[Unstable Update] May 2025
Welcome to the new monthly unstable branch thread.
Recent News
2025-04-17 - Andrew Crerar
  • As of Linux 6.13.12, the 6.13 series is now EOL (End Of Life). Please install 6.14 stable and/or 6.12 LTS (Long Term Support).
Notable Package Changes
Known Issues
2025-06-01 - avahi-discover python script
avahi-discover fails when attempting to write the disovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Change the ownership of the folder /usr/lib/avahi including files
sudo chown root:avahi /usr/lib/avahi -R
sudo chmod g+w /usr/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
Chrome/Chromium-based browsers and GNOME 48 - Global Shortcuts
If you have extensions who use shortcuts installed on these browsers, you’ll face an issue of many dialogs opening when the browser starts, it’s quite annoying. The bug has been reported and fixed, but the commit is not yet on a stable release.
The workaround for now, is to disable the feature via --disable-features=GlobalShortcutsPortal
– https://www.reddit.com/r/gnome/comments/1jfejor/psa_chromechromiumbased_browsers_and_gnome_48/
python-gobject 3.52 breaks multiple apps (libpeas related)
Python plugins for programs like Gedit and Rhythmbox currently will not be loaded in the current state.
python-gobject 3.52 breaks multiple apps (libpeas related) (#3) · Issues · Arch Linux / Packaging / Packages / pygobject · GitLab
For Gedit, use the Flatpak for now. See Some problems currently with Python and gedit plugins | Gedit Technology blog
Additional Info
Info about AUR packages
from last compile from topic Avril 2025
it’s ok on nvidia for maxwell for kernel 6.14 and 6.12 , ko for 6.6 ( i get only update 6.6 with header , no nvidia update ), so it does not work for kernel 6.6
Working on the missing modules now. I’ve just pushed linux66-nvidia and linux66-nvidia-open 570.144-3.
And now we have a fourth release of kernel 6.14.4. Why do we need so many patch updates to every single kernel version lately? I have now wasted 600 MB of bandwidth downloading the same kernel version four times.
Cos I’m adding support for a new device we will soon support pre-installed and might be available even in Stores to buy …
In the last 24 hours, the kernel upgrade failed three times.
I restored it three times, and it worked fine on the fourth try.
Even though it was the same version number, the contents were different.
I was struggling without noticing. lol)
You know the routine. Create a new Support topic.
We want information…information… information!!!
– Number Two
Thank you.
It seems that there are no problems at the moment, so I can’t take away other people’s valuable time. I can revert to the buggy state, but I have work and can’t have enough time to communicate.
There are no major problems. Pipewire just dies sometimes. I’m fixing it with my usual routine.
Thank you again.
This isn’t the same complaint I had. My complaint is that they’ve released 6.14.4-1, 6.14.4-2, 6.14.4-3, and 6.14.4-4 in the span of a few days.
Is 6.14.4-4 supposed to be fixed? Cause it doesn’t boot for me with nvidia. Had errors for missing modules during installation too.
Do you have linux614-nvidia installed?
Nope, had nvidia-open installed. Replaced it, works, thanks.
@ben75
I misunderstood.
Thank you for pointing that out.
my working memo
I had a bit of a hard time after number 17. It’s fine now.
