed 4267 MT/s 12volts
12curr 0.6 12width (bits) 12data 16 12total 16 12manufacturer Micron Technology 12part-no 53E2G32D4NQ-046
12serial N/A
12Device-2 Controller0-ChannelB 12type LPDDR4 12detail synchronous 12size 4 GiB 12speed 4267 MT/s 12volts
12serial N/A
12Device-3 Controller0-ChannelC 12type LPDDR4 12detail synchronous 12size 4 GiB 12speed 4267 MT/s 12volts
12serial N/A
12Device-4 Controller0-ChannelD 12type LPDDR4 12detail synchronous 12size 4 GiB 12speed 4267 MT/s 12volts
12serial N/A
12Device-5 Controller1-ChannelA 12type LPDDR4 12detail synchronous 12size 4 GiB 12speed 4267 MT/s 12volts
12serial N/A
12Device-6 Controller1-ChannelB 12type LPDDR4 12detail synchronous 12size 4 GiB 12speed 4267 MT/s 12volts
12serial N/A
12Device-7 Controller1-ChannelC 12type LPDDR4 12detail synchronous 12size 4 GiB 12speed 4267 MT/s 12volts
12serial N/A
12Device-8 Controller1-ChannelD 12type LPDDR4 12detail synchronous 12size 4 GiB 12speed 4267 MT/s 12volts
12serial N/A
12PCI Slots:
12Slot N/A 12type N/A 12status available 12length other 12bus-ID 00ff:ff:1f.7
12CPU:
12Info 12model 11th Gen Intel Core i7-1165G7 12socket U3E1 12bits 64 12type MT MCP 12arch Tiger Lake
12gen core 11 12level v4 12note check 12built 2020 12process Intel 10nm 12family 6 12model-id 0x8C (140)
12stepping 1 12microcode 0xB4
12Topology 12cpus 1x 12cores 4 12tpc 2 12threads 8 12smt enabled 12cache 12L1 320 KiB
12desc d-4x48 KiB; i-4x32 KiB 12L2 5 MiB 12desc 4x1.2 MiB 12L3 12 MiB 12desc 1x12 MiB
12Speed (MHz) 12avg 400 12min/max 400/4700 12base/boost 2800/2800 12scaling 12driver intel_pstate
12governor powersave 12volts 0.7 V 12ext-clock 100 MHz 12cores 121 400 122 400 123 400 124 400 125 400 126 400 127 400
128 400 12bogomips 44864
12Flags 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art
avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw
avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
erms est f16c flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid lahf_lm lm mca mce
md_clear mmx monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vpclmulqdq x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
12Vulnerabilities
12Type gather_data_sampling 12mitigation Microcode
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type mmio_stale_data 12status Not affected
12Type reg_file_data_sampling 12status Not affected
12Type retbleed 12status Not affected
12Type spec_rstack_overflow 12status Not affected
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation Enhanced / Automatic IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: SW sequence
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 Intel TigerLake-LP GT2 [Iris Xe Graphics] 12vendor Lenovo 12driver i915 12v kernel
12arch Gen-12.1 12process Intel 10nm 12built 2020-21 12ports 12active eDP-1 12empty DP-1, DP-2, DP-3, DP-4,
HDMI-A-1, HDMI-A-2, HDMI-A-3 12bus-ID 00:02.0 12chip-ID 8086:9a49 12class-ID 0300
12Device-2 Chicony Integrated Camera 12driver uvcvideo 12type USB 12rev 2.0 12speed 480 Mb/s 12lanes 1
12mode 2.0 12bus-ID 3-4:4 12chip-ID 04f2:b6ea 12class-ID fe01 12serial <filter>
12Display 12server X.org 12v 1.21.1.13 12with Xwayland 12v 23.2.6 12driver 12X 12loaded modesetting
12alternate fbdev,vesa 12dri iris 12gpu i915 12display-ID :0
12Monitor-1 eDP-1 12model-id CSO 0x1403 12built 2020 12res 3840x2400 12dpi 323 12gamma 1.2 12chroma 12red
12x 0.686 12y 0.314 12green 12x 0.259 12y 0.694 12blue 12x 0.145 12y 0.055 12white 12x 0.314 12y 0.337
12size 302x189mm (11.89x7.44") 12diag 356mm (14") 12ratio 16:10 12modes 3840x2400
12API EGL 12v 1.5 12hw 12drv intel iris 12platforms 12device 0 12drv iris 12device 1 12drv swrast 12surfaceless
12drv iris 12inactive gbm,wayland,x11
12API OpenGL 12v 4.6 12compat-v 4.5 12vendor mesa 12v 24.0.6-manjaro1.1 12note incomplete (EGL sourced)
12renderer Mesa Intel Xe Graphics (TGL GT2), llvmpipe (LLVM 17.0.6 256 bits)
12API Vulkan 12Message No Vulkan data available.
