Hello community,
Another unstable branch update with some usual updates for you. Remember that we expect possible breakage of your system with this update!
Our web-service Branch-Compare got improved. Works also now on Mobile!.. #stayhome, #staysafe, #stayhealthy
- Firefox got updated to 84.0.1
- Mass-Rebuild against ICU
- Qt4 got removed
- Other regular upstream updates
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev, which we build on a regular basis against kde-git master packages. Also check out our latest Manjaro Nibia 20.2 release! KDE, XFCE and Gnome
Our current supported kernels
- linux44 4.4.248
- linux49 4.9.248
- linux414 4.14.212
- linux419 4.19.163
- linux54 5.4.85
- linux59 5.9.16 [EOL]
- linux510 5.10.2
- linux54-rt 5.4.82_rt45
- linux59-rt 5.9.1_rt19
Packages Changes (Mon Dec 21 23:55:35 CET 2020)
:: Different overlay package(s) in repository community x86_64
PACKAGE testing unstable
qt4 4.8.7-29.1 -
spread-sheet-widget 0.3-2.0 -
:: Different sync package(s) in repository community x86_64
0ad a23.1-13 a23.1-14
aegisub 3.2.2-43 3.2.2-44
bazel 3.7.1-1 3.7.2-1
bluegriffon 3.1-11 3.1-12
bluegriffon-i18n-cs 3.1-11 3.1-12
bluegriffon-i18n-de 3.1-11 3.1-12
bluegriffon-i18n-es-es 3.1-11 3.1-12
bluegriffon-i18n-fi 3.1-11 3.1-12
bluegriffon-i18n-fr 3.1-11 3.1-12
bluegriffon-i18n-gl 3.1-11 3.1-12
bluegriffon-i18n-he 3.1-11 3.1-12
bluegriffon-i18n-hu 3.1-11 3.1-12
bluegriffon-i18n-it 3.1-11 3.1-12
bluegriffon-i18n-ja 3.1-11 3.1-12
bluegriffon-i18n-ko 3.1-11 3.1-12
bluegriffon-i18n-nl 3.1-11 3.1-12
bluegriffon-i18n-pl 3.1-11 3.1-12
bluegriffon-i18n-ru 3.1-11 3.1-12
bluegriffon-i18n-sl 3.1-11 3.1-12
bluegriffon-i18n-sr 3.1-11 3.1-12
bluegriffon-i18n-sv-se 3.1-11 3.1-12
bluegriffon-i18n-zh-cn 3.1-11 3.1-12
bluegriffon-i18n-zh-tw 3.1-11 3.1-12
broot 1.0.7-1 1.0.9-1
calibre 5.7.2-1 5.7.2-2
couchdb 3.1.1-1 3.1.1-2
darktable 2:3.2.1-2 2:3.2.1-3
dee 1.2.7-9 1.2.7-10
deepin-control-center 5.3.0.55-1 5.3.0.56-1
deepin-dock 5.3.0.38-1 5.3.0.39-1
deepin-music 6.0.1.91-1 6.0.1.91-2
deepin-system-monitor 5.8.0.3-2 5.8.0.3-3
dino 0.2.0-1 0.2.0-2
dovecot 2.3.11.3-2 2.3.11.3-3
dwdiff 2.1.3-1 2.1.3-2
electron 11.1.0-2 11.1.1-1
electron10 10.2.0-2 10.2.0-3
electron6 6.1.12-2 6.1.12-3
electron9 9.4.0-2 9.4.0-3
elinks 0.13-22 0.13.5-1