Num     Name                 Tags     Description
13   >  2025-04-30_19-00-46  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-2-MANJARO Cinnamon 6.4.9  nemo 6.4.5 🌲 unstable🌶🌶🌶_nvme0n1p6_btrfs_/var/cache remove orphans webkit_zish_cinnamon
14   >  2025-04-30_19-07-58  B
15   >  2025-04-30_20-18-16  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-2-MANJARO Cinnamon 6.4.9  nemo 6.4.5 🌲 unstable🌶🌶🌶__zish_cinnamon
16   >  2025-05-01_08-28-00  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-2-MANJARO Cinnamon 6.4.9  nemo 6.4.5 🌲 unstable🌶🌶🌶_nvme0n1p6_btrfs_/var/cache 🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶🌶
17   >  2025-05-01_08-34-40  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-2-MANJARO  nemo 6.4.5 🌲 unstable🌶🌶🌶_nvme0n1p6_btrfs_/var/cache pkgs (163) appstream-1.0.5-2  archlinux-keyring-20250430.1-1  aria2-1.37.0-2  audacious-plugins-4.4.2-4  binutils-2.44+r94+gfe459e33c676-1  blackbox-terminal-0.14.0-3
                 caribou-0.4.21+75+g8ad9883-8  clang-19.1.7-2  conky-1.22.1-2  darktable-2:5.0.1-3  electron35-35.2.1-2  evince-48.0-3  evince-lib-docs-48.0-3  ffmpeg-2:7.1.1-1
                 ffmpeg4.4-4.4.5-5  flatpak-1:1.16.0-3  flickcurl-1.26-13  font-manager-0.9.4-2  foomatic-db-engine-5:20200131-2  gcc-15.1.1+r7+gf36ec88aa85a-1
                 gcc-libs-15.1.1+r7+gf36ec88aa85a-1  gcc-objc-15.1.1+r7+gf36ec88aa85a-1  gettext-0.24-3  ghostscript-10.05.1-1  glibc-2.41+r48+g5cb575ca9a3d-1
                 glibc-locales-2.41+r48+g5cb575ca9a3d-1  glusterfs-1:11.1-4  gnome-online-accounts-3.54.2-2  gnustep-base-1.30.0-3  graphicsmagick-1.3.45-4  gst-libav-1.26.1-1
                 gst-plugin-gtk-1.26.1-1  gst-plugins-bad-1.26.1-1  gst-plugins-bad-libs-1.26.1-1  gst-plugins-base-1.26.1-1  gst-plugins-base-libs-1.26.1-1  gst-plugins-good-1.26.1-1
                 gst-plugins-ugly-1.26.1-1  gst-python-1.26.1-1  gstreamer-1.26.1-1  gtksourceview3-1:3.24.11+r30+gd880929f-1  gtksourceview4-4.8.4-2  gupnp-1:1.6.8-2  gupnp-dlna-0.12.0-4
                 gvfs-1.57.2-3  gvfs-afc-1.57.2-3  gvfs-dnssd-1.57.2-3  gvfs-goa-1.57.2-3  gvfs-google-1.57.2-3  gvfs-gphoto2-1.57.2-3  gvfs-mtp-1.57.2-3  gvfs-smb-1.57.2-3
                 handbrake-1.9.2-3  harfbuzz-11.2.0-1  harfbuzz-icu-11.2.0-1  haskell-haddock-library-1.11.0-73  haskell-pandoc-3.1.12.1-58  haskell-pandoc-lua-engine-0.2.1.2-139
                 haskell-pandoc-server-0.1.0.5-160  hwloc-2.12.0-2  imagemagick-7.1.1.47-2  inkscape-1.4.1-3  kio-6.13.0-2  lib32-gcc-libs-15.1.1+r7+gf36ec88aa85a-1
                 lib32-glibc-2.41+r48+g5cb575ca9a3d-1  lib32-harfbuzz-11.2.0-1  lib32-libelf-0.193-1  lib32-librsvg-2:2.60.0-2  lib32-libxkbcommon-1.9.0-1  lib32-libxkbcommon-x11-1.9.0-1
                 lib32-libxml2-2.14.2-2  lib32-llvm-libs-1:19.1.7-2  libabw-0.1.3-5  libarchive-3.7.9-2  libbluray-1.3.4-3  libcmis-0.6.2-4  libe-book-0.1.3-18  libelf-0.193-2
                 libetonyek-0.1.12-3  libgdata-0.18.1-4  libgedit-gtksourceview-299.5.0-2  libgoa-3.54.2-2  libgphoto2-2.5.31-4  libgpod-0.8.3-17  libgsf-1.14.53-2  liblangtag-0.6.7-2
