The patch is added again to the previous Kernel Series (shipped with next Kernel updates):
Sure does. What browser are you using to create them?
@codesardine forked the project to include JAK support.
I use Vivaldi. I uninstalled it and installed AUR git version, itās the same.
I tried the manjaro version, which hasnāt the same version nor compiling date, it works.
And in a VM with still stable version 1.1.5.1, I can create webapps with Firefox and Vivaldi.
When i installed my system last week, I was still in 1.1.5.1 and it worked with Vivaldi back then. I suspect something with 1.1.5.2.
Aha! I did break something. I just figured out a better way to fix the original issue.
Iāll be pushing 1.1.5+1+g2f3e132-1 here a few minutes.
What was the naughty code doing?
Itās like if the generated *.desktop files werenāt recognized by the system and could not be launched with the browser.
In short, browser binary names are different on Linux Mint than on Arch-based distros.
It works again, thanks @Yochanan !
manjaro-kde-settings brings a weird regression of the breath2 theme: all title bars are gray and the chosen colors donāt seem to have any effect.
See discussion here:
This is odd, because on my side thereās no any issues with titlebar colors. I use Breath2 2021 Light but did check other (light) variants too.
Iām using and seeing the issue with breath2 dark.
(rootless) podman 3.2.3-1 doesnāt work with containers-common 0.43.0-1:
Error: open /proc/sys/net/ipv4/ping_group_range : No such file or directory: OCI runtime attempted to invoke a command that was not found
Downgrading containers-common to 0.42.1-2 resolves the issue.
After the recent batch of updates, conainers-common 0.43.0-1 works for rootless podman (although that package wasnāt updated). Could have been made function after recent kernel updates.
in today update:
ldconfig: /usr/lib/libpamac-snap.so.11 is not a symbolic link
ldconfig: /usr/lib/libpamac-flatpak.so.11 is not a symbolic link
should I worry about it?
Wow. That thread of unstable branch is open and newest for almost 3 months. The stable branch got new topics more frequently
Unstable branch get updates every dayā¦
for a branch that gets updates everyday, it is also the quietest, and the least fuzziest
For a week or so thereās a strange issue happening again and again: sometimes all graphical interface (except mouse cursor) becomes very slow-mo, like 2 FPS or so, only when compositing enabled, disabling the latter āresolvesā that. It always begins when I set āPress Super to activate Application Launcherā in Latte settings, but sometimes it starts when a disabled compositing gets enabled again (say, after a fullscreen game is closed).
I tried to search logs for any hint what could be wrong but I had no luck.
This is just a quick draft. I still have no idea whether it has something to do with driver (i915/nvidia/nouveau) or recent Xorg updates.
But still hereās a new post you were waiting for guys
Unstable is full of hidden āgemsā.
Lol I found a culprit. And it is really hilarious and unexpectable.
If any of you guys have a dual monitor setup, set your screens like this, then disable compositing and enable it again:
To make this slow-mo youāre likely experiencing now disappear just press Ctrl+Shift+F12 to quickly disable compositing and align your screens back.
