Bug is solved - 14.1 is working now
All is good here with 14.1. Thanks for the quick fix.
Confirmed. Thank you.
telegram-desktop version 2.5.6.r7 has broken notifications count in system tray icon on KDE
downgrading to 2.5.5.r1 solved the problem.
Anyone else can confirm this?
Thank you! I didn’t see it before.
Yeap, it’s not mesa, it’s Nvidia driver modules:
Here is the simple solution - it’s a wrong setting in Qt5-settings
You have to set the same symbol-theme as in your DE
Oh, in these times I always stop to read after Nvidia …
Too many problems
It seems simple, but I think I’m not competent enough.
I downloaded qt5ct and tried to use it following this instruction but I had no luck, just had to force shutdown the laptop after I created the .profile and tried log-out log-in
Maybe since plasma is a qt5 desktop already maybe I don’t need the qt5ct
Also if it might be important when I do echo $QT_QPA_PLATFORMTHEME
like said in your bug report it gives me an empty result
Which DE do you use?
It’s Plasma.
BTW, I’ve never seen notification count in the system tray icon. The count is present, however, on the icon of Telegram’s launcher in Latte:
As openminded said I’m using KDE plasma. Also in my case the tray icon is present, what is missing is only the notification count
Are we using the same DE? I always had the notification count and it worked very well. If it works in cinnamon and with latte maybe telegram it’s missing some update from plasma frameworks…
The same Telegram notification issue (absence of red badge on the icon), the same env. variable output (empty).
KDE Plasma Version: 5.20.5
KDE Frameworks Version: 5.78.0
Qt Version: 5.15.2
Kernel Version: 5.11.0-2-MANJARO
OS Type: 64-bit
$ pacman -Qi telegram-desktop
Version : 2.5.6.r8.gefde011f1-1
EDIT2:
That’s how telegram GUI executes from TUI.
$ telegram-desktop
(process:7040): Telegram-WARNING **: 22:29:52.286: GTK integration was disabled on build or in runtime. This will lead to clipboard issues and a lack of some features (like Auto-Night Mode or system window controls layout).
(process:7040): Telegram-WARNING **: 22:29:52.288: Application was built without embedded fonts, this may lead to font issues.
[ALSOFT] (EE) Failed to set real-time priority for thread: Operation not permitted (1)
error: : cannot open
and GUI starts.
closing the app adds this line:
QCoreApplication::postEvent: Unexpected null receiver
reboot after update to
$ pacman -Qi linux511
Version : 5.11.rc5.d0124.g6ee1d74-1
leads to lost external (USB) audio DAC as output device: now no ability to get audio via that DAC.
output of sudo lsusb -v -s 1:2
is just the same as was previously saved on 5.11.rc4.d0117.g19c329f-2
before the update.
lsusb
$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 152a:8750 Thesycon Systemsoftware & Consulting GmbH D50s
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x152a Thesycon Systemsoftware & Consulting GmbH
idProduct 0x8750
bcdDevice 1.03
iManufacturer 1 Topping
iProduct 3 D50s
iSerial 0
bNumConfigurations 2
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x011c
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 1 Audio
bFunctionSubClass 0
bFunctionProtocol 32
iFunction 0
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 32
iInterface 3 D50s
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 2.00
bCategory 8
wTotalLength 0x0048
bmControls 0x00
bLength 8
bDescriptorType 36
bDescriptorSubtype 10 (CLOCK_SOURCE)
bClockID 41
bmAttributes 3 Internal programmable clock
bmControls 0x07
Clock Frequency Control (read/write)
Clock Validity Control (read-only)
bAssocTerminal 0
iClockSource 9 Topping Internal Clock
bLength 8
bDescriptorType 36
bDescriptorSubtype 11 (CLOCK_SELECTOR)
bClockID 40
bNrInPins 1
baCSourceID(0) 41
bmControls 0x03
Clock Selector Control (read/write)
iClockSelector 8 Topping Clock Selector
bLength 17
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 2
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bCSourceID 40
bNrChannels 2
bmChannelConfig 0x00000000
iChannelNames 11 Analogue 1
bmControls 0x0000
iTerminal 6 D50s
bLength 18
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 10
bSourceID 2
bmaControls(0) 0x0000000f
Mute Control (read/write)
Volume Control (read/write)
bmaControls(1) 0x00000000
bmaControls(2) 0x00000000
iFeature 0
bLength 12
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 20
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 4 D50s
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 4 D50s
