caho
18 November 2020 18:58
1
Hello together,
I have this problem:
I startet the update 2020-11-18 stable.
All files were downloaded, but then the Lan - connection was broken.
After a reboot a “pacman -Syu” tells me “there is nothing to do”. But nothing was updatet.
What can I do to restart or force the update again?
regards
caho
cscs
18 November 2020 19:03
2
If they werent installed the system should recognize that.
In such a situation you usually only have to worry about the one in the middle of installation.
Maybe try with this
sudo pacman -Syyu
Otherwise you might want to look in the log (/var/log/pacman.log
) to review the transaction.
can you provide
sudo mhwd-kernel -li
inxi -Fza --no-host
caho
18 November 2020 19:11
4
pacman -Syyu shows me
core 169,6 KiB 2,24 MiB/s 00:00 [#############################################################################] 100%
extra 1996,3 KiB 13,9 MiB/s 00:00 [#############################################################################] 100%
community 6,3 MiB 14,8 MiB/s 00:00 [#############################################################################] 100%
multilib 189,7 KiB 18,5 MiB/s 00:00 [#############################################################################] 100%
:: Starte vollständige Systemaktualisierung…
Es gibt nichts zu tun
this is the end of /var/log/pacman.log
[2020-11-18T18:46:22+0100] [PACMAN] Running ‘pacman -Syu’
[2020-11-18T18:46:22+0100] [PACMAN] synchronizing package lists
[2020-11-18T18:46:22+0100] [PACMAN] starting full system upgrade
[2020-11-18T18:47:14+0100] [PAMAC] synchronizing package lists
[2020-11-18T18:52:08+0100] [PACMAN] Running ‘pacman -Syyu’
[2020-11-18T18:52:08+0100] [PACMAN] synchronizing package lists
[2020-11-18T18:52:09+0100] [PACMAN] starting full system upgrade
[2020-11-18T18:52:43+0100] [PACMAN] Running ‘pacman -Syyuu’
[2020-11-18T18:52:43+0100] [PACMAN] synchronizing package lists
[2020-11-18T18:52:44+0100] [PACMAN] starting full system upgrade
[2020-11-18T20:08:46+0100] [PACMAN] Running ‘pacman -Syyu’
[2020-11-18T20:08:46+0100] [PACMAN] synchronizing package lists
[2020-11-18T20:08:47+0100] [PACMAN] starting full system upgrade
my system:
System: Host: manjaro64 Kernel: 5.4.77-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.3 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: MEDIONPC model: MS-7728 v: 2.0 serial: <superuser/root required> BIOS: American Megatrends
v: E7728MLN.208 date: 08/15/2011
CPU: Info: Quad Core model: Intel Core i7-2600 bits: 64 type: MT MCP L2 cache: 8192 KiB
Speed: 1596 MHz min/max: 1600/3800 MHz Core speeds (MHz): 1: 1596 2: 1596 3: 1596 4: 1596 5: 1596 6: 1596 7: 1596
8: 1596
Graphics: Device-1: NVIDIA GF116 [GeForce GT 545] driver: nvidia v: 390.132
Display: x11 server: X.Org 1.20.9 driver: nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GT 545/PCIe/SSE2 v: 4.6.0 NVIDIA 390.132
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel
Device-2: NVIDIA GF116 High Definition Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.77-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8168
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 8c:89:a5:99:8b:33
Drives: Local Storage: total: 465.77 GiB used: 36.07 GiB (7.7%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 220.44 GiB used: 36.07 GiB (16.4%) fs: ext4 dev: /dev/sda1
Swap: ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) dev: /dev/sda2
Sensors: System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 26%
Info: Processes: 231 Uptime: 5m Memory: 7.76 GiB used: 1.24 GiB (16.0%) Shell: Bash inxi: 3.1.08
caho
18 November 2020 19:13
5
System: Kernel: 5.4.77-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=fade4a2c-bd11-444d-9412-42d59f048a88 rw quiet splash
resume=UUID=138bba57-2e1c-4cbe-995b-da840baa29ec
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: MEDIONPC model: MS-7728 v: 2.0 serial: BIOS: American Megatrends v: E7728MLN.208
date: 08/15/2011
CPU: Info: Quad Core model: Intel Core i7-2600 bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
stepping: 7 microcode: 2F L2 cache: 8192 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 54293
Speed: 1596 MHz min/max: 1600/3800 MHz Core speeds (MHz): 1: 1594 2: 1596 3: 1596 4: 1596 5: 1596 6: 1596 7: 1596
8: 1596
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GF116 [GeForce GT 545] vendor: Elite Systems driver: nvidia v: 390.132
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1243
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9") s-diag: 610mm (24")
Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 92 size: 531x298mm (20.9x11.7") diag: 609mm (24")
OpenGL: renderer: GeForce GT 545/PCIe/SSE2 v: 4.6.0 NVIDIA 390.132 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
Device-2: NVIDIA GF116 High Definition Audio vendor: Elite Systems driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:0bee
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8168
v: 8.048.03-NAPI modules: r8169 port: d000 bus ID: 04:00.0 chip ID: 10ec:8168
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s serial: rev: 2B6Q scheme: MBR
SMART Message: Unknown smartctl error. Unable to get data.
ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB block size: physical: 512 B logical: 512 B
Partition: ID-1: / raw size: 224.08 GiB size: 220.44 GiB (98.37%) used: 36.07 GiB (16.4%) fs: ext4 block size: 4096 B
dev: /dev/sda1
Swap: Kernel: swappiness: 1 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
Sensors: System Temperatures: cpu: 29.0 C mobo: N/A gpu: nvidia temp: 47 C
Info: Processes: 229 Uptime: 7m Memory: 7.76 GiB used: 1.29 GiB (16.7%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1432 lib: 386 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.08
if it wad during download that link ip was broken
then
sudo pacman -Syyu
should works
caho
18 November 2020 19:18
7
sudo pacman -Syyuu shows me
:: Synchronisiere Paketdatenbanken...
core 169,6 KiB 1379 KiB/s 00:00 [#############################################################################] 100%
extra 1996,3 KiB 14,7 MiB/s 00:00 [#############################################################################] 100%
community 6,3 MiB 14,9 MiB/s 00:00 [#############################################################################] 100%
Is it possible to reinstall the last update?
cscs
18 November 2020 20:24
8
First off … please review how to format your posts:
When asking questions in the forum it is most helpful to everyone for you to provide some basic information.
When sharing information to either give or receive assistance, please be aware of the following:
1 ) In almost every situation not explicitly involving appearance, Text is preferred over Images.
2 ) When providing code or text output, please format it so the content is easy to read.
How to Format “Code” in the Forum
Its easy to make your text and code easy on the eyes
Firs…
Then …
That doesnt tell us anything … I see you tried to update multiple times … but what were the last transactions?
Meh … I guess you can sort of automate it like this:
paccache -rvk0 && sudo pacman-mirrors -f && sudo pacman -Syyu $(pacman -Qqen) && sudo pacman -S $(comm -13 <(pacman -Qqdt | sort) <(pacman -Qqdtt | sort)) --asdeps
(clear cache totally, sort mirrors, full sync/update and reinstall explicitly installed repo packages, reinstall as dependencies all packages installed as deps of othes)
caho
18 November 2020 20:39
9
You are right @cscs ,
I put the output with the “</>” . But the result isn´t very good readable.
1:
look here for example:
System: Kernel: 5.4.77-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.3 Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 766511G v: ThinkPad T61 serial:
Mobo: LENOVO model: 766511G serial: BIOS: LENOVO v: 7LETC1WW (2.21 ) date: 07/01/2008
Battery: ID-1: BAT0 charge: 43.1 Wh condition: 49.8/71.3 Wh (70%)
CPU: Info: Dual Core model: Intel Core2 Duo T7100 bits: 64 type: MCP L2 cache: 2048 KiB
Speed: 798 MHz min/max: 800/1801 MHz Core speeds (MHz): 1: 1068 2: 1186
Graphics: Device-1: NVIDIA G86M [Quadro NVS 140M] driver: nvidia v: 340.108
Display: x11 server: X.Org 1.20.9 driver: nvidia resolution: 1440x900~60Hz
OpenGL: renderer: Quadro NVS 140M/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
Audio: Device-1: Intel 82801H HD Audio driver: snd_hda_intel
Network: Device-1: Intel 82566MM Gigabit Network driver: e1000e
IF: enp0s25 state: down mac:
Device-2: Intel PRO/Wireless 4965 AG or AGN [Kedron] Network driver: iwl4965
IF: wls3 state: up mac:
Drives: Local Storage: total: 223.57 GiB used: 31.24 GiB (14.0%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDHII240G size: 223.57 GiB
Partition: ID-1: / size: 211.70 GiB used: 31.22 GiB (14.7%) fs: ext4 dev: /dev/sda1
Swap: ID-1: swap-1 type: partition size: 8.36 GiB used: 20.0 MiB (0.2%) dev: /dev/sda2
Sensors: System Temperatures: cpu: 49.0 C mobo: 45.0 C gpu: nvidia temp: 60 C
Fan Speeds (RPM): fan-1: 0
Info: Processes: 171 Uptime: 2h 01m Memory: 3.78 GiB used: 1.90 GiB (50.3%) Shell: Bash inxi: 3.1.08
I will try the “paccache -rvk0 …” tomorrow.
In the meantime thanks to @cscs and @stephane
regards
caho