Interestingly, a bug report already exists:
https://bugs.kde.org/show_bug.cgi?id=433664
Found that the
glibc 2.33-5
$ pacman -Qi glibc
Version : 2.33-5
Description : GNU C Library
Architecture : x86_64
URL : https://www.gnu.org/software/libc
Licenses : GPL LGPL
Groups : None
Provides : None
Depends On : linux-api-headers>=4.10 tzdata filesystem
Optional Deps : gd: for memusagestat [installed]
Required By : a52dec acpi alsa-lib alsa-oss alsa-plugins alsa-utils apparmor argon2 attr audacity audit b43-fwcutter bash binutils bluez-libs brotli btrfs-progs
bubblewrap bzip2 c-ares cdparanoia chromaprint cmark confuse coreutils cpupower dav1d device-mapper dhclient dhcpcd diffutils ding-libs discount dmidecode
dnsmasq dosfstools efibootmgr efivar elfutils exfat-utils expat faac faad2 fftw file findutils fluidsynth fribidi fuse2 fuse3 gawk gcc-libs gdbm giflib
glibc-locales gnupg grep gsm gzip haveged hdparm http-parser hwloc hyphen ijs iproute2 jack2 jansson jasper json-c kbd keyutils kmod krb5 l-smash
less libao libass libassuan libasyncns libavif libavtp libbsd libcap libcap-ng libcddb libdatrie libdmtx libdvbpsi libdvdcss libdvdread libedit libepoxy
libevdev libexif libffi libfreeaptx libgit2 libgpg-error libical libice libid3tag libidn libinih libinstpatch libjpeg-turbo libksba libldac libmad libmd
libmicrodns libmikmod libmms libmnl libmpcdec libmpdclient libmpeg2 libndp libnfnetlink libnfs libnghttp2 libnl libnsl libogg libomxil-bellagio libp11-kit
libpcap libpciaccess libpgm libpipeline libplacebo libraw1394 libsamplerate libseccomp libsndfile libsodium libstemmer libtasn1 libtiff libtommath libtool
libunistring libupnp liburing libusb libutempter libuv libvisual libxau libxcrypt libxdmcp libxshmfence lilv lmdb lsof lz4 lzo md4c mdadm
mkinitcpio-busybox mkvtoolnix-cli mpd mpfr mtdev ncurses npth nspr nss-mdns opencore-amr openmpi openssh openssl opera-ffmpeg-codecs opus orc ostree
pacman pam pciutils perl pinentry pixman popt portaudio portsmf ppp procps-ng protobuf raptor rav1e readline rpcbind rtmpdump run-parts sane sbc sdl
sdl2 sed serd shaderc snappy socat sord speexdsp sratom sudo suil svt-av1 sysfsutils systemd-libs talloc tar tdb tslib twolame usbutils v86d
vamp-plugin-sdk vid.stab vscodium-bin vulkan-icd-loader wavpack wayland wget which xapian-core xf86-input-elographics xf86-input-void xvidcore yajl zimg
zita-alsa-pcmi zita-resampler zlib zsh-theme-powerlevel10k zstd
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 46.01 MiB
Packager : Giancarlo Razzolini <edit: hidden>
Build Date : Wed 12 May 2021 22:18:40 EEST
Install Date : Tue 24 Aug 2021 05:52:35 EEST
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
package installer behaves abnormally (if to re-install the package):
(4/8) Restoring locales
call to execv failed (No such file or directory)
error: command failed to execute correctly
(5/8) Restarting cronie for libc upgrade...
