Hello,
when using Libreoffice with a dark theme and dark font the spelling correction is unreadable because it uses the text font and not the theme font. I don’t really know what to try besides changing either the font color or the system theme.
There is a bug ticket open at upstream:
https://bugs.documentfoundation.org/show_bug.cgi?id=131978
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please mark a solution like this:
