My last update from 12/24/22 crashed on my laptop:
(209/243) Aktualisiert wird libmpc [#############################################################################] 100%
(210/243) Aktualisiert wird pacman-mirrors [#############################################################################] 100%
Fehler: Konnte Datei /var/cache/pacman/pkg/pacman-6.0.2-6-x86_64.pkg.tar.zst nicht öffnen: Datei oder Verzeichnis nicht gefunden
Fehler: Konnte den Vorgang nicht durchfĂŒhren
Fehler: Der Vorgang konnte nicht durchgefĂŒhrt werden (Vorgang abgebrochen)
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
After that, I found, that a link (/var/cache/pacman â /mnt/linux2root/var/cache/pacman) is deleted during the update. I created this link weeks before because of low disk space on the / partition.
I create the link again, but cannot finish the update because âpacmanâ is not found.
Another way to update also donât work:
pamac update
pamac: error while loading shared libraries: libalpm.so.13: cannot open shared object file: No such file or directory
I can solve this with copying the file /lib/libalpm.so.13.0.2 from my desktop and create the missing links.
Now pamac starts, but during âpamac updateâ error occur:
Warning: could not fully load metadata for package pacman-6.0.2-6
Error: ... invalid or corrupted package
Has anyone a idea, how to get pacman working again?
pamac reinstall pacman
leads to the same error. Remove of pacman also donât work.
In /var/cache/pacman/pkg I have older packages of pacman, but how to install these?
Youâre improperly manipulating the location of the cache directory: it âbelongsâ to the pacman package and during the update of said package your symlink is removed and a directory (re-)created. That leads to an empty package cache during your update.
Use a bind mount
$ sudo mount --bind /mnt/linux2root/var/cache/pacman /var/cache/pacman
I change the CacheDir in /etc/pacman.conf and delete the link.
Then I extract the /usr files from the package pacman-6.0.2-6-x86_64.pkg.tar.zst in cache.
Now I can execute pacman, but a reinstall donât work:
sudo pacman -U --overwrite "*" pacman-6.0.2-6-x86_64.pkg.tar.zst
Pakete werden geladen âŠ
Warnung: pacman-6.0.2-6 ist aktuell -- Reinstalliere
AbhĂ€ngigkeiten werden aufgelöst âŠ
Nach in Konflikt stehenden Paketen wird gesucht âŠ
Warnung: Konnte die Metadaten fĂŒr Paket pacman-6.0.2-6 nicht vollstĂ€ndig laden
Fehler: Vorgang konnte nicht vorbereitet werden (UngĂŒltiges oder beschĂ€digtes Paket)
:: Paketdatenbanken werden synchronisiert âŠ
core ist aktuell
extra ist aktuell
community 7,5 MiB 9,43 MiB/s 00:01 [#############################################################################] 100%
multilib ist aktuell
:: VollstĂ€ndige Systemaktualisierung wird gestartet âŠ
Warnung: sndio: Lokale Version (20180120-1) ist neuer als community (1.9.0-1)
I was able, to install pacman-static with octopi, but
Actually I have no Manjaro USB, but I can create one in the next days. Can you point me to a description, how to finish the update after boot the live-system?
boot into live usb and use pacstrap instead of external pacman from the live usb, i have a feeling that external pacman from the usb will not work either:
install it in the live usb: sudo pacman -S arch-install-scripts
mount your root partition, for example: sudo mount /dev/sda1 /mnt
where /dev/sda1 you replace with your partition; you can check them with: lsblk -l
install pacman: sudo pacstrap -i /mnt pacman
if you didnt get any error, you can reboot and rerun update
I booted the Manjaro USB (from Image manjaro-kde-22.0-221224-linux61.iso), then install arch-install-scripts:
sudo pacman -Syu arch-install-scripts îČ 1 â
core 160,3 KiB 522 KiB/s 00:00 [####################################] 100%
extra 1829,0 KiB 8,01 MiB/s 00:00 [####################################] 100%
community 7,5 MiB 18,7 MiB/s 00:00 [####################################] 100%
multilib 166,4 KiB 2,90 MiB/s 00:00 [####################################] 100%
error: failed retrieving file 'core.db' from manjaro.moson.eu : Could not resolve host: manjaro.moson.eu
warning: too many errors from manjaro.moson.eu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.infotronik.hu : The requested URL returned error: 404
error: failed retrieving file 'extra.db' from mirror.infotronik.hu : The requested URL returned error: 404
error: failed retrieving file 'community.db' from mirror.infotronik.hu : The requested URL returned error: 404
warning: too many errors from mirror.infotronik.hu, skipping for the remainder of this transaction
resolving dependencies...
Packages (1) arch-install-scripts-28-1
Total Download Size: 0,02 MiB
Total Installed Size: 0,05 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
arch-install-scripts-28-1-any 15,8 KiB 144 KiB/s 00:00 [####################################] 100%
(1/1) checking keys in keyring [####################################] 100%
(1/1) checking package integrity [####################################] 100%
(1/1) loading package files [####################################] 100%
(1/1) checking for file conflicts [####################################] 100%
(1/1) checking available disk space [####################################] 100%
(1/1) installing arch-install-scripts [####################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Refreshing PackageKit...
then mount my / partition to /mnt and run
sudo pacstrap -i /mnt pacman îČ â
==> Creating install root at /mnt
==> Installing packages to /mnt
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: pacman-6.0.2-6 is up to date -- reinstalling
warning: could not fully load metadata for package pacman-6.0.2-6
error: failed to prepare transaction (invalid or corrupted package)
==> ERROR: Failed to install packages to new root