AudioStreaming Interface Descriptor:
bLength 16
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 2
bmControls 0x00
bFormatType 1
bmFormats 0x00000001
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bSubslotSize 4
bBitResolution 32
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0308 1x 776 bytes
bInterval 1
AudioStreaming Endpoint Descriptor:
bLength 8
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 2 Decoded PCM samples
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 17
Synch Type None
Usage Type Feedback
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 4 D50s
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 4 D50s
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
bmFormats 0x80000000
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 254 Application Specific Interface
bInterfaceSubClass 1 Device Firmware Update
bInterfaceProtocol 1
iInterface 10 Topping DFU
Device Firmware Upgrade Interface Descriptor:
bLength 9
bDescriptorType 33
bmAttributes 7
Will Not Detach
Manifestation Tolerant
Upload Supported
Download Supported
wDetachTimeout 250 milliseconds
wTransferSize 64 bytes
bcdDFUVersion 1.10
bLength 9
bDescriptorType 2
wTotalLength 0x011c
bNumInterfaces 3
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionSubClass 0
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
iInterface 3 D50s
bLength 9
bDescriptorType 36
bcdADC 2.00
bCategory 8
wTotalLength 0x0048
bmControls 0x00
bLength 8
bDescriptorType 36
bClockID 41
bmControls 0x07
bAssocTerminal 0
bLength 8
bDescriptorType 36
bClockID 40
bNrInPins 1
baCSourceID(0) 41
bmControls 0x03
bLength 17
bDescriptorType 36
bTerminalID 2
bAssocTerminal 0
bCSourceID 40
bNrChannels 2
bmControls 0x0000
iTerminal 6 D50s
bLength 18
bDescriptorType 36
bUnitID 10
bSourceID 2
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 20
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
iInterface 4 D50s
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 4 D50s
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 4 D50s
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 4 D50s
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0008
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
bLength 9
bDescriptorType 33
bmAttributes 7
Will Not Detach
Upload Supported
Download Supported
bcdDFUVersion 1.10
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 2
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
Shutdown of the DAC device during PC is up, re-plug USB cable is not fixing the problem.
As lsusb
output of the device are exactly the same as was during “rc4-2”, it should be little problem to fix. Investigating…
EDIT:
$ journalctl -b -p3 --no-hostname
Jan 25 20:00:19 pulseaudio[912]: Failed to find a working profile.
Jan 25 20:00:19 pulseaudio[912]: Failed to load module "module-alsa-card" (argument: "device_id="0" name="usb-Topping_D50s-00" card_name="alsa_card.usb-Topping_D50s-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
EDIT2:
$ sudo modprobe module-alsa-card
modprobe: FATAL: Module module-alsa-card not found in directory /lib/modules/5.11.0-1-MANJARO
@nightmare-2021, does it should be?
EDIT3:
Interesting thing: currently I have no output device and …
Remember the older “3 clicks problem while PC boots up” [Unstable Update] 2020-12-22 - ICU, Firefox, Removal of Qt4 - #79 by alven problem, which starts on every 5.11-rcX build at least from “rc2”? Current “rc5-1” wihout alsa module has the same issue as all previous 5.11-rcX, so by that lack now we know that the source of that “3 clicks” is not the currently absent module.
After I re-plug the DAC into USB of PC I hear the same clicks but only 2 and display shows different types of input signal DSD/PCM.
Probably somehow an initialization of the Topping D50s DAC became audible now. It is brand new behaviour of highly audible initialization which was inaudible on all 5.X kernel family before 5.11 and starts at least from 5.11-rc2 (5.11-rc1 was not tested by me).
EDIT5:
Meantime the 5.10.10-1
was installed and PC was rebooted into it.
No audible clicks: there are 1-2 DSD/PCM change shown on DAC’s display but it was with delay of 1.5-2 between switches. May be fast switches by somewhat inside of linux511
makes the switches highly audible with clicks.
$ uname -r
5.10.10-1-MANJARO
the same:
modprobe: FATAL: Module module-alsa-card not found in directory /lib/modules/5.10.10-1-MANJARO
journalctl
has no audio-related issues. Sound device is present and working.
