[Unstable Update] 2023-05-15 - Kernels, KDE Frameworks 5.106.0, KiCAD 7.0.3, Python, Haskell
Hello community,
Another unstable branch update with some usual package updates for you.
Recent News:
  • Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
  • As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
Previous News
Notable Package Updates:
  • Realtime Kernel got updated to 6.3.1 and 6.4 kernel series has its second release candidate
  • KDE Frameworks got renewed to 5.106.0
  • kicad is now at 7.0.3
  • Usual KDE-git, Python and Haskell updates
Additional Info
Info about Python 3.11
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.10.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.10/ :
pacman -Qoq /usr/lib/python3.10/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.10)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
Our current supported kernels
  • linux419 4.19.282
  • linux54 5.4.242
  • linux510 5.10.179
  • linux515 5.15.111
  • linux61 6.1.28
  • linux62 6.2.15
  • linux63 6.3.2
  • linux64 6.4-rc2
  • linux62-rt 6.2.0_rt3
  • linux63-rt 6.3.1_rt13
Package Changes (Mon May 15 16:40:54 CEST 2023)
A detailed list of all package changes can be found here
0 voters
Known issues and solutions
Please, consider subscribing to the Unstable Updates Announcements RSS feed
:arrow_right: 2023-05-15
2023-05-06
Many applications (firefox, thunderbird, etc) slow to start on desktops other than Gnome
There is a bug with xdg-desktop-portal-gnome (more details here).
Workaround for gtk-based desktops (including Xfce)
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
Workaround for KDE
sudo pacman -S xdg-desktop-portal-kde
Workaround for Lxqt
sudo pacman -S xdg-desktop-portal-lxqt
Workaround for desktops using hyprland
sudo pacman -S xdg-desktop-portal-hyprland
Workaround for desktops using wlroots
sudo pacman -S xdg-desktop-portal-wlr
2023-05-03
Help with upgrading Python packages that were installed from AUR or PyPI
checkrebuild
See also:
[HowTo] After a Python interpreter upgrade, reinstall non-working Python packages
2023-04-07
2023-03-31
GRUB: some backwards hardware compatibility has been restored
A modification has been reverted in order to restore support to old motherboards: [Unstable Update] 2023-02-17 - Plasma 5.27 LTS, GNOME, Python - #51 by philm
GRUB, LUKS and full disk encryption: 'no such cryptodisk found'
Following grub’s update, new configuration may be needed to be manually applied:
  • Check for modifications to /etc/default/grub
    Most notably, if you use LUKS with full disk encryption, you may need to:
    • check that GRUB_ENABLE_CRYPTODISK=y is not commented out
  • Don’t use tools like grub-customizer as it may create issues with the grub.cfg file.
  • Check if the UUID of your encrypted drive matches in your config files.
  • Based on the manual, unlike filesystem UUIDs, UUIDs for encrypted devices must be specified without dash separators. So check /boot/grub/grub.cfg for entries like cryptomount -u 3722dfb2-3b32-414b-bd59-4329fa92b6a9 and try to remove the dash separators.
  • If you modified the above configuration, you then need to update the grub menu with sudo update-grub.
  • A message “no such cryptodisk found” may appear on the following reboot, but should not prevent you from continuing by typing any key.
You may still want to have a liveUSB ready, in the rare case your bootloader does break, in which case you will need to reinstall grub.
For more details:
Info about recent NVIDIA packaging changes
[Testing Update] 2023-03-25 - Kernels, Firefox, Deepin, GNOME, NVIDIA, Wine - #42 by philm
Possible kernel fs block code regression in 6.2.3 umounting usb drives
With kernel 6.2.3 when you simply plug in a usb external drive, mount it and umount it, then the journal has a kernel Oops. A bug report, that includes the journal output was submitted at. Making sure you're not a bot! Discussion can be found here: https://www.spinics.net/lists/stable/msg637035.html
kernel 5.15.99+ Black/empty screen during boot with i915 Intel gfx. No ways to do anything
Seems there is a regression introduced with 5.15.99 kernel update: Making sure you're not a bot!. My thoughts here: [Testing Update] 2023-03-11 - Kernels, Mesa 22.3.7, Phosh, LibreOffice 7.4.6 - #31 by philm
NVIDIA 530.41.03-1 high refresh rate problems
FS#77975 - [nvidia] 530.41.03-1 high refresh rate problems
2023-02-12
Switch to the base-devel meta package requires manual intervention
2023-02-12 - Robin Candau
On February 2nd, the base-devel package group has been replaced by a meta package of the same name.