which affects (probably warns only) at least:
$ man pacman
man: can't set the locale; make sure $LC_* and $LANG are correct
$ man man
$ locale
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Details
$ sudo pacman -Syu
:: Synchronising package databases...
core is up to date
extra is up to date
community is up to date
there is nothing to do
$ pacman -Qo locale-gen
/usr/bin/locale-gen is owned by glibc 2.33-5
$ locale
LANG=en_GB.UTF-8
LC_CTYPE="en_GB.UTF-8"
LC_NUMERIC="en_GB.UTF-8"
LC_TIME="en_GB.UTF-8"
LC_COLLATE="en_GB.UTF-8"
LC_MONETARY="en_GB.UTF-8"
LC_MESSAGES="en_GB.UTF-8"
LC_PAPER="en_GB.UTF-8"
LC_NAME="en_GB.UTF-8"
LC_ADDRESS="en_GB.UTF-8"
LC_TELEPHONE="en_GB.UTF-8"
LC_MEASUREMENT="en_GB.UTF-8"
LC_IDENTIFICATION="en_GB.UTF-8"
LC_ALL=
$ locale -a
aa_DJ.utf8
aa_ER.utf8
aa_ER.utf8@saaho
aa_ET.utf8
af_ZA.utf8
agr_PE.utf8
ak_GH.utf8
am_ET.utf8
an_ES.utf8
anp_IN.utf8
ar_AE.utf8
ar_BH.utf8
ar_DZ.utf8
ar_EG.utf8
ar_IN.utf8
ar_IQ.utf8
ar_JO.utf8
ar_KW.utf8
ar_LB.utf8
ar_LY.utf8
ar_MA.utf8
ar_OM.utf8
ar_QA.utf8
ar_SA.utf8
ar_SD.utf8
ar_SS.utf8
ar_SY.utf8
ar_TN.utf8
ar_YE.utf8
as_IN.utf8
ast_ES.utf8
ayc_PE.utf8
az_AZ.utf8
az_IR.utf8
be_BY.utf8
be_BY.utf8@latin
bem_ZM.utf8
ber_DZ.utf8
ber_MA.utf8
bg_BG.utf8
bhb_IN.utf8
bho_IN.utf8
bho_NP.utf8
bi_VU.utf8
bn_BD.utf8
bn_IN.utf8
bo_CN.utf8
bo_IN.utf8
br_FR.utf8
brx_IN.utf8
bs_BA.utf8
byn_ER.utf8
C
ca_AD.utf8
ca_ES.utf8
ca_ES.utf8@valencia
ca_FR.utf8
ca_IT.utf8
ce_RU.utf8
chr_US.utf8
cmn_TW.utf8
crh_UA.utf8
csb_PL.utf8
cs_CZ.utf8
cv_RU.utf8
cy_GB.utf8
da_DK.utf8
de_AT.utf8
de_BE.utf8
de_CH.utf8
de_DE.utf8
de_IT.utf8
de_LI.utf8
de_LU.utf8
doi_IN.utf8
dsb_DE.utf8
dv_MV.utf8
dz_BT.utf8
el_CY.utf8
el_GR.utf8
en_AG.utf8
en_AU.utf8
en_BW.utf8
en_CA.utf8
en_DK.utf8
en_GB.utf8
en_HK.utf8
en_IE.utf8
en_IL.utf8
en_IN.utf8
en_NG.utf8
en_NZ.utf8
en_PH.utf8
en_SC.utf8
en_SG.utf8
en_US.utf8
en_ZA.utf8
en_ZM.utf8
en_ZW.utf8
eo.utf8
es_AR.utf8
es_BO.utf8
es_CL.utf8
es_CO.utf8
es_CR.utf8
es_CU.utf8
es_DO.utf8
es_EC.utf8
es_ES.utf8
es_GT.utf8
es_HN.utf8
es_MX.utf8
es_NI.utf8
es_PA.utf8
es_PE.utf8
es_PR.utf8
es_PY.utf8
es_SV.utf8
es_US.utf8
es_UY.utf8
es_VE.utf8
et_EE.utf8
eu_ES.utf8
fa_IR.utf8
ff_SN.utf8
fi_FI.utf8
fil_PH.utf8
fo_FO.utf8
fr_BE.utf8
fr_CA.utf8
fr_CH.utf8
fr_FR.utf8
fr_LU.utf8
fur_IT.utf8
fy_DE.utf8
fy_NL.utf8
ga_IE.utf8
gd_GB.utf8
gez_ER.utf8
gez_ER.utf8@abegede
gez_ET.utf8
gez_ET.utf8@abegede
gl_ES.utf8
gu_IN.utf8
gv_GB.utf8
hak_TW.utf8
ha_NG.utf8
he_IL.utf8
hif_FJ.utf8
hi_IN.utf8
hne_IN.utf8
hr_HR.utf8
hsb_DE.utf8
ht_HT.utf8
hu_HU.utf8
hy_AM.utf8
ia_FR.utf8
id_ID.utf8
ig_NG.utf8
ik_CA.utf8
is_IS.utf8
it_CH.utf8
it_IT.utf8
iu_CA.utf8
ja_JP.utf8
kab_DZ.utf8
ka_GE.utf8
kk_KZ.utf8
kl_GL.utf8
km_KH.utf8
kn_IN.utf8
kok_IN.utf8
ko_KR.utf8
ks_IN.utf8
ks_IN.utf8@devanagari
ku_TR.utf8
kw_GB.utf8
ky_KG.utf8
lb_LU.utf8
lg_UG.utf8
li_BE.utf8
lij_IT.utf8
li_NL.utf8
ln_CD.utf8
lo_LA.utf8
lt_LT.utf8
lv_LV.utf8
lzh_TW.utf8