12Audio:
12Device-1 Intel Tiger Lake-LP Smart Sound Audio 12vendor Lenovo 12driver sof-audio-pci-intel-tgl
12bus-ID 00:1f.3 12chip-ID 8086:a0c8 12class-ID 0403
12API ALSA 12v k6.6.25-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
12tools alsactl,alsamixer,amixer
12Server-1 JACK 12v 1.9.22 12status off 12tools N/A
12Server-2 PipeWire 12v 1.0.5 12status off 12with wireplumber 12status off 12tools pw-cli,wpctl
12Server-3 PulseAudio 12v 17.0 12status off 12with pulseaudio-alsa 12type plugin 12tools pacat,pactl
12Network:
12Device-1 Intel Wi-Fi 6 AX201 12driver iwlwifi 12v kernel 12bus-ID 00:14.3 12chip-ID 8086:a0f0
12class-ID 0280
12IF wlp0s20f3 12state up 12mac <filter>
12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
12IP v6 <filter> 12type noprefixroute 12scope link
12Info 12services No services found.
12WAN IP <filter>
12Bluetooth:
12Device-1 Intel AX201 Bluetooth 12driver btusb 12v 0.8 12type USB 12rev 2.0 12speed 12 Mb/s 12lanes 1 12mode 1.1
12bus-ID 3-10:5 12chip-ID 8087:0026 12class-ID e001
12Report rfkill 12ID hci0 12rfk-id 1 12state down 12bt-service N/A 12rfk-block 12hardware no 12software no
12address see --recommends
12Logical:
12Message No logical block device data found.
12RAID:
12Message No RAID data found.
12Drives:
12Local Storage 12total 3.88 TiB 12used 192.33 GiB (4.8%)
12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor SK Hynix 12model HFS256GDE9X081N 12size 238.47 GiB
12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12tech SSD 12serial <filter>
12fw-rev 41710C20 12temp 39.9 C
12SMART yes 12health PASSED 12on 229d 6h 12cycles 1,022 12read-units 20,063,562 [10.2 TB]
12written-units 36,586,281 [18.7 TB]
12ID-2 /dev/sda 12maj-min 8:0 12model USB 2.0 Flash Drive 12size 3.75 GiB 12block-size 12physical 512 B
12logical 512 B 12type USB 12rev 2.0 12spd 480 Mb/s 12lanes 1 12mode 2.0 12tech SSD 12serial <filter> 12fw-rev 8.07
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12ID-3 /dev/sdb 12maj-min 8:16 12vendor Western Digital 12model WD40NDZW-11A8JS1 12family Elements / My
Passport (USB, AF) 12size 3.64 TiB 12block-size 12physical 4096 B 12logical 512 B 12type USB 12rev 3.1
12spd 5 Gb/s 12lanes 1 12mode 3.2 gen-1x1 12sata 3.1 12speed 6.0 Gb/s 12tech HDD 12rpm 5400 12serial <filter>
12fw-rev 1020 12drive-rev 01.01A01 12temp 49 C
12SMART yes 12state enabled 12health PASSED 12on 17d 10h 12cycles 155
12Message No optical or floppy data found.
12Partition:
12ID-1 / 12raw-size 229.37 GiB 12size 224.71 GiB (97.97%) 12used 192.33 GiB (85.6%) 12fs ext4
12block-size 4096 B 12dev /dev/dm-0 12maj-min 254:0 12mapped encrypted 12label N/A 12uuid N/A
12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 448 KiB (0.1%) 12fs vfat
12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1 12label N/A 12uuid 1E2A-B0FC
12Swap:
12Alert No swap data was found.