flickcurl 1.26-9 1.26-10
fwbuilder 5.3.7-7 5.3.7-8
gambas3-devel 3.15.2-4 3.15.2-5
gambas3-gb-args 3.15.2-4 3.15.2-5
gambas3-gb-cairo 3.15.2-4 3.15.2-5
gambas3-gb-chart 3.15.2-4 3.15.2-5
gambas3-gb-clipper 3.15.2-4 3.15.2-5
gambas3-gb-complex 3.15.2-4 3.15.2-5
gambas3-gb-compress 3.15.2-4 3.15.2-5
gambas3-gb-crypt 3.15.2-4 3.15.2-5
gambas3-gb-data 3.15.2-4 3.15.2-5
gambas3-gb-db 3.15.2-4 3.15.2-5
gambas3-gb-db-form 3.15.2-4 3.15.2-5
gambas3-gb-db-mysql 3.15.2-4 3.15.2-5
gambas3-gb-db-odbc 3.15.2-4 3.15.2-5
gambas3-gb-db-postgresql 3.15.2-4 3.15.2-5
gambas3-gb-db-sqlite3 3.15.2-4 3.15.2-5
gambas3-gb-dbus 3.15.2-4 3.15.2-5
gambas3-gb-desktop 3.15.2-4 3.15.2-5
gambas3-gb-desktop-gnome 3.15.2-4 3.15.2-5
gambas3-gb-desktop-x11 3.15.2-4 3.15.2-5
gambas3-gb-eval-highlight 3.15.2-4 3.15.2-5
gambas3-gb-form 3.15.2-4 3.15.2-5
gambas3-gb-form-dialog 3.15.2-4 3.15.2-5
gambas3-gb-form-editor 3.15.2-4 3.15.2-5
gambas3-gb-form-mdi 3.15.2-4 3.15.2-5
gambas3-gb-form-stock 3.15.2-4 3.15.2-5
gambas3-gb-form-terminal 3.15.2-4 3.15.2-5
gambas3-gb-gmp 3.15.2-4 3.15.2-5
gambas3-gb-gsl 3.15.2-4 3.15.2-5
gambas3-gb-gtk3 3.15.2-4 3.15.2-5
gambas3-gb-httpd 3.15.2-4 3.15.2-5
gambas3-gb-image 3.15.2-4 3.15.2-5
gambas3-gb-image-effect 3.15.2-4 3.15.2-5
gambas3-gb-image-imlib 3.15.2-4 3.15.2-5
gambas3-gb-image-io 3.15.2-4 3.15.2-5
gambas3-gb-inotify 3.15.2-4 3.15.2-5
gambas3-gb-libxml 3.15.2-4 3.15.2-5
gambas3-gb-logging 3.15.2-4 3.15.2-5
gambas3-gb-map 3.15.2-4 3.15.2-5
gambas3-gb-markdown 3.15.2-4 3.15.2-5
gambas3-gb-media 3.15.2-4 3.15.2-5
gambas3-gb-media-form 3.15.2-4 3.15.2-5
gambas3-gb-memcached 3.15.2-4 3.15.2-5
gambas3-gb-mime 3.15.2-4 3.15.2-5
gambas3-gb-mysql 3.15.2-4 3.15.2-5
gambas3-gb-ncurses 3.15.2-4 3.15.2-5
gambas3-gb-net 3.15.2-4 3.15.2-5
gambas3-gb-net-curl 3.15.2-4 3.15.2-5
gambas3-gb-net-pop3 3.15.2-4 3.15.2-5
gambas3-gb-net-smtp 3.15.2-4 3.15.2-5
gambas3-gb-openal 3.15.2-4 3.15.2-5
gambas3-gb-opengl 3.15.2-4 3.15.2-5
gambas3-gb-opengl-glsl 3.15.2-4 3.15.2-5
gambas3-gb-opengl-glu 3.15.2-4 3.15.2-5
gambas3-gb-opengl-sge 3.15.2-4 3.15.2-5
gambas3-gb-openssl 3.15.2-4 3.15.2-5
gambas3-gb-option 3.15.2-4 3.15.2-5
gambas3-gb-pcre 3.15.2-4 3.15.2-5
gambas3-gb-pdf 3.15.2-4 3.15.2-5
gambas3-gb-poppler 3.15.2-4 3.15.2-5
