Unexpected Ctrl + . behavior
Hi!
As many of you will know, Ctrl + . is a shortcut to quick fix errors in VSCode, like by importing missing Modules etc.
For the last week or so this doesnt work anymore, instead pressing Ctrl + . makes an underlined e appear on screen. It can’t be removed via backspace unless I press escape first. Typing other characters makes them also appear underlined^^. Changing focus to some other window triggers even more weird behaviour, now everything I do, be it clicking somewhere, or pressing Ctrl+z pastes the previously underlined characters where I clicked or pressed ctrl+z.
This happens not only in vscode, also in other applications.
I have no idea what this function is called or why anyone would want to use it. Most importantly I dont know how to turn it off, please help ^^’
  Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: root=UUID=509cf8d1-a35f-4336-8b2d-34229ea2062d rw quiet
  udev.log_priority=3 nvidia-drm.modeset=1
  initrd=boot\initramfs-5.13-x86_64.img
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Desktop Mobo: Gigabyte model: X570 GAMING X v: x.x serial: <filter>
  UEFI: American Megatrends LLC. v: F34 date: 06/10/2021
  RAM: total: 31.3 GiB used: 3.67 GiB (11.7%)
  Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
  family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
  L2: 4 MiB bogomips: 121639
  Speed: 3610 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
  1: 3610 2: 2879 3: 2876 4: 3121 5: 3597 6: 2878 7: 2878 8: 3033 9: 2869
  10: 2880 11: 3599 12: 2877 13: 2876 14: 2878 15: 3945 16: 2911
  cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
  flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
  invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
  movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
  overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
  perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
  rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
  sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
  topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean
  vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: always-on, RSB filling
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia
  v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
  chip-ID: 10de:2484 class-ID: 0300
  Device-2: Sunplus Innovation MiraBox Video Capture type: USB
  driver: snd-usb-audio,uvcvideo bus-ID: 6-2.3:5 chip-ID: 1bcf:2c99
  class-ID: 0102
  Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: nvidia resolution: <missing: xdpyinfo>
  OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
  Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:228b
  class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Device-3: Yamaha Steinberg UR22mkII type: USB driver: snd-usb-audio
  bus-ID: 1-1.1:4 chip-ID: 0499:170f class-ID: 0103
  Device-4: Sunplus Innovation MiraBox Video Capture type: USB
  class-ID: 0102
  Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.19 running: no
  Sound Server-4: PulseAudio v: 15.0 running: no
  Sound Server-5: PipeWire v: 0.3.35 running: yes
  vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  driver: btusb v: 0.8 bus-ID: 5-1.4.1:7 chip-ID: 0a12:0001 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
  Local Storage: total: 6.37 TiB used: 2.1 TiB (33.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
  lanes: 4 type: SSD serial: <filter> rev: 1B2QGXA7 temp: 38.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDA-2T00
  size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 40RL scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1ER162
  type: HDD rpm: 7200 serial: <filter> rev: CC45 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: HDWD130 size: 2.73 TiB
  block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
  rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
  ID-1: / raw-size: 97.89 GiB size: 95.8 GiB (97.86%) used: 72.25 GiB (75.4%)
  fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  uuid: 509cf8d1-a35f-4336-8b2d-34229ea2062d
  ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
  used: 5.1 MiB (2.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
  uuid: 4A6B-A47E
  ID-3: /home raw-size: 833.37 GiB size: 819.29 GiB (98.31%)
  used: 598.71 GiB (73.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  label: N/A uuid: b19c9d93-2a04-4d8c-adc4-375f51e8bc28