12Unmounted:
12ID-1 /dev/nvme0n1p2 12maj-min 259:2 12size 229.37 GiB 12fs N/A 12label N/A
12uuid f989b79a-acbe-4ea0-9e5b-d8e8780129a5
12ID-2 /dev/nvme0n1p3 12maj-min 259:3 12size 8.8 GiB 12fs N/A 12label N/A
12uuid 8fc2e7af-1820-4046-b692-30f7cf9dc241
12ID-3 /dev/sda1 12maj-min 8:1 12size 2.96 GiB 12fs N/A 12label MANJARO_KDEM_2314
12uuid 2024-04-06-03-22-56-00
12ID-4 /dev/sda2 12maj-min 8:2 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid C84B-5BFC
12ID-5 /dev/sdb1 12maj-min 8:17 12size 3.64 TiB 12fs ntfs 12label Elements 12uuid 94CC024FCC022BD4
12USB:
12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 1 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
12Hub-2 2-0:1 12info super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s) 12lanes 1
12mode 3.2 gen-2x1 12chip-ID 1d6b:0003 12class-ID 0900
12Hub-3 3-0:1 12info hi-speed hub with single TT 12ports 12 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s)
12lanes 1 12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
12Device-1 3-1:2 12info Alcor Micro Flash Drive 12type mass storage 12driver usb-storage 12interfaces 1
12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 100mA 12chip-ID 058f:6387 12class-ID 0806
12serial <filter>
12Device-2 3-3:3 12info Synaptics 12type <vendor specific> 12driver N/A 12interfaces 1 12rev 2.0
12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA 12chip-ID 06cb:00fc 12class-ID ff00
12serial <filter>
12Device-3 3-4:4 12info Chicony Integrated Camera 12type video 12driver uvcvideo 12interfaces 5 12rev 2.0
12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 500mA 12chip-ID 04f2:b6ea 12class-ID fe01
12serial <filter>
12Device-4 3-10:5 12info Intel AX201 Bluetooth 12type bluetooth 12driver btusb 12interfaces 2 12rev 2.0
12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA 12chip-ID 8087:0026 12class-ID e001
12Hub-4 4-0:1 12info super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s) 12lanes 1
12Device-1 4-2:2 12info Western Digital Elements 2620 12type mass storage 12driver usb-storage
12interfaces 1 12rev 3.1 12speed 5 Gb/s (596.0 MiB/s) 12lanes 1 12mode 3.2 gen-1x1 12power 896mA
12chip-ID 1058:2620 12class-ID 0806 12serial <filter>
12Sensors:
12System Temperatures 12cpu 43.0 C 12mobo N/A
12Fan Speeds (rpm) 12fan-1 0 12fan-2 0
12Repos:
12Packages 12pm pacman 12pkgs 1587 12libs 437 12tools pamac,yay 12pm flatpak 12pkgs 0
12Active pacman repo servers in /etc/pacman.d/mirrorlist
121 https: //mirrors2.manjaro.org/stable/$repo/$arch
122 https: //mirrors.manjaro.org/repo/stable/$repo/$arch
123 https: //manjaro.mirror.wearetriple.com/stable/$repo/$arch
124 https: //mirror.dkm.cz/manjaro/stable/$repo/$arch
125 https: //mirror.erickochen.nl/manjaro/stable/$repo/$arch
126 https: //mirror.futureweb.be/manjaro/stable/$repo/$arch
127 https: //mirror1.sox.rs/manjaro/stable/$repo/$arch
128 https: //manjaro.ynh.ovh/stable/$repo/$arch
129 https: //mirror.vinehost.net/manjaro/stable/$repo/$arch
1210 https: //mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
1211 https: //mirror.bouwhuis.network/manjaro/stable/$repo/$arch
1212 https: //mirrors.cicku.me/manjaro/stable/$repo/$arch
1213 https: //ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
1214 https: //manjaro.kurdy.org/stable/$repo/$arch
1215 https: //ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
1216 http: //ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
1217 http: //mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
1218 https: //www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
1219 http: //ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
1220 https: //ask4.mm.fcix.net/manjaro/stable/$repo/$arch
1221 https: //mirror.23m.com/manjaro/stable/$repo/$arch
1222 https: //mirror.netcologne.de/manjaro/stable/$repo/$arch
1223 https: //mirror.alpix.eu/manjaro/stable/$repo/$arch
1224 https: //mirror.init7.net/manjaro/stable/$repo/$arch
1225 https: //mirrors.ft.uam.es/manjaro/stable/$repo/$arch
1226 http: //manjaro.mirrors.uk2.net/stable/$repo/$arch
1227 http: //mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
1228 https: //ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
1229 https: //mirrors.dotsrc.org/manjaro/stable/$repo/$arch
1230 https: //manjaro.ipacct.com/manjaro/stable/$repo/$arch
1231 https: //mirror.telepoint.bg/manjaro/stable/$repo/$arch
1232 https: //quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
1233 https: //mirror.zetup.net/manjaro/stable/$repo/$arch
1234 https: //fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
1235 https: //ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
1236 https: //mirrors.nic.cz/manjaro/stable/$repo/$arch
1237 https: //ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
1238 http: //ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
1239 https: //repos.silknet.com/manjaro/stable/$repo/$arch
1240 https: //mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
1241 http: //manjaro.grena.ge/stable/$repo/$arch
1242 https: //ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
1243 https: //nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
1244 https: //mirror.easyname.at/manjaro/stable/$repo/$arch