gambas3-gb-qt5 3.15.2-4 3.15.2-5
gambas3-gb-qt5-opengl 3.15.2-4 3.15.2-5
gambas3-gb-qt5-webkit 3.15.2-4 3.15.2-5
gambas3-gb-report 3.15.2-4 3.15.2-5
gambas3-gb-scanner 3.15.2-4 3.15.2-5
gambas3-gb-sdl 3.15.2-4 3.15.2-5
gambas3-gb-sdl-sound 3.15.2-4 3.15.2-5
gambas3-gb-sdl2 3.15.2-4 3.15.2-5
gambas3-gb-sdl2-audio 3.15.2-4 3.15.2-5
gambas3-gb-settings 3.15.2-4 3.15.2-5
gambas3-gb-signal 3.15.2-4 3.15.2-5
gambas3-gb-term 3.15.2-4 3.15.2-5
gambas3-gb-util 3.15.2-4 3.15.2-5
gambas3-gb-util-web 3.15.2-4 3.15.2-5
gambas3-gb-v4l 3.15.2-4 3.15.2-5
gambas3-gb-vb 3.15.2-4 3.15.2-5
gambas3-gb-web 3.15.2-4 3.15.2-5
gambas3-gb-web-feed 3.15.2-4 3.15.2-5
gambas3-gb-web-form 3.15.2-4 3.15.2-5
gambas3-gb-web-gui 3.15.2-4 3.15.2-5
gambas3-gb-xml 3.15.2-4 3.15.2-5
gambas3-gb-xml-html 3.15.2-4 3.15.2-5
gambas3-gb-xml-rpc 3.15.2-4 3.15.2-5
gambas3-gb-xml-xslt 3.15.2-4 3.15.2-5
gambas3-ide 3.15.2-4 3.15.2-5
gambas3-runtime 3.15.2-4 3.15.2-5
gambas3-script 3.15.2-4 3.15.2-5
gdal 3.0.4-16 3.0.4-17
gitlab 13.6.3-1 13.6.3-2
gitlab-gitaly 13.6.1-1 13.6.1-2
gitlab-runner 13.6.0-1 13.7.0-1
gnucash 4.2-4 4.2-5
gnustep-base 1.27.0-1 1.27.0-2
haskell-citeproc 0.2-4 0.2-5
haskell-hakyll 4.13.4.1-74 4.13.4.1-75
haskell-text-icu 0.7.0.1-34 0.7.0.1-35
imv 4.2.0-1 4.2.0-2
jami-daemon 20201023-1 20201216-1
jami-gnome 20201019-1 20201217-1
kbibtex 1:0.9.2-2 1:0.9.2-3
kiwix-lib 9.4.1-1 9.4.1-2
kvantum-theme-materia 20201214-1 20201222-1
ledger 3.2.1-4 3.2.1-5
libavif 0.8.2-1 0.8.3-1
libjamiclient 20201021-1 20201217-1
libmodsecurity 1:3.0.4-3 1:3.0.4-4
libperconaserverclient 8.0.22_13-1 8.0.22_13-2
libzim 6.3.0-1 6.3.0-2
maim 5.6.3-2 5.6.3-3
mapnik 3.0.23-4 3.0.23-5
materia-kde 20201214-1 20201222-1
mongo-c-driver 1.17.3-1 1.17.3-2
ncmpcpp 0.9-1 0.9-2
newsboat 2.21-1 2.21-2
nodejs 15.4.0-1 15.4.0-2
nodejs-lts-dubnium 10.23.0-1 10.23.0-2
nodejs-lts-erbium 12.20.0-1 12.20.0-2
nodejs-lts-fermium 14.15.3-1 14.15.3-2
oath-toolkit 2.6.4-1 2.6.4-2
opendht 1:2.1.6-3 1:2.1.9.5-1
openrct2 0.3.2-2 0.3.2-3
openttd 1.10.3-1 1.10.3-2
pandoc 2.11.2-6 2.11.2-7
pandoc-citeproc 0.17.0.2-112 0.17.0.2-113
pandoc-crossref 0.3.8.2-50 0.3.8.2-51
percona-server 8.0.22_13-1 8.0.22_13-2
percona-server-clients 8.0.22_13-1 8.0.22_13-2
php-mongodb 1.9.0-1 1.9.0-2
poedit 1:2.4.1-3 1:2.4.1-4