lsmod
Module Size Used by
hid_logitech_hidpp 49152 0
mousedev 24576 0
joydev 28672 0
hid_logitech_dj 28672 0
usbhid 65536 1 hid_logitech_dj
snd_hda_codec_hdmi 73728 1
snd_hda_codec_realtek 143360 1
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek
snd_sof_pci 24576 0
intel_rapl_msr 20480 0
snd_sof_intel_byt 20480 1 snd_sof_pci
snd_sof_intel_ipc 20480 1 snd_sof_intel_byt
intel_rapl_common 28672 1 intel_rapl_msr
snd_sof_intel_hda_common 98304 1 snd_sof_pci
snd_soc_hdac_hda 24576 1 snd_sof_intel_hda_common
snd_sof_xtensa_dsp 16384 2 snd_sof_intel_hda_common,snd_sof_intel_byt
snd_sof_intel_hda 20480 1 snd_sof_intel_hda_common
x86_pkg_temp_thermal 20480 0
snd_sof 139264 4 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_intel_byt,snd_sof_intel_ipc
intel_powerclamp 20480 0
coretemp 20480 0
ledtrig_audio 16384 2 snd_hda_codec_generic,snd_sof
kvm_intel 327680 0
snd_soc_skl 180224 0
snd_soc_sst_ipc 20480 1 snd_soc_skl
snd_soc_sst_dsp 36864 1 snd_soc_skl
snd_hda_ext_core 36864 4 snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda
snd_soc_acpi_intel_match 45056 3 snd_sof_pci,snd_sof_intel_hda_common,snd_soc_skl
snd_soc_acpi 16384 4 snd_soc_acpi_intel_match,snd_sof_intel_hda_common,snd_sof_intel_byt,snd_soc_skl
snd_hda_intel 57344 2
snd_intel_dspcfg 24576 4 snd_hda_intel,snd_sof_pci,snd_sof_intel_hda_common,snd_soc_skl
kvm 933888 1 kvm_intel
soundwire_intel 45056 2 snd_sof_intel_hda_common,snd_intel_dspcfg
soundwire_generic_allocation 16384 1 soundwire_intel
soundwire_cadence 36864 1 soundwire_intel
snd_hda_codec 172032 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda
irqbypass 16384 1 kvm
snd_hda_core 106496 10 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda
crct10dif_pclmul 16384 1
crc32_pclmul 16384 0
squashfs 73728 0
i915 2711552 42
snd_usb_audio 315392 1
ghash_clmulni_intel 16384 0
rfkill 28672 3
soundwire_bus 90112 3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
loop 36864 0
iTCO_wdt 16384 0
intel_pmc_bxt 16384 1 iTCO_wdt
snd_usbmidi_lib 40960 1 snd_usb_audio
mei_hdcp 24576 0
iTCO_vendor_support 16384 1 iTCO_wdt
ee1004 20480 0
snd_soc_core 323584 5 soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl
snd_hwdep 16384 2 snd_usb_audio,snd_hda_codec
snd_rawmidi 45056 1 snd_usbmidi_lib
snd_seq_device 16384 1 snd_rawmidi
aesni_intel 372736 0
mc 61440 1 snd_usb_audio
crypto_simd 16384 1 aesni_intel
cryptd 24576 2 crypto_simd,ghash_clmulni_intel
wmi_bmof 16384 0
intel_wmi_thunderbolt 20480 0
snd_compress 32768 1 snd_soc_core
glue_helper 16384 1 aesni_intel
rapl 16384 0
vfat 24576 1
ac97_bus 16384 1 snd_soc_core
intel_cstate 20480 0
snd_pcm_dmaengine 16384 1 snd_soc_core
i2c_algo_bit 16384 1 i915
fat 86016 1 vfat
snd_pcm 147456 12 snd_hda_codec_hdmi,snd_hda_intel,snd_usb_audio,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_compress,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
intel_uncore 172032 0
drm_kms_helper 274432 1 i915
snd_timer 45056 1 snd_pcm
i2c_i801 36864 0
pcspkr 16384 0
e1000e 299008 0
snd 114688 20 snd_hda_codec_generic,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm,snd_rawmidi
mei_me 45056 1
i2c_smbus 20480 1 i2c_i801
soundcore 16384 1 snd
mei 139264 3 mei_hdcp,mei_me
cec 69632 2 drm_kms_helper,i915
intel_gtt 24576 1 i915
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
intel_pch_thermal 16384 0
fb_sys_fops 16384 1 drm_kms_helper
wmi 36864 2 intel_wmi_thunderbolt,wmi_bmof
tpm_crb 20480 0
tpm_tis 16384 0
video 53248 1 i915
tpm_tis_core 32768 1 tpm_tis
tpm 73728 3 tpm_tis,tpm_crb,tpm_tis_core
rng_core 16384 1 tpm
mac_hid 16384 0
acpi_tad 20480 0
acpi_pad 24576 0
drm 569344 13 drm_kms_helper,i915
uinput 20480 0
sg 40960 0
fuse 163840 5
crypto_user 20480 0
agpgart 53248 2 intel_gtt,drm
ip_tables 32768 0
x_tables 53248 1 ip_tables
ext4 933888 1
crc32c_generic 16384 0
crc16 16384 1 ext4
mbcache 16384 1 ext4
jbd2 151552 1 ext4
rtsx_pci_sdmmc 32768 0
mmc_core 192512 1 rtsx_pci_sdmmc
crc32c_intel 24576 2
rtsx_pci 106496 1 rtsx_pci_sdmmc
xhci_pci 20480 0
Rebooting into linux511 to check lsmod there and to compare them…
EDIT6:
again 3 clicks on the 5.11 family.