                 libmusicbrainz5-5.1.0-9  libnbd-1.22.1-2  libodfgen-0.1.8-4  libosinfo-1.12.0-2  libreoffice-still-24.8.6-3  librest-0.9.1-3  librsvg-2:2.60.0-2  libsoup-2.74.3-3
                 libsysprof-capture-48.0-5  libtool-2.5.4+r23+g5b582aed-1  libvirt-1:11.2.0-2  libvirt-glib-5.0.0-3  libvisio-0.1.8-3  libvlc-3.0.21-18  libxkbcommon-1.9.0-1
                 libxkbcommon-x11-1.9.0-1  libxklavier-5.4-6  libxml2-2.14.2-2  libxslt-1.1.43-2  linux612-6.12.25-2  linux612-headers-6.12.25-2  linux612-virtualbox-host-modules-7.1.8-8
                 linux612-zfs-2.3.1-16  linux614-6.14.4-3  linux614-headers-6.14.4-3  linux614-virtualbox-host-modules-7.1.8-9  linux614-zfs-2.3.1-12  llvm-19.1.7-2  llvm-libs-19.1.7-2
                 localsearch-3.9.0-3  mariadb-libs-11.7.2-3  mhwd-nvidia-570.144-3  mhwd-nvidia-390xx-390.157-20  mhwd-nvidia-470xx-470.256.02-11  mlt-7.30.0-2  netpbm-10.86.46-2
                 netstandard-targeting-pack-9.0.4.sdk105-1  networkmanager-openconnect-1.2.10-3  nfs-utils-2.8.3-2  nfsidmap-2.8.3-2  oath-toolkit-2.6.12-2  opencl-nvidia-570.144-3
                 openconnect-1:9.12-4  pandoc-cli-3.1.12.1-68  perl-alien-libxml2-0.20-1  perl-xml-libxml-2.0210-3  phodav-3.0-4  postgresql-libs-17.4-4  pyside6-6.9.0-2
                 python-lxml-5.3.2-2  python-orjson-3.10.18-1  python-typing_extensions-4.13.2-1  qpwgraph-0.9.0-1  qt5-webengine-5.15.18-7  qt6-webengine-6.9.0-5  raptor-2.0.16-7
                 rrdtool-1.9.0-6  shared-mime-info-2.4-2  shiboken6-6.9.0-2  shotwell-2:0.32.10-2  snapper-0.12.2-3  stoken-0.92-5  tinysparql-3.9.2-2  totem-pl-parser-3.26.6+r30+g51b8439-2
                 virtualbox-7.1.8-2  vlc-3.0.21-18  wayland-1.23.1-2  webkit2gtk-4.1-2.48.1-2  webkitgtk-6.0-2.48.1-2  xed-3.8.2-2  xmlsec-1.3.7-2  xreader-4.2.5-2  yelp-42.2-4
                 autoconf-archive-1:2024.10.16-2  dotnet-sdk-9.0.4.sdk105-1  dotnet-targeting-pack-9.0.4.sdk105-1  intltool-0.51.0-6_zish_cinnamon
18   >  2025-05-01_08-53-58  O B      🌶🌶🌶  0n1p6 btrfs  6.14.4-2-MANJARO Cinnamon 6.4.9  nemo 6.4.5 🌲 unstable🌶🌶🌶_restored🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾_zish_cinnamon
19   >  2025-05-01_09-00-22  B
20   >  2025-05-01_09-17-06  O        🌶🌶🌶  0n1p6 btrfs  6.12.25-1-MANJARO Cinnamon 6.4.9  nemo 6.4.5 🌲 unstable🌶🌶🌶_restored🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾🐾_zish_cinnamon
21   >  2025-05-01_09-41-08  O        🌶🌶🌶  1n1p6 btrfs  6.14.4-2-MANJARO Cinnamon 6.4.9  nemo 6.4.5 🌲 unstable🌶🌶🌶_nvme1n1p6_btrfs_/var/log _restored_restored_restored
22   >  2025-05-01_09-48-42  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-2-MANJARO Cinnamon 6.4.9  nemo 6.4.5 🌲 unstable🌶🌶🌶_----------------------------------RRRRRRRRRRRRRRRRRRR----------------------__restored
23   >  2025-05-01_09-58-20  O        Before restoring '2025-04-30 14:56:36'
24   >  2025-05-01_10-00-52  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-2-MANJARO Cinnamon 6.4.9  nemo 6.4.5 🌲 unstable🌶🌶🌶_RRRRRRRRRRRRRRRRRRR__restored
25   >  2025-05-01_10-09-52  B
26   >  2025-05-01_11-57-37  B
27   >  2025-05-01_17-55-45  B D