python-gdal 3.0.4-16 3.0.4-17
python-pyicu 2.6-2 2.6-3
python-sword 1.8.1-10 1.8.1-11
python-tensorflow 2.4.0-1 2.4.0-2
python-tensorflow-cuda 2.4.0-1 2.4.0-2
python-tensorflow-opt 2.4.0-1 2.4.0-2
python-tensorflow-opt-cuda 2.4.0-1 2.4.0-2
rspamd 2.6-1 2.6-2
scribus 1.5.6.1-3 1.5.6.1-4
seamonkey 2.53.5-1 2.53.5-2
skk-jisyo 20201213-1 20201220-1
slop 7.5-3 7.5-4
tarantool 2.7.0-1 2.7.0-2
tesseract 4.1.1-3 4.1.1-4
unarchiver 1.10.7-1 1.10.7-2
widelands 21-3 21-4
xalan-c 1:1.12-1 1:1.12-2
yaz 5.30.3-1 5.30.3-2
youtube-dl 2020.12.14-1 2020.12.22-1
zcash 4.1.1-3 4.2.0-1
znc 1.7.5-9 1.7.5-10
libyuv - r2212+dfaf7534-1
:: Different sync package(s) in repository core x86_64
icu 67.1-1 68.2-1
xfsprogs 5.8.0-1 5.8.0-2
:: Different overlay package(s) in repository extra x86_64
boxit 2.1.3-6 2.1.3-7
boxit-32 2.1.3-2 -
boxit-32-server 2.1.3-2 -
boxit-arm 2.1.3-4 2.1.3-5
boxit-arm-server 2.1.3-4 2.1.3-5
boxit-server 2.1.3-6 2.1.3-7
manjaro-settings-manager 0.5.6-10 0.5.6-11
manjaro-settings-manager-kcm 0.5.6-10 0.5.6-11
manjaro-settings-manager-knotifier 0.5.6-10 0.5.6-11
manjaro-settings-manager-notifier 0.5.6-10 0.5.6-11
qt5-base 5.15.2-1 5.15.2-2
qt5-xcb-private-headers 5.15.2-1 5.15.2-2
:: Different sync package(s) in repository extra x86_64
389-ds-base 1.4.4.4-4 1.4.4.4-5
beanshell 2.0b6-3 2.1.0-1
boost 1.75.0-1 1.75.0-2
boost-libs 1.75.0-1 1.75.0-2
botan 2.17.2-2 2.17.3-1
brltty 6.1-4 6.1-5
chromium 87.0.4280.88-2 87.0.4280.88-3
enchant 2.2.12-1 2.2.13-2
evolution-data-server 3.38.2-1 3.38.2-2
firefox 84.0-1 84.0.1-1
firefox-i18n-ach 84.0-1 84.0.1-1
firefox-i18n-af 84.0-1 84.0.1-1
firefox-i18n-an 84.0-1 84.0.1-1
firefox-i18n-ar 84.0-1 84.0.1-1
firefox-i18n-ast 84.0-1 84.0.1-1
firefox-i18n-az 84.0-1 84.0.1-1
firefox-i18n-be 84.0-1 84.0.1-1
firefox-i18n-bg 84.0-1 84.0.1-1
firefox-i18n-bn 84.0-1 84.0.1-1
firefox-i18n-br 84.0-1 84.0.1-1
firefox-i18n-bs 84.0-1 84.0.1-1
firefox-i18n-ca 84.0-1 84.0.1-1
firefox-i18n-ca-valencia 84.0-1 84.0.1-1
firefox-i18n-cak 84.0-1 84.0.1-1
firefox-i18n-cs 84.0-1 84.0.1-1
firefox-i18n-cy 84.0-1 84.0.1-1
firefox-i18n-da 84.0-1 84.0.1-1
firefox-i18n-de 84.0-1 84.0.1-1
firefox-i18n-dsb 84.0-1 84.0.1-1
firefox-i18n-el 84.0-1 84.0.1-1
firefox-i18n-en-ca 84.0-1 84.0.1-1
firefox-i18n-en-gb 84.0-1 84.0.1-1