If you installed the base-devel package group prior to this date, explicitly re-install it to get the new base-devel package installed on the system:
pacman -Syu base-devel
– Arch Linux - News: Switch to the base-devel meta package requires manual intervention
2023-02-03
vlc player crashes while playing videos
A solution, regarding to rob215x, is:
VLC would crash immediately when trying to play any video. I opened VLC directly, and changed Preferences > Video > Output from “Automatic” to “VDPAU” and it works now. I found that solution on another thread but I still don’t understand the problem and why VDPAU works.
2023-01-24
PHP 8.2 update and introduction of legacy branch
2023-01-13 - Pierre Schmitz
The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. These will follow the oldest but still actively supported PHP branch. This enables users to install the latest version but also introduces the option to use third party applications that might rely on an older version. Both branches will be kept up to date following our rolling release model. php and php-legacy can be installed at the same time as the latter uses a -legacy suffix for its binaries and configuration files.
In addition to this, the php7 packages have been removed as they reached end of life. The imap extension will no longer be provided as it relies on the c-client library which has been abandoned for many years.
– Arch Linux - News: PHP 8.2 update and introduction of legacy branch
2022-12-20
pacman-mirrors was temporarily renamed to manjaro-mirrors (changed has been reverted)
This was done to avoid confusion with an AUR / WSL package with the same name and avoid possible breakage. It should be a seamless transition.
Sign in · GitLab You will need to rebuild any AUR Python packages that install files to site-packages. :information_source:
Print a list of them:
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.s/-/issues/183
dbus-x11 demoted to AUR
dbus-x11 was installed out of the box on some flavors of Manjaro as of a year ago, but is no longer needed. If you have it installed, please replace it with dbus using the following:
sudo pacman -Syu dbus
XFCE becomes unusable if libxfce4ui-nocsd is still installed
XFCE Classic project became obsolete with the 4.18 series and is no longer required. If you still have it installed, please replace it with the normal package:
sudo pacman -S libxfce4ui
Somebody knows why journalctl warning:
archlinux kernel: memfd_create() without MFD_EXEC nor MFD_NOEXEC_SEAL, pid=1 'systemd'
in kernel 6.3 and kernel 6.4
In short: no.
I researched yesterday about some bug reports and fixes / patches for that but found nothing useful about it.
This link for detailed discussion (I’ve seen it mentioned before)
https://lore.kernel.org/linux-security-module/20221209160453.3246150-4-jeffxu@google.com/
API changed for memfd_create (that creates temp memory files) that requires a caller to explicitely set (at creation) whether file is executable or not (the +x flag). This is to close a security ‘loophole’ if running as root.
When you make a (breaking) change like this you can a) require all callers (including kernel, modules etc.) to adjust their code immediatelly and wreak havoc in the linux community, or b) you give devs e.g. one year, you allow for code to function as before and just issue a warning.
Nothing to do with you or me (I have it too) I’d say.
acpi-cpufreq: probe of acpi-cpufreq failed with error -17
==> [PATCH] ACPI: cpufreq: Prevent a warning when another frequency driver is loaded - Petr Pavlu
Here:
cpupower frequency-info
CPU 5 wird analysiert:
driver: amd-pstate
only one more nasty warning (kernel 6.4.0-1) (rc2)
EDIT:
has gone meantime (rc3)
The acpi-cpufreq should not be loaded when amd-pstate is in use…