1245 https: //uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
1246 https: //mirrors.up.pt/pub/manjaro/stable/$repo/$arch
1247 http: //mirror.fcix.net/manjaro/stable/$repo/$arch
1248 https: //nocix.mm.fcix.net/manjaro/stable/$repo/$arch
1249 https: //ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
1250 https: //forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
1251 https: //southfront.mm.fcix.net/manjaro/stable/$repo/$arch
1252 https: //muug.ca/mirror/manjaro/stable/$repo/$arch
1253 https: //mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
1254 https: //coresite.mm.fcix.net/manjaro/stable/$repo/$arch
1255 https: //mirrors.atlas.net.co/manjaro/stable/$repo/$arch
1256 https: //mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
1257 https: //mirrors.gigenet.com/manjaro/stable/$repo/$arch
1258 https: //repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
1259 https: //codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
1260 https: //mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
1261 https: //volico.mm.fcix.net/manjaro/stable/$repo/$arch
1262 https: //mirror.truenetwork.ru/manjaro/stable/$repo/$arch
1263 https: //mirror.xenyth.net/manjaro/stable/$repo/$arch
1264 https: //ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
1265 https: //mirror.albony.xyz/manjaro/stable/$repo/$arch
1266 https: //opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
1267 https: //edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
1268 https: //mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
1269 https: //ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
1270 https: //mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
1271 https: //mirror.freedif.org/Manjaro/stable/$repo/$arch
1272 https: //mirrors.sonic.net/manjaro/stable/$repo/$arch
1273 http: //manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
1274 https: //mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
1275 https: //gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
1276 https: //mirror.2degrees.nz/manjaro/stable/$repo/$arch
1277 http: //mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
1278 https: //mirror.kamtv.ru/manjaro/stable/$repo/$arch
1279 https: //mirror.funami.tech/manjaro/stable/$repo/$arch
1280 https: //irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
1281 http: //mirror.xeonbd.com/manjaro/stable/$repo/$arch
1282 https: //linorg.usp.br/manjaro/stable/$repo/$arch
1283 https: //mirror.ufro.cl/manjaro/stable/$repo/$arch
1284 https: //mirror.ufam.edu.br/manjaro/stable/$repo/$arch
1285 https: //mirror.kku.ac.th/manjaro/stable/$repo/$arch
1286 https: //manjaro.repo.cure.edu.uy/stable/$repo/$arch
1287 http: //ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
1288 http: //ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
1289 http: //kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
1290 https: //mirror.archlinux.tw/Manjaro/stable/$repo/$arch
1291 https: //manjarolinux-mirror.cloud.mu/stable/$repo/$arch
1292 https: //manjaro.c3sl.ufpr.br/stable/$repo/$arch
1293 https: //mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
1294 https: //mirror.koddos.net/manjaro/stable/$repo/$arch
1295 https: //mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
12Processes:
12Message No process data available.
12Info:
12Processes 0 12Power 12uptime 25m 12states freeze,mem,disk 12suspend s2idle 12wakeups 0 12hibernate platform
12avail shutdown, reboot, suspend, test_resume 12image 12.41 GiB 12Init systemd 12v 255 12default graphical
12tool systemctl
12Compilers 12clang 17.0.6 12gcc 13.2.1 12Client systemd 12inxi 3.3.34
> mhwd-kernel -li
Currently running: 6.6.25-1-MANJARO (linux66)
error: could not open file /var/lib/pacman/local/texlive-fontsextra-2024.2-1/desc: No such file or directory
* linux61
* linux66
> lsb_release -sirc
ManjaroLinux 24.0.0 Wynsdey
> journalctl --boot=-1 --priority=3 --catalog --no-pager
May 12 18:11:48 marcoshstation kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
May 12 18:11:51 marcoshstation kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
May 12 18:12:06 marcoshstation bluetoothd[505]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
May 12 18:12:06 marcoshstation bluetoothd[505]: Failed to add UUID: Failed (0x03)
May 12 19:07:34 marcoshstation pulseaudio[2391]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.NoReply:Remote peer disconnected
May 12 19:07:34 marcoshstation pulseaudio[2391]: Assertion 'pa_atomic_load(&(y)->_ref) > 0' failed at ../pulseaudio/src/modules/bluetooth/bluez5-util.c:2207, function pa_bluetooth_discovery_hook(). Aborting.
May 12 19:07:35 marcoshstation dbus-broker-launch[501]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
May 12 19:07:36 marcoshstation dbus-broker-launch[501]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
May 12 19:07:36 marcoshstation systemd-cryptsetup[203244]: Device luks-f989b79a-acbe-4ea0-9e5b-d8e8780129a5 is still in use.
May 12 19:07:36 marcoshstation systemd-cryptsetup[203244]: Failed to deactivate 'luks-f989b79a-acbe-4ea0-9e5b-d8e8780129a5': Device or resource busy