firefox-i18n-en-us 84.0-1 84.0.1-1
firefox-i18n-eo 84.0-1 84.0.1-1
firefox-i18n-es-ar 84.0-1 84.0.1-1
firefox-i18n-es-cl 84.0-1 84.0.1-1
firefox-i18n-es-es 84.0-1 84.0.1-1
firefox-i18n-es-mx 84.0-1 84.0.1-1
firefox-i18n-et 84.0-1 84.0.1-1
firefox-i18n-eu 84.0-1 84.0.1-1
firefox-i18n-fa 84.0-1 84.0.1-1
firefox-i18n-ff 84.0-1 84.0.1-1
firefox-i18n-fi 84.0-1 84.0.1-1
firefox-i18n-fr 84.0-1 84.0.1-1
firefox-i18n-fy-nl 84.0-1 84.0.1-1
firefox-i18n-ga-ie 84.0-1 84.0.1-1
firefox-i18n-gd 84.0-1 84.0.1-1
firefox-i18n-gl 84.0-1 84.0.1-1
firefox-i18n-gn 84.0-1 84.0.1-1
firefox-i18n-gu-in 84.0-1 84.0.1-1
firefox-i18n-he 84.0-1 84.0.1-1
firefox-i18n-hi-in 84.0-1 84.0.1-1
firefox-i18n-hr 84.0-1 84.0.1-1
firefox-i18n-hsb 84.0-1 84.0.1-1
firefox-i18n-hu 84.0-1 84.0.1-1
firefox-i18n-hy-am 84.0-1 84.0.1-1
firefox-i18n-ia 84.0-1 84.0.1-1
firefox-i18n-id 84.0-1 84.0.1-1
firefox-i18n-is 84.0-1 84.0.1-1
firefox-i18n-it 84.0-1 84.0.1-1
firefox-i18n-ja 84.0-1 84.0.1-1
firefox-i18n-ka 84.0-1 84.0.1-1
firefox-i18n-kab 84.0-1 84.0.1-1
firefox-i18n-kk 84.0-1 84.0.1-1
firefox-i18n-km 84.0-1 84.0.1-1
firefox-i18n-kn 84.0-1 84.0.1-1
firefox-i18n-ko 84.0-1 84.0.1-1
firefox-i18n-lij 84.0-1 84.0.1-1
firefox-i18n-lt 84.0-1 84.0.1-1
firefox-i18n-lv 84.0-1 84.0.1-1
firefox-i18n-mk 84.0-1 84.0.1-1
firefox-i18n-mr 84.0-1 84.0.1-1
firefox-i18n-ms 84.0-1 84.0.1-1
firefox-i18n-my 84.0-1 84.0.1-1
firefox-i18n-nb-no 84.0-1 84.0.1-1
firefox-i18n-ne-np 84.0-1 84.0.1-1
firefox-i18n-nl 84.0-1 84.0.1-1
firefox-i18n-nn-no 84.0-1 84.0.1-1
firefox-i18n-oc 84.0-1 84.0.1-1
firefox-i18n-pa-in 84.0-1 84.0.1-1
firefox-i18n-pl 84.0-1 84.0.1-1
firefox-i18n-pt-br 84.0-1 84.0.1-1
firefox-i18n-pt-pt 84.0-1 84.0.1-1
firefox-i18n-rm 84.0-1 84.0.1-1
firefox-i18n-ro 84.0-1 84.0.1-1
firefox-i18n-ru 84.0-1 84.0.1-1
firefox-i18n-si 84.0-1 84.0.1-1
firefox-i18n-sk 84.0-1 84.0.1-1
firefox-i18n-sl 84.0-1 84.0.1-1
firefox-i18n-son 84.0-1 84.0.1-1
firefox-i18n-sq 84.0-1 84.0.1-1
firefox-i18n-sr 84.0-1 84.0.1-1
firefox-i18n-sv-se 84.0-1 84.0.1-1
firefox-i18n-ta 84.0-1 84.0.1-1
firefox-i18n-te 84.0-1 84.0.1-1
firefox-i18n-th 84.0-1 84.0.1-1
firefox-i18n-tl 84.0-1 84.0.1-1
firefox-i18n-tr 84.0-1 84.0.1-1
firefox-i18n-trs 84.0-1 84.0.1-1
firefox-i18n-uk 84.0-1 84.0.1-1
firefox-i18n-ur 84.0-1 84.0.1-1