the same 2 lines of errors in journalctl
as was on “5.11-rc5-1” before.
again no the USB DAC device as audio output.
lsmod
Module Size Used by
mousedev 24576 0
joydev 28672 0
snd_sof_pci 24576 0
snd_sof_intel_hda_common 102400 1 snd_sof_pci
snd_sof 147456 4 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_intel_byt,snd_sof_intel_ipc
snd_soc_sst_dsp 40960 1 snd_soc_skl
snd_soc_acpi_intel_match 49152 3 snd_sof_pci,snd_sof_intel_hda_common,snd_soc_skl
coretemp 20480 0
kvm_intel 327680 0
squashfs 73728 0
snd_usb_audio 327680 0
kvm 974848 1 kvm_intel
i915 2756608 33
iTCO_wdt 16384 0
snd_soc_core 339968 5 soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl
ee1004 20480 0
wmi_bmof 16384 0
mei_hdcp 24576 0
mc 65536 1 snd_usb_audio
loop 36864 0
rfkill 28672 3
snd_pcm 147456 13 snd_hda_codec_hdmi,snd_hda_intel,snd_usb_audio,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_sof_intel_ipc,snd_compress,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
rapl 16384 0
vfat 24576 1
snd 114688 18 snd_hda_codec_generic,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm,snd_rawmidi
fat 86016 1 vfat
drm_kms_helper 282624 1 i915
i2c_i801 36864 0
pcspkr 16384 0
e1000e 303104 0
mei_me 45056 1
cec 73728 2 drm_kms_helper,i915
tpm_crb 20480 0
tpm_tis 16384 0
tpm 77824 3 tpm_tis,tpm_crb,tpm_tis_core
video 53248 1 i915
mac_hid 16384 0
acpi_pad 24576 0
acpi_tad 20480 0
uinput 20480 0
drm 581632 13 drm_kms_helper,i915
sg 40960 0
crypto_user 20480 0
fuse 159744 5
agpgart 45056 2 intel_gtt,drm
ip_tables 32768 0
ext4 937984 1
crc16 16384 1 ext4
jbd2 151552 1 ext4
mmc_core 196608 1 rtsx_pci_sdmmc
xhci_pci 20480 0
Try a different theme for the DE - see if the icon appears again.
I tried a couple, I’m using Breeze by default but I tried with Breath2 and Oxygen; and also Default for GTK apps, but it doesn’t change.
I noticed that in the section “notifications” in telegram there isn’t anymore the option “use native notifications”
I downgraded to the older version, since it works correctly. This is the output of telegram-desktop-2.5.5.r1 (the latest working version) when I launch from terminal
telegram-desktop (process:6883): Telegram-WARNING **: 16:45:32.764: Unfortunately, GTK integration conflicts with qgtk2 platformtheme and style. Therefore, QT_QPA_PLATFORMTHEME and QT_STYLE_OVERRIDE will be unset. Telegram-Message: 16:45:32.765: This can be ignored by setting TDESKTOP_I_KNOW_ABOUT_GTK_INCOMPATIBILITY environment variable to any value, however, if qgtk2 theme or style is used, this will lead to a crash. Telegram-Message: 16:45:32.765: GTK integration can be disabled by setting TDESKTOP_DISABLE_GTK_INTEGRATION to any v alue. Keep in mind that this will lead to clipboard issues and tdesktop will be unable to get settings from GTK (suc h as decoration layout, dark mode & more). (process:6883): Telegram-WARNING **: 16:45:32.765: Application was built without embedded fonts, this may lead to fo nt issues. [ALSOFT] (EE) Failed to set real-time priority for thread: Operation not permitted (1)
I updated PulseEffects to 5.0 but it didn’t work with the meta package manjaro-pulse, so I installed PulseEffects legacy 4.8.4 from AUR.