28   >  2025-05-01_22-13-03  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-2-MANJARO Cinnamon 6.4.9  nemo 6.4.5 🌲 unstable🌶🌶🌶_---------------------------------------_zish_cinnamon
29   >  2025-05-01_22-28-24  B
30   >  2025-05-01_22-38-04  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-3-MANJARO Cinnamon 6.4.10  nemo 6.4.5 🌲 unstable🌶🌶🌶_nvme0n1p6_btrfs_/var/log ================= iikanji_zish_cinnamon
31   >  2025-05-01_22-44-53  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-3-MANJARO Cinnamon 6.4.10  nemo 6.4.5 🌲 unstable🌶🌶🌶_❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤❤_zish_cinnamon
32   >  2025-05-01_22-52-38  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-4-MANJARO Cinnamon 6.4.10  nemo 6.4.5 🌲 unstable🌶🌶🌶_🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧🐧_zish_cinnamon
33   >  2025-05-01_22-58-33  O B      🌶🌶🌶  0n1p6 btrfs  6.14.4-4-MANJARO Cinnamon 6.4.10  nemo 6.4.5 🌲 unstable🌶🌶🌶_🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸_zish_cinnamon
34   >  2025-05-01_23-07-43  B        🌶🌶🌶  0n1p6 btrfs  6.14.4-4-MANJARO Cinnamon 6.4.10  nemo 6.4.5 🌲 unstable🌶🌶🌶_🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸🐸_zish_cinnamon
35   >  2025-05-02_01-36-34  O        🌶🌶🌶  0n1p6 btrfs  6.14.4-4-MANJARO Cinnamon 6.4.10  nemo 6.4.5 🌲 unstable🌶🌶🌶_パッケージ (15) electron35-35.2.2-1  firefox-138.0.1-1  firefox-i18n-en-us-138.0.1-1
                firefox-i18n-ja-138.0.1-1  gcc13-13.3.1+r432+gfc8bd63119c0-2
                gcc13-libs-13.3.1+r432+gfc8bd63119c0-2  js115-115.23.0-1  js128-128.10.0-1
                libnvme-1.13-1  libxdp-1.5.4-1  noto-fonts-1:2025.05.01-1
                noto-fonts-extra-1:2025.05.01-1  nvme-cli-2.13-1  xreader-4.2.6-1
                yt-dlp-2025.04.30-1_zish_cinnamon
36   >  2025-05-02_01-45-53  B
Currently. I feel like the whole DE has become slower, but it’s not a problem.
I can get the job done. In other words, I don’t need help.
A post was split to a new topic: Something about missing libxml2.so.2
3 posts were split to a new topic: Issue with NVIDIA 575.51.02 beta
linux614-header were marked as orphaned in pamac.
I knew I need this “because of some modules”
and marked this as “Expressly installed”.
I guess switch to Stable, or don’t do the updates if your have concerns about your bandwidth.
No thanks, I don’t want to wait 4-6 weeks for most security patches and bug fixes.
The following was handled successfully:
Nice.
zfs-2.3.2
With ZFS. If it’s up to date, it’s very fast. I’m amazed. I just saw the announcement on github.
:: 8 package to upgrade/install.
8  core/linux614                           6.14.4-4 -> 6.14.5-1
7  core/linux614-headers                   6.14.4-4 -> 6.14.5-1
6  core/linux66                            6.6.88-2 -> 6.6.89-1
5  core/linux66-headers                    6.6.88-2 -> 6.6.89-1
4  extra/linux614-virtualbox-host-modules  7.1.8-10 -> 7.1.8-11
3  extra/linux614-zfs                      2.3.1-13 -> 2.3.1-14
2  extra/linux66-virtualbox-host-modules   7.1.8-3  -> 7.1.8-4
1  extra/linux66-zfs                       2.3.1-8  -> 2.3.1-9
Good job, maintenance team.
kernel 6.14 + nvidia-open
does that work for you?
or just not for me ?