firefox-i18n-uz 84.0-1 84.0.1-1
firefox-i18n-vi 84.0-1 84.0.1-1
firefox-i18n-xh 84.0-1 84.0.1-1
firefox-i18n-zh-cn 84.0-1 84.0.1-1
firefox-i18n-zh-tw 84.0-1 84.0.1-1
harfbuzz 2.7.2-1 2.7.2-3
harfbuzz-icu 2.7.2-1 2.7.2-3
htop 3.0.3-1 3.0.4-1
kdb 3.2.0-5 3.2.0-6
libcdr 0.1.6-2 0.1.6-3
libe-book 0.1.3-7 0.1.3-8
libical 3.0.8-2 3.0.8-3
libmspub 0.1.4-8 0.1.4-9
libphonenumber 8.12.14-2 8.12.14-3
libqalculate 3.15.0-1 3.15.0-2
libqxp 0.0.2-4 0.0.2-5
libreoffice-fresh 7.0.4-1 7.0.4-2
libreoffice-fresh-sdk 7.0.4-1 7.0.4-2
libreoffice-still 6.4.7-7 6.4.7-8
libreoffice-still-sdk 6.4.7-7 6.4.7-8
libsynctex 2020.54586-7 2020.54586-8
libvisio 0.1.7-3 0.1.7-4
libxml2 2.9.10-7 2.9.10-8
libzmf 0.0.2-8 0.0.2-9
m17n-lib 1.8.0-7 1.8.0-8
mpd 0.22.3-1 0.22.3-2
nuspell 4.2.0-1 4.2.0-2
php 7.4.13-1 7.4.13-2
php-apache 7.4.13-1 7.4.13-2
php-cgi 7.4.13-1 7.4.13-2
php-dblib 7.4.13-1 7.4.13-2
php-embed 7.4.13-1 7.4.13-2
php-enchant 7.4.13-1 7.4.13-2
php-fpm 7.4.13-1 7.4.13-2
php-gd 7.4.13-1 7.4.13-2
php-imap 7.4.13-1 7.4.13-2
php-intl 7.4.13-1 7.4.13-2
php-odbc 7.4.13-1 7.4.13-2
php-pgsql 7.4.13-1 7.4.13-2
php-phpdbg 7.4.13-1 7.4.13-2
php-pspell 7.4.13-1 7.4.13-2
php-snmp 7.4.13-1 7.4.13-2
php-sodium 7.4.13-1 7.4.13-2
php-sqlite 7.4.13-1 7.4.13-2
php-tidy 7.4.13-1 7.4.13-2
php-xsl 7.4.13-1 7.4.13-2
postfix 3.5.8-3 3.5.8-4
postgresql 13.1-2 13.1-3
postgresql-docs 13.1-2 13.1-3
postgresql-libs 13.1-2 13.1-3
postgresql-old-upgrade 12.5-1 12.5-2
qt5-location 5.15.2-1 5.15.2-2
qt5-webengine 5.15.2-2 5.15.2-3
qt5-webkit 5.212.0alpha4-8 5.212.0alpha4-9
qt6-5compat 6.0.0-1 6.0.0-2
qt6-base 6.0.0-1 6.0.0-2
r 4.0.3-1 4.0.3-2
raptor 2.0.15-14 2.0.15-15
samba 4.13.3-1 4.13.3-2
sdl2 2.0.12-3 2.0.14-1
smbclient 4.13.3-1 4.13.3-2
tepl 5.0.1-1 5.0.1-2
texlive-bin 2020.54586-7 2020.54586-8
thunderbird 78.6.0-1 78.6.0-2
thunderbird-i18n-ar 78.6.0-1 78.6.0-2
thunderbird-i18n-ast 78.6.0-1 78.6.0-2
thunderbird-i18n-be 78.6.0-1 78.6.0-2
thunderbird-i18n-bg 78.6.0-1 78.6.0-2
thunderbird-i18n-br 78.6.0-1 78.6.0-2
thunderbird-i18n-ca 78.6.0-1 78.6.0-2
thunderbird-i18n-cs 78.6.0-1 78.6.0-2
thunderbird-i18n-cy 78.6.0-1 78.6.0-2
thunderbird-i18n-da 78.6.0-1 78.6.0-2
thunderbird-i18n-de 78.6.0-1 78.6.0-2
thunderbird-i18n-dsb 78.6.0-1 78.6.0-2
thunderbird-i18n-el 78.6.0-1 78.6.0-2
