I’m trying to enable emoji support in Konsole and followed these instructions
using the Noto fonts mentioned in the post as well the Twemoji font. I can see emoji in Konsole, however, no sequences combine together: flags flags show up as their two letter country code (CA instead of the Canadian flag), and skin-tone modifiers show as the base emoji + skin colour emoji.
The above post mentions this is dependent on the font supporting these emoji, however, I’m fairly certain both Noto and Twemoji support this (as evidenced in the above post, as well as using the fonts in Kate and being able to view the emoji correctly).
This issue then has knock on effects for cursor alignment, for instance, piping to column
, and even breaks some programs like ytfzf
if any of these emoji appear in video titles.
I can see these emoji properly elsewhere (including Kate and the Emoji selector). Changing conf files in ~/.config/fontconfig/conf.d to swap between Noto and Twemoji does update the look of the emojis successfully (I also try opening a new Konsole instance after each change), but can never get the emojis to collapse to single flag/skin tone emoji. Konsole is set to UTF-8.
Is there a setting or something I’m missing to enable this? I’m not familiar with KDE development, but an old 2018 diff on Phabricator (D15758, can’t link) suggests it should be supported (and checking the Konsole github, the relevant changes still appear in the codebase).
Thanks for any help
