Arch totally botched the pulseeffects
5.0 update. 5.0 will only work with Pipewire.
5 posts were split to a new topic: Looking for recent ISO
PHP 8.0 and PHP 7 legacy packages are available
2021-01-28 - Pierre Schmitz
The php package has been updated to version 8.0. Please refer to the upstream migration guide. As some applications are not compatible with PHP 8 yet we provide a php7 package which can be installed alongside version 8. Packages that depend on PHP reflect this update and will require php7 if needed. You might need to update your configuration accordingly. PHP 7 binaries and configuration have the “7” suffix:
- /usr/bin/php → /usr/bin/php7
- /etc/php → /etc/php7
- /usr/bin/php-fpm → /usr/bin/php-fpm7
- /usr/lib/systemd/system/php-fpm.service → /usr/lib/systemd/system/php-fpm7.service
- /run/php-fpm → /run/php-fpm7
We also provide third party modules compiled for PHP 7:
- php7-apcu
- php7-geoip
- php7-grpc
- php7-igbinary
- php7-imagick
- php7-memcache
- php7-memcached
- php7-mongodb
- php7-redis
Note that support for php7 will be limited and likely be dropped in about a year depending on how soon the majority of applications will be compatible with version 8.
https://archlinux.org/news/php-80-and-php-7-legacy-packages-are-available/
At shutdown “many” terminal messages running all over the screen
NOT (!) at reboot.
Regards:
Kernel 510 (5.10.11-1)
Kernel 511 (5.11.rc5.d0124.g6ee1d74-1)
Gnome / also with extensions disabled / no reason found in bootlog
Not affected: Kernel 59 (5.9.16-1) - here everything normal…
Start a thread in the Support section with the output of journalctl --no-hostname --no-pager -b -1 -p3
(on a boot next to that when you see those lines). Without that, it is hard to tell anything.
I for one, see no issues (except for infamous and long-standing sd-umoun
trashlines due to Nvidia driver, but I am used to that) on any of recent kernels, including git’s 5.11-rc6. Most likely you have some hardware-specific “shenanigans”.
Old swedish… Digital Spuk. But which Witch?
I played too much with the System.
Finally I decided to install it new.
No error as described above.
Did one know, that changing the hostname in Gnome resets
/home/[user]/.config/dconf/user
to default???
linux510.12-2
The same BTF Issue as usual…
.EDIT:
Solved in linux510.12.3
Confirmed same BTF issue on boot as earlier builds of 5.10.
Today updates…
:: Starting full system upgrade…
resolving dependencies…
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: opencolorio1 and opencolorio are in conflict
opencolorio1
1.1.1-2 fixes the issue.
journalcrl:
could not read from ‘/sys/module/amd64_edac_mod/initstate’: No such device
Linux510.12-3
Solution: Reboot once with “fallback initramfs” entry in GRUB-menu.
Chromium losing Sync support in early March
2021-02-03 - Evangelos Foutras
Google has announced that they are going to block everything but Chrome from accessing certain Google features (like Chrome sync) starting on March 15. This decision by Google is going to affect Arch’s
chromium
package a bit earlier, on March 2, when Chromium 89 gets released.We know for sure that data syncing will stop working (passwords, bookmarks, etc.). Other features such as geolocation or enhanced spell check might continue to function for a bit longer. Extensions integrating with Google Drive might misbehave and LibreOffice will lose access to documents stored there.
Other distros such as openSUSE and Fedora have already removed the soon-to-be-limited API keys from their Chromium 88 packages. Fedora’s advisory provides a great deal of perspective on this and I also found this Hackaday post to be quite informative.
https://archlinux.org/news/chromium-losing-sync-support-in-early-march/
i guess this means those who rely on google sync will have to resort to GChrome from AUR afterwards
which don’t have video acceleration at all, what a pity
Are you sure?
Thank you works perfect !
no Packages can be updated:
Fehler: Konnte den Vorgang nicht durchführen (In Konflikt stehende Dateien)
psmisc: /usr/share/man/de/man1/fuser.1.gz existiert im Dateisystem (gehört zu man-pages-de)
psmisc: /usr/share/man/de/man1/killall.1.gz existiert im Dateisystem (gehört zu man-pages-de)
psmisc: /usr/share/man/de/man1/peekfd.1.gz existiert im Dateisystem (gehört zu man-pages-de)
psmisc: /usr/share/man/de/man1/prtstat.1.gz existiert im Dateisystem (gehört zu man-pages-de)
psmisc: /usr/share/man/de/man1/pslog.1.gz existiert im Dateisystem (gehört zu man-pages-de)
psmisc: /usr/share/man/de/man1/pstree.1.gz existiert im Dateisystem (gehört zu man-pages-de)
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
yep, I overwrite the files and it will update
If overwritten, a possible update of either psmisc
or man-pages-de
without those will leave you with missing (german) man pages. At least until the other one will be reinstalled…
edit: This happened just now with the updated man-pages-de
package. To get those german man pages back, reinstall psmisc
afterwards. It will warn about it’s missing files on uninstallation and put them back.