thunderbird-i18n-en-gb 78.6.0-1 78.6.0-2
thunderbird-i18n-en-us 78.6.0-1 78.6.0-2
thunderbird-i18n-es-ar 78.6.0-1 78.6.0-2
thunderbird-i18n-es-es 78.6.0-1 78.6.0-2
thunderbird-i18n-et 78.6.0-1 78.6.0-2
thunderbird-i18n-eu 78.6.0-1 78.6.0-2
thunderbird-i18n-fi 78.6.0-1 78.6.0-2
thunderbird-i18n-fr 78.6.0-1 78.6.0-2
thunderbird-i18n-fy-nl 78.6.0-1 78.6.0-2
thunderbird-i18n-ga-ie 78.6.0-1 78.6.0-2
thunderbird-i18n-gd 78.6.0-1 78.6.0-2
thunderbird-i18n-gl 78.6.0-1 78.6.0-2
thunderbird-i18n-he 78.6.0-1 78.6.0-2
thunderbird-i18n-hr 78.6.0-1 78.6.0-2
thunderbird-i18n-hsb 78.6.0-1 78.6.0-2
thunderbird-i18n-hu 78.6.0-1 78.6.0-2
thunderbird-i18n-hy-am 78.6.0-1 78.6.0-2
thunderbird-i18n-id 78.6.0-1 78.6.0-2
thunderbird-i18n-is 78.6.0-1 78.6.0-2
thunderbird-i18n-it 78.6.0-1 78.6.0-2
thunderbird-i18n-ja 78.6.0-1 78.6.0-2
thunderbird-i18n-ko 78.6.0-1 78.6.0-2
thunderbird-i18n-lt 78.6.0-1 78.6.0-2
thunderbird-i18n-nb-no 78.6.0-1 78.6.0-2
thunderbird-i18n-nl 78.6.0-1 78.6.0-2
thunderbird-i18n-nn-no 78.6.0-1 78.6.0-2
thunderbird-i18n-pl 78.6.0-1 78.6.0-2
thunderbird-i18n-pt-br 78.6.0-1 78.6.0-2
thunderbird-i18n-pt-pt 78.6.0-1 78.6.0-2
thunderbird-i18n-rm 78.6.0-1 78.6.0-2
thunderbird-i18n-ro 78.6.0-1 78.6.0-2
thunderbird-i18n-ru 78.6.0-1 78.6.0-2
thunderbird-i18n-si 78.6.0-1 78.6.0-2
thunderbird-i18n-sk 78.6.0-1 78.6.0-2
thunderbird-i18n-sl 78.6.0-1 78.6.0-2
thunderbird-i18n-sq 78.6.0-1 78.6.0-2
thunderbird-i18n-sr 78.6.0-1 78.6.0-2
thunderbird-i18n-sv-se 78.6.0-1 78.6.0-2
thunderbird-i18n-tr 78.6.0-1 78.6.0-2
thunderbird-i18n-uk 78.6.0-1 78.6.0-2
thunderbird-i18n-vi 78.6.0-1 78.6.0-2
thunderbird-i18n-zh-cn 78.6.0-1 78.6.0-2
thunderbird-i18n-zh-tw 78.6.0-1 78.6.0-2
tracker 2.3.6-2 2.3.6-3
tracker-miners 2.3.5-2 2.3.5-3
tracker3 3.0.2-1 3.0.2-2
tracker3-miners 3.0.3-1 3.0.3-2
vte-common 0.62.1-1 0.62.1-2
vte3 0.62.1-1 0.62.1-2
webkit2gtk 2.30.4-1 2.30.4-2
xerces-c 3.2.3-1 3.2.3-2
:: Different overlay package(s) in repository multilib x86_64
lib32-qt4 4.8.7-13 -
lib32-qtcurve-qt4 1.9.1-1 -
:: Different sync package(s) in repository multilib x86_64
lib32-harfbuzz 2.7.2-1 2.7.2-3
lib32-harfbuzz-icu 2.7.2-1 2.7.2-3
lib32-icu 67.1-1 68.2-1
lib32-libxml2 2.9.10-2 2.9.10-3
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