mag_IN.utf8
mai_IN.utf8
mai_NP.utf8
mfe_MU.utf8
mg_MG.utf8
mhr_RU.utf8
mi_NZ.utf8
miq_NI.utf8
mjw_IN.utf8
mk_MK.utf8
ml_IN.utf8
mni_IN.utf8
mn_MN.utf8
mnw_MM.utf8
mr_IN.utf8
ms_MY.utf8
mt_MT.utf8
my_MM.utf8
nan_TW.utf8
nan_TW.utf8@latin
nb_NO.utf8
nds_DE.utf8
nds_NL.utf8
ne_NP.utf8
nhn_MX.utf8
niu_NU.utf8
niu_NZ.utf8
nl_AW.utf8
nl_BE.utf8
nl_NL.utf8
nn_NO.utf8
nr_ZA.utf8
nso_ZA.utf8
oc_FR.utf8
om_ET.utf8
om_KE.utf8
or_IN.utf8
os_RU.utf8
pa_IN.utf8
pap_AW.utf8
pap_CW.utf8
pa_PK.utf8
pl_PL.utf8
POSIX
ps_AF.utf8
pt_BR.utf8
pt_PT.utf8
quz_PE.utf8
raj_IN.utf8
ro_RO.utf8
ru_RU.utf8
ru_UA.utf8
rw_RW.utf8
sah_RU.utf8
sa_IN.utf8
sat_IN.utf8
sc_IT.utf8
sd_IN.utf8
sd_IN.utf8@devanagari
se_NO.utf8
sgs_LT.utf8
shn_MM.utf8
shs_CA.utf8
sid_ET.utf8
si_LK.utf8
sk_SK.utf8
sl_SI.utf8
sm_WS.utf8
so_DJ.utf8
so_ET.utf8
so_KE.utf8
so_SO.utf8
sq_AL.utf8
sq_MK.utf8
sr_ME.utf8
sr_RS.utf8
sr_RS.utf8@latin
ss_ZA.utf8
st_ZA.utf8
sv_FI.utf8
sv_SE.utf8
sw_KE.utf8
sw_TZ.utf8
szl_PL.utf8
ta_IN.utf8
ta_LK.utf8
tcy_IN.utf8
te_IN.utf8
tg_TJ.utf8
the_NP.utf8
th_TH.utf8
ti_ER.utf8
ti_ET.utf8
tig_ER.utf8
tk_TM.utf8
tl_PH.utf8
tn_ZA.utf8
to_TO.utf8
tpi_PG.utf8
tr_CY.utf8
tr_TR.utf8
ts_ZA.utf8
tt_RU.utf8
tt_RU.utf8@iqtelif
ug_CN.utf8
uk_UA.utf8
unm_US.utf8
ur_IN.utf8
ur_PK.utf8
uz_UZ.utf8
uz_UZ.utf8@cyrillic
ve_ZA.utf8
vi_VN.utf8
wa_BE.utf8
wae_CH.utf8
wal_ET.utf8
wo_SN.utf8
xh_ZA.utf8
yi_US.utf8
yo_NG.utf8
yue_HK.utf8
yuw_PG.utf8
zh_CN.utf8
zh_HK.utf8
zh_SG.utf8
zh_TW.utf8
zu_ZA.utf8
$ man pacman
$ man man
$ sudo pacman -S glibc
warning: glibc-2.33-5 is up to date -- reinstalling
resolving dependencies...
Package (1) Old Version New Version Net Change Download Size
core/glibc 2.33-5 2.33-5 0.00 MiB 9.83 MiB
Total Download Size: 9.83 MiB
Total Installed Size: 46.01 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
glibc-2.33-5-x86_64 9.8 MiB 3.08 MiB/s 00:03 [####################################################################] 100%
(1/1) checking keys in keyring [####################################################################] 100%
(1/1) checking package integrity [####################################################################] 100%
(1/1) loading package files [####################################################################] 100%
(1/1) checking for file conflicts [####################################################################] 100%
(1/1) checking available disk space [####################################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
Found 3 snapshot(s)
done
(1/1) reinstalling glibc [####################################################################] 100%
Generating locales...
en_US.UTF-8... done
Generation complete.
(1/8) Reloading system manager configuration...
(2/8) Creating temporary files...
(3/8) Arming ConditionNeedsUpdate...
(6/8) Refreshing PackageKit...
(7/8) Modifying 'locale-gen'
(8/8) Updating the info directory file...
