Welcome to the new monthly unstable branch thread.
Recent News
New in Manjaro GNOME!
When choosing an accent color in Settings, the folder colors will now change automatically to match when using the Papirus Dark or Papirus Light icon theme.
To try it out, install gnome-shell-extension-papirus-folders-colorizer from Add/Remove Software, logout / login and enable Papirus Folder Colorizer from Extensions.
Or, if you prefer the command line:
Install:
sudo pacman -Syu gnome-shell-extension-papirus-folders-colorizer
Enable the extension:
gnome-extensions enable papirus-folders-colorizer@NiffirgkcaJ.github.com
Logout:
gnome-session-quit --logout
Also, when applying accent colors from Layout Switcher settings, it will also set the matching folder color. Requires accent-color-change r172.c761c84-2 or newer.
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
Kernel 5.4 is now EOL
5.4.302 is the last maintenance release of the 5.4 kernel series. This kernel is now marked ‘End Of Life’ (EOL). It is recommend to switch to a newer LTS series like 5.10 or 5.15.
Kernel 6.17 is now EOL
6.17.13 is the last maintenance release of the 6.17 kernel series. This kernel is now marked ‘End Of Life’ (EOL). It is recommend to switch to the newer linux618 series:
sudo mhwd-kernel -i linux618
[DRAFT] NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
- Install the official
linuxXXX-nvidia-575xx,linuxXXX-nvidia-570xx, or related DKMS packages.
Notable Package Changes
- COSMIC Epoch 1.0.5 / 1.0.6 / 1.0.7 / 1.0.8
- KDE Gear 25.12.2
- LibreOffice 26.2, 26.2.1 / 25.8.5
- Systemd 259
- Mesa 25.3.5
- WebKitGTK 2.50.5
- CrossOver 26
- GNOME 49.4
- KDE Frameworks 6.23.0
- GStreamer 1.28.0, 1.28.1
- NVIDIA 580.126.18
- KDE Plasma 6.6.1
- Firefox 148.0
- Mesa 26.0.1
- Thunderbird 148.0
Known Issues
Additional Info
Python 3.14 info
You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.13.so.
Rebuild them all at once:*
checkrebuild
Info about AUR packages
AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcements topics are off-topic and will be flagged, moved or removed without warning.