  ID-4: /run/media/sebastianp/Festplatte1TB raw-size: 931.51 GiB
  size: 915.89 GiB (98.32%) used: 86.64 GiB (9.5%) fs: ext4 dev: /dev/sdb1
  maj-min: 8:17 label: Festplatte1TB
  uuid: 4dde623e-8047-4245-84d5-bcb8dfa11f7e
  ID-5: /run/media/sebastianp/Festplatte3TB raw-size: 2.73 TiB
  size: 2.69 TiB (98.39%) used: 674.13 GiB (24.5%) fs: ext4 dev: /dev/sdc1
  maj-min: 8:33 label: Festplatte3TB
  uuid: 0e6f034a-c658-4d25-a53d-20ddc84b9afb
  ID-6: /run/media/sebastianp/GamesSSDLinux raw-size: 931.51 GiB
  size: 915.89 GiB (98.32%) used: 147.31 GiB (16.1%) fs: ext4 dev: /dev/sda1
  maj-min: 8:1 label: GamesSSDLinux uuid: a45782c4-3d4c-47fb-8676-553aae579070
  ID-7: /run/media/sebastianp/GamesSSDWindows raw-size: 931.51 GiB
  size: 931.51 GiB (100.00%) used: 569.74 GiB (61.2%) fs: ntfs dev: /dev/sda2
  maj-min: 8:2 label: GamesSSDWindows uuid: 6715844153CD810C
  ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Hub-2: 1-1:2 info: Microchip (formerly SMSC) ports: 1 rev: 2.0
  speed: 480 Mb/s power: 2mA chip-ID: 0424:2422 class-ID: 0900
  Device-1: 1-1.1:4 info: Yamaha Steinberg UR22mkII type: Audio
  driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-2: 1-2:3 info: Speedy Supplies Pte. type: Mouse,Keyboard
  driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 1017:6001 class-ID: 0300
  Device-3: 1-4:5 info: NZXT USB Device type: HID driver: hid-generic,usbhid
  interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 1e71:2007
  class-ID: 0300 serial: <filter>
  Device-4: 1-5:6 info: NZXT Smart Device V2 type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 1e71:2006 class-ID: 0300 serial: <filter>
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 3-6:2 info: Integrated Express IT8297 RGB LED Controller
  type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
  Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-7: 5-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 0bda:5411 class-ID: 0900
  Device-1: 5-1.3:4 info: eLicenser License Management and Copy Protection
  type: <vendor specific> driver: N/A interfaces: 1 rev: 1.0 speed: 12 Mb/s
  power: 18mA chip-ID: 0819:0101 class-ID: ff00
  Hub-8: 5-1.4:6 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  Device-1: 5-1.4.1:7
  info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
  driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip-ID: 0a12:0001
  class-ID: e001
  Device-2: 5-1.4.4:8 info: ESM GAME FOR WINDOWS 1.02 type: <vendor specific>
  driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA
  chip-ID: 2f24:00b7 class-ID: ff00 serial: <filter>
  Hub-9: 5-2:3 info: Texas Instruments ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 0451:8242 class-ID: 0900
  Device-1: 5-3:5 info: Holtek USB-HID Keyboard type: Keyboard,HID
  driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s
  power: 500mA chip-ID: 04d9:a12a class-ID: 0300 serial: <filter>
  Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-11: 6-1:2 info: Realtek Hub ports: 4 rev: 3.2 speed: 5 Gb/s
  chip-ID: 0bda:0411 class-ID: 0900
  Hub-12: 6-1.4:4 info: Realtek Hub ports: 4 rev: 3.2 speed: 5 Gb/s
  Hub-13: 6-2:3 info: Texas Instruments ports: 4 rev: 3.1 speed: 5 Gb/s
  chip-ID: 0451:8240 class-ID: 0900
  Device-1: 6-2.3:5 info: Sunplus Innovation MiraBox Video Capture
  type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 3.1
  speed: 5 Gb/s power: 512mA chip-ID: 1bcf:2c99 class-ID: 0102
  System Temperatures: cpu: 50.4 C mobo: 29.0 C gpu: nvidia temp: 44 C
  Processes: 377 Uptime: 18m wakeups: 0 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: 1497 pacman: 1480
  lib: 399 flatpak: 17 Shell: fish v: 3.3.1 running-in: gnome-terminal
  inxi: 3.3.06
Welcome to the forum! :wave:
Since you’re a new user on this forum, I would recommend you take a look at the link below:
Please update your post accordingly. Thanks!
Ctrl + . opens the emoji picker - or it should - but in some installs you’ll see that e. If you press SPACE when you see the e, the emoji picker will appear.
I had this ‘e’ thing happen with manjaro gnome earlier this year, but since clean installing 21.1 that ships with kernel 5.13 it seems to work correctly (eg: emoji only with native apps)
When I had the ‘e’ issue you describe, sometimes it would get stuck in that input mode & I would be forced to restart the computer. Results were really unpredictable. Space, pick emoji & then close the pop-up is one way to get through it.
Thank you!
