I have a very annoying problem with my Broadcom BCM4352 wifi & bl chip. If I connect my bluetooth headphones to the laptop (XPS 13 9350) the wifi is very very unstable and drops out every few seconds. I installed the Winterheart Broadcom BT firmware (GitHub - winterheart/broadcom-bt-firmware: Repository for various Broadcom Bluetooth firmware) to get the bluetooth working in the first place (before that scanning was possible, but refused to connect).
I also switched NetworkManager to use iwd instead of wpa_supplicant to make reconnection after standby much faster.
If I “force” iwd to connect to the 5Ghz band of my wifi, then it works fine so I’m guessing the 2.4Ghz band is (because of the Bluetooth connection) is being interfered with. This makes the use of the laptop very much limited though and I would love to fix this. Any help is greatly appreciated.
inxi -Fza
System: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=331f33b6-7e2c-43a9-844e-7b2032f10c39 rw quiet apparmor=1
security=apparmor resume=UUID=1450892a-65ea-43ce-af55-8cf0b4d931c5 udev.log_priority=3 i915.enable_psr=1
i915.disable_power_well=0 i915.enable_rc6=1 i915.enable_fbc=1 i915.enable_guc_loading=1
i915.enable_guc_submission=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: XPS 13 9350 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0V33HM v: A02 serial: <filter> UEFI: Dell v: 1.9.0 date: 08/31/2018
Battery: ID-1: BAT0 charge: 11.1 Wh condition: 11.1/56.0 Wh (20%) volts: 8.5/7.6 model: LGC-LGC7.3 DELL 5K9CP59 type: Li-ion
serial: <filter> status: Full
CPU: Info: Dual Core model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake family: 6 model-id: 4E (78)
stepping: 3 microcode: E2 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20810
Speed: 3093 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 3040 2: 3010 3: 3082 4: 3003
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:1916
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo bus ID: 1-5:3 chip ID: 0c45:670c
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 dpi: 168 size: 290x170mm (11.4x6.7") diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.2.3 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel alternate: snd_soc_skl
bus ID: 00:1f.3 chip ID: 8086:9d70
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Broadcom and subsidiaries BCM4352 802.11ac Wireless Network Adapter vendor: Dell driver: wl v: kernel
modules: bcma port: f040 bus ID: 3a:00.0 chip ID: 14e4:43b1
Drives: Local Storage: total: 238.47 GiB used: 13.80 GiB (5.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: PM951 NVMe 256GB size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: BXV76D0Q scheme: GPT
Partition: ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%) used: 13.80 GiB (6.1%) fs: ext4 dev: /dev/nvme0n1p2
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 37.0 C mobo: 30.0 C sodimm: 31.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 188 Uptime: 2d 3h 17m Memory: 7.64 GiB used: 1.61 GiB (21.1%) Init: systemd v: 246 Compilers:
gcc: 10.2.0 Packages: pacman: 1264 lib: 371 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