$ man pacman
$ man man
$ locale
LANG=en_GB.UTF-8
LC_ALL=
$ locale -a
locale: Cannot set LC_COLLATE to default locale: No such file or directory
C
POSIX
en_US.utf8
$ sudo locale-gen
en_US.UTF-8... done
Copying saved locales...
Copying complete.
$ man pacman
$ man man
$ locale
LANG=en_GB.UTF-8
LC_ALL=
$ locale -a
aa_DJ.utf8
aa_ER.utf8
aa_ER.utf8@saaho
aa_ET.utf8
af_ZA.utf8
agr_PE.utf8
ak_GH.utf8
am_ET.utf8
an_ES.utf8
anp_IN.utf8
ar_AE.utf8
ar_BH.utf8
ar_DZ.utf8
ar_EG.utf8
ar_IN.utf8
ar_IQ.utf8
ar_JO.utf8
ar_KW.utf8
ar_LB.utf8
ar_LY.utf8
ar_MA.utf8
ar_OM.utf8
ar_QA.utf8
ar_SA.utf8
ar_SD.utf8
ar_SS.utf8
ar_SY.utf8
ar_TN.utf8
ar_YE.utf8
as_IN.utf8
ast_ES.utf8
ayc_PE.utf8
az_AZ.utf8
az_IR.utf8
be_BY.utf8
be_BY.utf8@latin
bem_ZM.utf8
ber_DZ.utf8
ber_MA.utf8
bg_BG.utf8
bhb_IN.utf8
bho_IN.utf8
bho_NP.utf8
bi_VU.utf8
bn_BD.utf8
bn_IN.utf8
bo_CN.utf8
bo_IN.utf8
br_FR.utf8
brx_IN.utf8
bs_BA.utf8
byn_ER.utf8
C
ca_AD.utf8
ca_ES.utf8
ca_ES.utf8@valencia
ca_FR.utf8
ca_IT.utf8
ce_RU.utf8
chr_US.utf8
cmn_TW.utf8
crh_UA.utf8
csb_PL.utf8
cs_CZ.utf8
cv_RU.utf8
cy_GB.utf8
da_DK.utf8
de_AT.utf8
de_BE.utf8
de_CH.utf8
de_DE.utf8
de_IT.utf8
de_LI.utf8
de_LU.utf8
doi_IN.utf8
dsb_DE.utf8
dv_MV.utf8
dz_BT.utf8
el_CY.utf8
el_GR.utf8
en_AG.utf8
en_AU.utf8
en_BW.utf8
en_CA.utf8
en_DK.utf8
en_GB.utf8
en_HK.utf8
en_IE.utf8
en_IL.utf8
en_IN.utf8
en_NG.utf8
en_NZ.utf8
en_PH.utf8
en_SC.utf8
en_SG.utf8
en_US.utf8
en_ZA.utf8
en_ZM.utf8
en_ZW.utf8
eo.utf8
es_AR.utf8
es_BO.utf8
es_CL.utf8
es_CO.utf8
es_CR.utf8
es_CU.utf8
es_DO.utf8
es_EC.utf8
es_ES.utf8
es_GT.utf8
es_HN.utf8
es_MX.utf8
es_NI.utf8
es_PA.utf8
es_PE.utf8
es_PR.utf8
es_PY.utf8
es_SV.utf8
es_US.utf8
es_UY.utf8
es_VE.utf8
et_EE.utf8
eu_ES.utf8
fa_IR.utf8
ff_SN.utf8
fi_FI.utf8
fil_PH.utf8
fo_FO.utf8
fr_BE.utf8
fr_CA.utf8
fr_CH.utf8
fr_FR.utf8
fr_LU.utf8
fur_IT.utf8
fy_DE.utf8
fy_NL.utf8
ga_IE.utf8
gd_GB.utf8
gez_ER.utf8
gez_ER.utf8@abegede
gez_ET.utf8
gez_ET.utf8@abegede
gl_ES.utf8
gu_IN.utf8
gv_GB.utf8
hak_TW.utf8
ha_NG.utf8
he_IL.utf8
hif_FJ.utf8
hi_IN.utf8
hne_IN.utf8
hr_HR.utf8
hsb_DE.utf8
ht_HT.utf8
hu_HU.utf8
hy_AM.utf8
ia_FR.utf8
id_ID.utf8
ig_NG.utf8
ik_CA.utf8
is_IS.utf8
it_CH.utf8
it_IT.utf8
iu_CA.utf8
ja_JP.utf8
kab_DZ.utf8
ka_GE.utf8
kk_KZ.utf8
kl_GL.utf8
km_KH.utf8
kn_IN.utf8
kok_IN.utf8
ko_KR.utf8
ks_IN.utf8
ku_TR.utf8
kw_GB.utf8
ky_KG.utf8
lb_LU.utf8
lg_UG.utf8
li_BE.utf8
lij_IT.utf8
li_NL.utf8
ln_CD.utf8
lo_LA.utf8
lt_LT.utf8
lv_LV.utf8
lzh_TW.utf8
mag_IN.utf8
mai_IN.utf8
mai_NP.utf8
mfe_MU.utf8
mg_MG.utf8
mhr_RU.utf8
mi_NZ.utf8
miq_NI.utf8
mjw_IN.utf8
mk_MK.utf8
ml_IN.utf8
mni_IN.utf8
mn_MN.utf8
mnw_MM.utf8
mr_IN.utf8
ms_MY.utf8
mt_MT.utf8
my_MM.utf8
nan_TW.utf8
nan_TW.utf8@latin
nb_NO.utf8
nds_DE.utf8
nds_NL.utf8
ne_NP.utf8
nhn_MX.utf8
niu_NU.utf8
niu_NZ.utf8
nl_AW.utf8
nl_BE.utf8
nl_NL.utf8
nn_NO.utf8
nr_ZA.utf8
nso_ZA.utf8
oc_FR.utf8
om_ET.utf8
om_KE.utf8
or_IN.utf8
os_RU.utf8
pa_IN.utf8
pap_AW.utf8
pap_CW.utf8
pa_PK.utf8
pl_PL.utf8
POSIX
ps_AF.utf8
pt_BR.utf8
pt_PT.utf8
quz_PE.utf8
raj_IN.utf8
ro_RO.utf8
ru_RU.utf8
ru_UA.utf8
rw_RW.utf8
sah_RU.utf8
sa_IN.utf8
sat_IN.utf8
sc_IT.utf8
sd_IN.utf8
se_NO.utf8
sgs_LT.utf8
shn_MM.utf8
shs_CA.utf8
sid_ET.utf8
si_LK.utf8
sk_SK.utf8
sl_SI.utf8
sm_WS.utf8
so_DJ.utf8
so_ET.utf8
so_KE.utf8
so_SO.utf8
sq_AL.utf8
sq_MK.utf8
sr_ME.utf8
sr_RS.utf8
sr_RS.utf8@latin
ss_ZA.utf8
st_ZA.utf8
sv_FI.utf8
sv_SE.utf8
sw_KE.utf8
sw_TZ.utf8
szl_PL.utf8
ta_IN.utf8
ta_LK.utf8
tcy_IN.utf8
te_IN.utf8
tg_TJ.utf8
the_NP.utf8
th_TH.utf8
ti_ER.utf8
ti_ET.utf8
tig_ER.utf8
tk_TM.utf8
tl_PH.utf8
tn_ZA.utf8
to_TO.utf8
tpi_PG.utf8
tr_CY.utf8
tr_TR.utf8
ts_ZA.utf8
tt_RU.utf8
tt_RU.utf8@iqtelif
ug_CN.utf8
uk_UA.utf8
unm_US.utf8
ur_IN.utf8
ur_PK.utf8
uz_UZ.utf8
uz_UZ.utf8@cyrillic
ve_ZA.utf8
vi_VN.utf8
wa_BE.utf8
wae_CH.utf8
wal_ET.utf8
wo_SN.utf8
xh_ZA.utf8
yi_US.utf8
yo_NG.utf8
yue_HK.utf8
yuw_PG.utf8
zh_CN.utf8
zh_HK.utf8
zh_SG.utf8
zh_TW.utf8
zu_ZA.utf8
Every time I install Linux514 kernel it messes up the older kernels and I have to reinstall the older kernels.
Also Jack server doesnt start with 5.14 Kernel and if I try to start it manually it freezes the PC.
